Cb550 airbox removal ,will i need to alter carb setup?
shitfan
PostPosted: 20:32 - 01 Jan 2010    Post subject: Cb550 airbox removal ,will i need to alter carb setup? Reply with quote
Plan on turning a 76 cb550 into a cafe racer .
One of the things i plan on doing is removing standard airbox ,and replace with cone type air filters. Wil this alter carb setup.And
if so ,what will i need to do to set them up right. Question
hmmmnz
PostPosted: 20:40 - 01 Jan 2010    Post subject: Reply with quote
yes you will, probably up a 4 sizes atleast, more if you have changed the exhaust as well,
you'll also have to play about with the needle position, or even new needle sizes once you have sorted the main jets
have a read of this it should make things a little clearer
this is quite good as well https://dotheton.com/index.php?topic=9392.0;wap2
the humans are dead
I kick arse for the lord
The last post was made 16 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 31.98 Kb
