| mrr1 |
 mrr1 Traffic Copper
 Posted: 00:01 - 10 Jan 2010 Post subject: ybr 125 - maintenance advice needed |
hi all - after binnning my Fazer just before xmas and snapping off pretty much everything that stuck out on the left hand side I've decided to get a cheap winter hack. I've bought a 55 plate YBR125 with 15k on the clock, years MOT & tax for 600 quid off fleabay. Its been dropped a couple of times - a few very light scrapes here and there but nothing that won't fix up nice and shiny with filler, silver spray and some TLC. Engine runs sweetly and rest of bike is straight. I just need to know whats the best oil & plug to pop in and any other advice to help the little thing run as best it can.
cheers ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis. |
| miguel_costello |
 miguel_costello Nova Slayer
| Mark65 |
 Mark65 World Chat Champion
| neil. |
 neil. World Chat Champion
 Posted: 21:14 - 13 Jan 2010 Post subject: |
You might want to do a fork oil change if it hasn't been done already. 10w fork oil is what they specify for it and there's no set interval for changing it, but I was told 20k miles was 'well overdue', so 15k sounds about right. Mark (above) has put heavier oil in his forks and added spacers to increase pre-load on the springs to stiffen the whole lot up, so you may want to do that if you find them a bit too floppy.
As for engine oil, I now use Halfords 10w40 semi-synthetic, no problems. Used to use Shell VSX1 but it was quite expensive. Don't notice any difference with either to be honest. I tend to find after about 2'000 miles, it needs topping up a little bit.
I put a CR6HiX (iridium electrode) plug in for the sake of it. Bike starts first time even in these freezing winter temperatures we're getting now, but was also good with the standard plug. Only a couple quid difference so I thought what the hey... Apparent advantages (so I've been told) are hotter spark, uses less battery power, more efficient burn, a bit more MPG.
If it's the '05 model, check the battery as it ships with the type that needs topping up with distilled water, and people do overlook it, letting the level drop. It may have been replaced with a maintenance free battery by the previous owner, which doesn't need any attention.
Halfords also do a BA20D fitting 35/35w halogen bulb (cylindrical in shape) which is an excellent, considerably brighter replacement for the OEM krypton type (round in shape) in my opinion. It's the only bulb I've tried that doesn't flicker when I'm maxing the speed out on a dual carriageway/motorway. Halogen bulbs I've bought off eBay have been useless and tended to blow quickly. The Halfords one has been in for a good few months now and still going strong.
There's a Haynes manual for the YBR now which is worth getting, and there's also a service manual by Yamaha themselves: https://dl.dropbox.com/u/175946/YBR125ED_3D9-E0.PDF
Parts catalogue: https://dl.dropbox.com/u/175946/Moto-YBR125ED-3D91-2005.pdf
Owner's manual: https://ymenvom.nl/manuals/U3D9E0.PDF
That should keep you busy.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Bubbs |
 Bubbs World Chat Champion
 Posted: 22:35 - 13 Jan 2010 Post subject: |
Interesting... where do you actually order the parts?? Need a new side panel as the plastic has broken where it clips on... annoying!
Also have you found any way to make your ybr faster? i notice u have a fly screen. Mine tops out about 58-60 at the moment. Cheers  ____________________ Life begins at the end of your comfort zone. |
| miguel_costello |
 Posted: 23:46 - 13 Jan 2010 Post subject: |
yup, hoon it downhill with the wind behind you  |
| neil. |
 Posted: 08:08 - 14 Jan 2010 Post subject: |
| dafyddjohndavies wrote: | Interesting... where do you actually order the parts?? Need a new side panel as the plastic has broken where it clips on... annoying!
Also have you found any way to make your ybr faster? i notice u have a fly screen. Mine tops out about 58-60 at the moment. Cheers  |
I'd say a most official Yamaha dealers would be able to source parts from you just reading out the numbers from that book. I used Woodford Motorcycles in this way, but there's a place nearer to me now in Essex that I'll be trying soon.
I haven't specifically tried to make the bike go faster (a bit like polishing a turd), but the screen helps push the front down when the speed picks up, making things feel more stable. I found it difficult to keep the front end from being a bit wobbly at top speeds before that. I have, on 2 occasions, got 70mph on my GPS and speedo, which, very unusually, seems to be 100% accurate with the GPS. This was on an extremely good road surface, downhill, with the wind behind me and my chin on the tank! Otherwise, I find it tops out at 60-65, with it absolutely screaming at 65 (and taking ages to get there), and I'm not the lightest person (17st). I tend to keep it around 55. Different engine oils/spark plugs haven't seemed to make much difference, and neither has the use of premium fuels, like Shell V-Power (although it has detergents and cleans out the engine, apparently). I'm more interested in keeping it running the best it can, for as long as possible, as it's my only form of transport and I absolutely need it.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Bubbs |
| Alexio |
 Alexio World Chat Champion
| s1h |
 s1h Nova Slayer
| Mark65 |
 Posted: 19:58 - 14 Jan 2010 Post subject: |
Neil has it pretty much spot on, i changed to 15w fork oil and put 1 extra spacer in and raised the oil height by 10 mm, a lot better for me at 15 stone doesnt nose dive at the slightest sign of the front brake, i also put in a halogen bulb too, try ebay for parts too just type in ybr on the search. Every now and then i run a tank of shell v power through it, but it never lets me down, spark plug is changed at 3000 mile intervals and oil every 1000 miles.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Mark65 |
| mrr1 |
 mrr1 Traffic Copper
 Posted: 19:29 - 16 Jan 2010 Post subject: |
great advice chaps!!!
i took the silver flea out for a good spin today after a new air filter, nw iridium plug and a healthy dose of muc-off chain oil. -When i bought her i took the front wheel off and put the whole bike into the back of my car so the first thing i discovered was the speedo cable hub hadn't found the slots on the wheel hub - a bit of a faff to sort but done after 20 minutes. The front caliper was glad of a bit of a strip and clean, rear fender needed refixing. Only things that bother me now are the clutch and the back brake. On my fazer I like the biting point to be about half way between lever fully in and lever fully out, on the ybr the clutch itself won't allow that. The first time i rode it you only had to rest your fingers on the clutch lever and the clutch would be slipping, i assumed the lad who had it before had set it up like that however thats not the case. When I adjusted the cable you simply end up with a clutch cable thats really saggy and a clutch lever that flaps around for half an inch. As for the back brake when you really press on it something clicks and the pedal drops a couple of mill or so. Its more disconcerting than anything - theres that horrible thought that they're about to go pop and fail. Does any of this ring any bells? ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
| Mark65 |
| mrr1 |
 mrr1 Traffic Copper
| neil. |
| mrr1 |
 mrr1 Traffic Copper
| Mark65 |
 Posted: 10:35 - 18 Jan 2010 Post subject: |
They can be straightned as long as theres no creases, i was quoted £25 each when i noticed mine were bent, i had been riding it for at least 6 months like that, i still have my old ones as my bend was only about 4-5mm on each leg measured with a straight edge. As for safe to ride if theres no creses on them and they work smoothly i personaly would think ok maybe, but it depends on where ,how far, and fast i would be riding, nice and easy i would probably use it till i could get it fixed
Lukily my yamaha dealer (Wigan) who i bought the bike off split the cost of the new legs 1 each and sold mine to me at cost, and i got help from lonewolf and colin in the workshop to change them .
I was thinking of ebaying my old ones as i only noticed the bend when i took the forks out to change the oil weight.
You can get import forks on ebay £85 each, but i dont know if they are the exact same , you would need to check.
https://cgi.ebay.co.uk/Yamaha-YBR125-Left-Hand-FORK-YBR-125-2005-BRAND-new_W0QQitemZ300350734297QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item45ee4c7fd9
The actual fork leg ( the long chrome bit only) on its own is around £100 each from yamaha.
| Bubbs |
| neil. |
| Bubbs |
| neil. |
 Posted: 12:49 - 18 Jan 2010 Post subject: |
Not all parts, just the backs of brake pads and bits that need greasing on brake parts. It's not good at bearing a load which makes it useless on bearings, where you'd pack lithium grease. The back wheel just 'dragged' along, rather than locking up, but it's not good either way and is pissing me off today as it's on my mind.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| neil. |
 Posted: 22:29 - 18 Jan 2010 Post subject: |
Well I just replaced the shoes with a new set - old ones were glazed over but still had a good few mm of wear left. It was rather filthy in there and the cam had completely seized up to the point where it was impossible to actually remove it without the help of a bit of WD40. Springs were still strong, so I basically degreased everything with paraffin apart from the inside of the drum where I used brake cleaner and wiped all the old dust out. Greased the cam and rocker pin, then fitted the new shoes and put it all back together. It's now all very smooth indeed, no clicking, no seizing, no nothing. And this isn't something that's included in the service schedule from Yamaha...  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
The last post was made 16 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
