| _sketch_ |
 _sketch_ Scooby Slapper
| Gawain |
 Gawain Nitrous Nuisance
| _sketch_ |
| baldy |
 baldy World Chat Champion
| stevo as b4 |
| Handsome |
 Handsome World Chat Champion
| Frost |
 Frost World Chat Champion
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
| _sketch_ |
| Pete. |
 Pete. Super Spammer
 Posted: 17:25 - 07 Aug 2009 Post subject: |
I don't like the 2 carbs idea. I vote for an angled manifold. Could it be that the monifold is actually angled and someone has fitted it wrong? ____________________ a.k.a 'Geri'
| _sketch_ |
 Posted: 14:31 - 06 Jan 2010 Post subject: |
Hi all,
Sorry to dig up this old thread but have had few personal problems recently and had to abandon all of my projects.
Back on the game now and the bike is in the same condition (slightly more rusty )
What would be the cons of leaving it how it is? Im only going to be riding it in nice weather conditions so won’t have to worry about water ect. Do you think that “filter” is enough to keep the dust out? Will I be getting enough air in the carb?
At the moment my main priority is getting it taxed and tested so it can be more of a rolling project.
Thanks in advance. ____________________ A sucker for 2 strokes
Cagiva Supermoto project |
| G |
 G The Voice of Reason
| Kickstart |
 Kickstart The Oracle
 Posted: 14:44 - 06 Jan 2010 Post subject: |
The filter will get drenched easily and has a very small surface area so will probably be fairly restrictive. Although it will keep the dust out.
What frame is it and what engine is it? Supercity by any chance? From vague memory I thought the carb went off to the side on them, and that doesn't look like a Dellorto carb. Looks possibly like a Mito manifold and Mikuni carb.
| _sketch_ |
| Kickstart |
 Posted: 15:20 - 06 Jan 2010 Post subject: |
Fairly sure the Mito and Supercity engines are basically identical. However the Supercity had a different carb manifold to push it to one side. Most Mitos had a 28mm carb very similar to the NSR, but some had a larger Mikuni or Keihin (forget which), and it is possible that carb is from one of those. Most Supercitys had 34mm Dellorto carbs.
Looking at the manual the stock carb on a Supercity is cranked off to the left, with a rubber tube then going past the rear shock and to the airbox that appears to sit behind and to the left of the shock.
Brembo brakes were also standard (although whether they are the standard ones on your bike is another question)
| _sketch_ |
| Kickstart |
| _sketch_ |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 17:54 - 06 Jan 2010 Post subject: |
YOu can get some pretty stubby minimoto filters e.g. clicky, might be worth looking into??
Even if it went in, I think having any flat surface that near the end of the bell-mouth is probably not that great an idea anyway mind you?!?  ____________________ The purpose of life is to fight maturity. |
| _sketch_ |
 Posted: 17:49 - 11 Jan 2010 Post subject: |
Cheers Blue,
Will defiantly be getting this sort of filter, just after the standard inlet manifold.
Hard to get any work done in this weather  ____________________ A sucker for 2 strokes
| twotakt |
 twotakt World Chat Champion
| twotakt |
 Posted: 00:40 - 12 Jan 2010 Post subject: |
If you run a 28mm carb instead of 34mm then one of these should fit:
EBAY
EBAY
The supercity also ran a 28mm PHBH in the newer models anyway so it'll still run well. Also check that 34mm is a VHSB ES rather than a VHSB LD. ____________________ R.I.P. Tareree Shiimi, 1985-2008 |
| _sketch_ |
The last post was made 16 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
