Accumen cat 3 powering power valve on lock/unlock .....
Jamie S
PostPosted: 16:58 - 28 Dec 2009    Post subject: Accumen cat 3 powering power valve on lock/unlock ..... Reply with quote
Hey guys, fitted my self a Cat3:1 accumen alarm on my dt125, everytime I lock or unlock the "bike" (alarm) it powers up the power valve for a split seccond.
It has only happened since I wired the alarm to flash the indecators.
Is it just because there is 12 volts in the electrical system ?
As when the ignition is turned on the PV resets it position automaticaly.
Is this a problem and will it wear the pv motor out over time?
Jamie.
PDF of wiring diagram, page 12:
wiring link
oldbiker
PostPosted: 16:55 - 29 Dec 2009    Post subject: Reply with quote
Sounds like the flasher unit shares a common supply with the ignition dc feed.
This will not do any harm to the bike or alarm.
I just don`t like acumen very poor aftersales support
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
prawny1
PostPosted: 17:30 - 29 Dec 2009    Post subject: Reply with quote
My old accumen alarm was wired in to the rear side light and would live the whole bike when it flashed,
So if the headlight was switched on it would flash not just the side light and if I pressed the starter button the motor woulds turn whilst the alarm went off/flashed.
I suppose fitting a diode of some sort to stop the whole system becoming live by back tracking through the loom would eliminate this problem.
crackpotterpi...
PostPosted: 20:36 - 29 Dec 2009    Post subject: Reply with quote
i agree in the fitting a diode solution,a cheap and easy way of sorting the problem.......just think of a diode as a one way valve that will only let the electrical current flow one way
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
The last post was made 16 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 40.04 Kb
