Honda CG125 BR-T 1996 Chain Case
davart
PostPosted: 23:39 - 11 Jan 2010    Post subject: Honda CG125 BR-T 1996 Chain Case Reply with quote
Hi All,
I have the above bike and have a question for anyone who owns or owned one.
I have had a problem with the chain case fouling the rear wheel. This happened during my Module 1 test so had to re-schedule it.
I discovered this started when I wheeled the bike backwards on the manual handling part - there was the tell-tale 'clacking' of something catching the spokes.
Anyhow, I've removed the chain case and found that the lower half was catching at the leading edge and pushed the top half of the chain case out of line and into the rear wheel when the bike was wheeled backwards.
I'd like to check the correct fitment of the upper half of the chain case. At the pivot end of the swing-arm, does the chain case fit inside or outside of the vertical plate that is part of the swingarm. Looking at the cutouts, I'd say it was the outside (case overlaps plate) , but this chain-case was previously fitted with it tucked inside.
I hope this description makes sense to someone who has or had a CG125. I'm planning on buying a new chain case which is about £50, so I don't wanna ruin it by fitting it incorrectly.
Many Thanks for your help!
Dave.
P.S. I've now added a pic to accompany the explanation. Highlighted in a yellow box is the vertical plate, which is behind where the screw-lug is mounted.
1996 Honda CG125 BR-T
davart
PostPosted: 12:39 - 12 Jan 2010    Post subject: Reply with quote
Many Thanks for your reply!
The chain case has been dented in the past which makes it harder to see how it's fits correctly. Perhaps when I get a new one it be clearer on how it seats on the bike.
I have removed the lower half of the chain case and I'm running the bike like that for now.
This picture was taken when I first purchased the bike and the valve clearance, oil, chain, carburettor were being serviced. I'll check the tension but I think there's about an inch of play there now.
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 36.69 Kb
