Servicing cost
rac3r
PostPosted: 10:14 - 06 Jan 2010    Post subject: Servicing cost Reply with quote
Just want to compare servicing costs. How much do you pay for:
1 - Minor service (every year)
2 - Major service (every 2 years or whatever)
EDIT: I'm talking if you go to a garage not DIY service
Chequered Flag
rac3r
PostPosted: 10:51 - 06 Jan 2010    Post subject: Reply with quote
No one services their bike Laughing
Chequered Flag
Itchy
PostPosted: 11:01 - 06 Jan 2010    Post subject: Reply with quote
Its just cost of parts for me:
XT600 which I had to service 4 times on the road:
Oil £16 for 3.2 litres
Oil filter £3
Spark plug 1/4 of an iridium £6
Air filter £4
New tyres front and back £35 each.
CBer
£20 of oil
£6 oil filter
£10 air filter
£16 spark plugs
Once every blue moon I do the valves which doesn't cost much other than a gasket and some shims just takes lots of time.
smegballs
PostPosted: 11:06 - 06 Jan 2010    Post subject: Reply with quote
I never really got the "service" to be honest. I keep up on top of things as they arise. I assume the point is to have the convenience of swapping a load of consumables at one time so downtime is minimised?
I do all my own work anyway so it would just be parts which are of course bike dependent.
PostPosted: 11:16 - 06 Jan 2010    Post subject: Reply with quote
S4, minor (every 6k) £130, Major (every 12k) best part of £500
TDM Minor (every 6k) £130(guess) Med (every 12k) £250 Major (every 24k) £330
PostPosted: 12:22 - 06 Jan 2010    Post subject: Reply with quote
Vast majority of the time I do it myself, so just pay for parts.
Sorry, meant to say - £180 for a 'minor' service on a KTM 690 enduro.
PostPosted: 12:35 - 06 Jan 2010    Post subject: Reply with quote
When I bought the CB500 four years ago I wasn't sure when certain things had been done, so I paid £227 for a full service, which included valves, carb balancing, a change of brake fluid, coolant, plugs, oil and airfilters. Since then it's been DIY.
rac3r
PostPosted: 13:33 - 06 Jan 2010    Post subject: Reply with quote
The reason I asked is because I phoned up a local Ducati garage (not a dealer, specialist type place) and he said it was about £300 for a minor service! Shocked Major is about £400 or £500 which isn't too bad.
I think I'll do the minor service my self Laughing
Chequered Flag
Dr. DaveJPS
PostPosted: 13:47 - 06 Jan 2010    Post subject: Reply with quote
now waiting for the likely workshop thread:
"my cambelt snapped and lunched my engine, what can i do?"
actually i have no idea if this is a problem with the 600 ducatis, but it is built into my mind as part of the ducati brand.
www.davejps.com
PostPosted: 13:55 - 06 Jan 2010    Post subject: Reply with quote
I'd do it myself, however apparently if you ask around on the Ducati Sporting club forum etc,s
Barry_M2
PostPosted: 14:08 - 06 Jan 2010    Post subject: Reply with quote
Pop round mine, I'll do it for you. My 916 was a piece of pi$$ to work on. The cams belts were simple, done in under an hour! Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
rac3r
PostPosted: 14:30 - 06 Jan 2010    Post subject: Reply with quote
I can do the minor service pretty easy, the belts are done every 12,000 miles/2 years so mine isn't due until 2011.
Are belts part of the major service?
Chequered Flag
LeeR
PostPosted: 19:22 - 06 Jan 2010    Post subject: Reply with quote
I don't do a minor service as such because I change the oil every 2,000 miles (monthly), the oil filter every 6,000 miles (quarterly), and the spark plugs every 7,500 miles and generally keep on top of things as per the service schedule.
I do have a major service once every 15,000 miles which costs around £250 and includes throttle body synchronization, valve clearances and I usually have a courtesy bike overnight.
My claim to fame: Austin Vince nicked my pen...
The Tot
PostPosted: 20:07 - 06 Jan 2010    Post subject: Reply with quote
Just paid southern cross £400 for my latest service; valve checks and FI balancing, lubing of cables etc. Most of it was down to the £50 labour costs. They did a good job since the bike feels balanced and compliant.
Minor services I do myself so that's only for parts.
Never argue with autism
That_Hornet
PostPosted: 22:07 - 06 Jan 2010    Post subject: Reply with quote
Last service on the hornet was 130 (parts and labor)
Now i do them myself.
Alexio
PostPosted: 22:33 - 06 Jan 2010    Post subject: Reply with quote
When I started biking I ended up getting my bike serviced every couple of months (or 1500 - 2000 miles). Half the time it was absolutely free and the other half of the time it cost £25.
Because I rag my bike so much I continue to use a garage to service my bike because there is almost always something else that needs to be repaired at the same time. My bike is now thoroughly abused.
nasty
PostPosted: 22:34 - 06 Jan 2010    Post subject: Reply with quote
I don't mind doing the oil and filter, plugs etc myself but when it comes to valve clearances etc I prefer to have a garage do that sort of stuff as I don't have the tools or the know how (or basically just don't want to do that shit).
July last year I changed the oil and filter myself but took it to the garage to have fork oil and seals, SH bearings re-greased, cables lubed and MOT all for £111
October I took it to the garage to have valve clearances done and carbs synched, as it was in there though I had the garage change the oil (Silkolene) and filter, clean the K&N air filter (adjusted the chain too without asking and without charging) all for £116
Then I changed the brake fluid when I got home.
ZX6R F3
69.9mph
PostPosted: 23:39 - 06 Jan 2010    Post subject: Reply with quote
This will give you a good idea of the typical servicing costs https://www.motorapido.co.uk/bike%20service%20details.php
and this is what is covered https://www.motorapido.co.uk/service%20details.php
The servicing schedule on more modern Ducs is mileage dependant and is 50% less if you do under a certain annual mileage (although I can't remember the exact figure at the moment, I think it's around 6,000 miles).
You'll have trouble getting top money at resale time without a Service History from a Duc dealer, so that's something to take into consideration. Thumbs Up
rac3r
PostPosted: 11:52 - 07 Jan 2010    Post subject: Reply with quote
That's why I'm doing the major at the garage, 1 because some of the things I don't want to/can't do my self and 2 I wan the stamp. As for the minor service £300 is too much for things that I can do pretty easily using the Haynes Manual Wink
The prices at Moto Rapido are pretty similar to the ones at RC Thumbs Up
I probably will never reach those mileage requirements so I plan to do the minor every year and the major/belts every 2 years
Chequered Flag
salty21
PostPosted: 12:04 - 07 Jan 2010    Post subject: Reply with quote
i couldn't imagine paying someone else to service my bike.
The way i see it, theres absolutely no harm in having a stab at something and aslong as you have the manual the risk is fairly low of you making a catastrophic mistake, even if you do you have probably saved more than enough to put it right by not taking it to a garage for the last 3 services.
Thats how i see it anyway. I know there are exeptions with some people who just dont get the whole spannering thing and aren't programmed that way, but i think even most of those people would be suprised at how simple small jobs are like; oil changes, spark plugs, air filters, chain tensioning sprockets etc.....
Smooth
PostPosted: 10:18 - 08 Feb 2010    Post subject: Reply with quote
I've just heard that my brother-in-law paid 750quid for a service of his '04 Triumph Daytona 600 Shocked
Now is is just me or is that a huge amount?
-yes, it was a main dealer...
TDM850
Syx
PostPosted: 13:53 - 08 Feb 2010    Post subject: Reply with quote
That's one dealer I wouldn't be going back to!
garth
Never taken a bike in for a service, never plan on doing so. When I do it myself I know a proper job has been done, and I also get an insight into the condition of my bike and how it works.
@rac3r, there are tuition videos of 2V duke servicing on youtube. They're quite simple engines. Thumbs Up
Smooth
PostPosted: 14:24 - 08 Feb 2010    Post subject: Reply with quote
I'm not sure what they did to the bike, but they certainly saw him coming...
TDM850
The last post was made 16 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 132.68 Kb
