sticking throttle on wifes zx6r f3
lydanial
PostPosted: 22:13 - 02 Jan 2010    Post subject: sticking throttle on wifes zx6r f3 Reply with quote
the throttle is sticking on, and has to be rolled off.
i have narrowed it down to the throttle as i have stripped it and cleaned it and then it will snap back fine for a little while before sticking again.
suggestion please.
thanks
Ariel Badger
PostPosted: 22:33 - 02 Jan 2010    Post subject: Re: sticking throttle on wifes zx6r f3 Reply with quote
suggestion please.
thanks
Try moving it out about 2mm, it may just be clipping the end of the bar.
st3v3
PostPosted: 00:02 - 03 Jan 2010    Post subject: Reply with quote
As in, the handle grip is affecting it's "snap back" time?
If cables are freely moving, how close is the grip to both the bar and and throttle housing? Close enough to catch?
DeeTee
PostPosted: 01:22 - 03 Jan 2010    Post subject: Re: sticking throttle on wifes zx6r f3 Reply with quote
suggestion please.
thanks
Lend it to my wife Twisted Evil
st3v3
PostPosted: 01:57 - 03 Jan 2010    Post subject: Re: sticking throttle on wifes zx6r f3 Reply with quote
DeeTee wrote:
suggestion please.
thanks
I'm guessing this is a private joke..?
PostPosted: 10:44 - 03 Jan 2010    Post subject: Re: sticking throttle on wifes zx6r f3 Reply with quote
Have you suck any lubricant in there after cleaning?
I'd lube under the throttle tube as well as the cable.
As above, also check it's not rubbing on the switch gear or the bar end.
A slightly bent bar will do the same, but presume that's not the case here.
lydanial
PostPosted: 12:38 - 03 Jan 2010    Post subject: Reply with quote
i did consider that it may be catching the bar end, so i rolled the rubber back and it still did it.
i couldnt get the bar end off anyway as its seized.
PostPosted: 13:30 - 03 Jan 2010    Post subject: Reply with quote
If you haven't had the throttle tube off to give it a decent clean, I'd definitely be getting some silicon spray under there at least.
I've been quite surprised how much affect a clean and a bit of grease can have to 'feel' of the bike - like getting a free 10hp thought out the rev range Smile.
PostPosted: 13:44 - 03 Jan 2010    Post subject: Reply with quote
Make sure that there is a bit of free play in the cables. If the open and closing cables are adjusted to pull tightly against each other then it can cause the throttle to stick.
st3v3
PostPosted: 15:13 - 03 Jan 2010    Post subject: Reply with quote
I've found that getting a flat screwdriver under the grip to allow you to spray a bit of WD40 up inside it is great for making minor adjustments, get's it nice and slippy but that wears off in a very short space of time so you don't discover any inconvenient lack of control when riding.
The last post was made 16 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 65.98 Kb
