| bobmcpop |
 bobmcpop L Plate Warrior
| EnergyInducti... |
 EnergyInducti... Crazy Courier
| lonie |
 lonie Banned
| nitro159 |
 nitro159 Two Stroke Sniffer
| davart |
 davart Derestricted Danger
| bobmcpop |
| davart |
| bobmcpop |
| Moo. |
 Moo. World Chat Champion
 Posted: 20:03 - 19 Jan 2010 Post subject: |
Hey there, i have a 1977 Honda CG, bang on with everything, and mine has a little hole, with what looks like a ball bearing in it, when turned upside down fuel leaks out, its an overflow pipe.
There are 3 rubbers tubes, breather pipe, overflow pipe, and the battery acid overflow.
My mirrors where different sizes, but one has a thread that it screws into, the right hand side is just a hole with a nut on the bottom.
Can i ask a question, does yours have a heat sheild between the card and the engine? I know the earlier ones had it, but do they need it? ____________________ A2 Passed 18/6/10 |
| bobmcpop |
 Posted: 19:28 - 22 Jan 2010 Post subject: |
yes mine does, although it is cracked and barely holding on... yours probably just fell off. Reckon mine will fall off pretty soon too
does anyone know what the little black cylinder is under the headlights? it has wires conected, is it the ignition coil/condenser? Mine starts to smoke after the engine runs for over 10 minutes!!
The electric system takes a few minutes to kick in after ignition which is strange - eg. the horn wont work to begin with, also the indicators will take a while before flashing weakly then slightly stronger...
All indicators produce weak light, but im sure the bulbs are the right voltage/wattage. can you think of anything that's wrong with the electrics? |
The last post was made 16 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
