Overkill?
Mira
PostPosted: 13:14 - 16 Jan 2010    Post subject: Overkill? Reply with quote
Hay all, I'm about to get a bigger bike Very Happy which I'll be keeping outside my house in a not brilliant but not the worst part of Liverpool.
When my dad had his bike (old suzuki 100) outside the house the local scrots were forever trying to nick it. They buggered the ignition barrel then when they couldn't start it (they were very cr@p Rolling Eyes ) they decided to start pushing it over to trash it. This was going back a good few years now.
Now all my dad had was a crappy tiny padlock and chain (the type that wouldn't look secure on a peddle bike! Shocked ) chained to the lada he had at the time.
I'm planing on having a Almax chain/squire lock, bolt down anchor, alarmed disk lock, and bike cover.
Now my question is is it worth getting a concrete in ground anchor and/or a motorcycle alarm (cheap one off e-bay) as well?
Thanks all Thumbs Up
I have heard there are troubles of more than one kind. Some come from ahead and some come from behind. But I've bought a big bat.  I'm all ready you see.
Now my troubles are going to have troubles with me! ~ Dr Seuss.
Alexio
PostPosted: 13:34 - 16 Jan 2010    Post subject: Reply with quote
It's well worth finding a motion sensitive 120DB alarm in my honest opinion Thumbs Up
Blue_SV650S
PostPosted: 13:45 - 16 Jan 2010    Post subject: Re: Overkill? Reply with quote
The anchor and GOOD chain is what is going to stop it from getting nicked (well, if someone has target your bike, it is gone whatever you do ... but it WILL stop opportunists walking by and the less well equipped/lazy thief). These days alarms are just totally ignored by the public - and therefore by the scrote ...
If it is outside your house, then for your own peace of mind it might be worth getting an alarm (hopefully you will hear it and can react if you are in the house).
In short, the lock and anchor are the ones you want to spend good money on, any old alarm should do, so don't spend big money on one (unless you get one that is a multi point immobilizer too).
Mira
PostPosted: 14:43 - 16 Jan 2010    Post subject: Reply with quote
Thanks Thumbs Up
I was looking at an alarm/immobilizer on e-bay the cyclone V2.
The alarms are just so I can run out with harry the hammer if it gets set off Twisted Evil
Charlie
PostPosted: 15:08 - 16 Jan 2010    Post subject: Reply with quote
**Thinks about an alarm system linked to a stebel nautilus*** Thinking Thinking
That_Hornet
PostPosted: 15:33 - 16 Jan 2010    Post subject: Reply with quote
I had this alarm on my DT
https://www.busters-accessories.co.uk/productInfo.aspx?clearance=1&catRef=ACU1020&kw=alarms
Quite loud, easy to use and install.
and its 50 quid.
Thumbs Up Karma
Mira
PostPosted: 15:46 - 16 Jan 2010    Post subject: Reply with quote
£30 was the one I was looking at.
https://www.motorbikealarm.co.uk/node/47
27cows
PostPosted: 16:05 - 16 Jan 2010    Post subject: Reply with quote
Nothing prevents a bike from being stolen better than having a reputation of someone who will do serious and permanent damage to potential thieves. Obviously it's not a good idea to actually maim anyone...but if you can make the chavs think you might, that's the battle won Wink
cyberglass
PostPosted: 16:22 - 16 Jan 2010    Post subject: Reply with quote
Thats what i have done on the strom. Ive wired the indicator flasher to the stebel relay when the alarm goes off the stebel sounds with the indicators. The indicators flash to quickly for the stebel to hit full DB output but its still a hellova lot louder than the alarm itself.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
Ingah
PostPosted: 17:14 - 16 Jan 2010    Post subject: Re: Overkill? Reply with quote
Yes it is (especially a nice cheap one).
Ideally one that works in parallel with your ignition system (i.e. if your alarm fails you do not want to be stranded, you want to be able to unplug it and ride). If it helps the "advanced motorcycle alarm v3" i got from that site works like that. This is a less secure arrangement (unplug = no alarm OR immobiliser), but worth it imo, after all, your main security IS your chain / anchor point / frame of your bike (please don't put the almax through the front wheel and think it's secure...)
An alternative worth considering is a talking alarm (downside: might do your head in and you end up disabling it completely - upside: people will pay more attention to it the first time or 2 it goes off).
Regarding anchor points, it better be a lamp post or equivalent otherwise you're at risk of just having the "anchoring" item cut rendering your great chain useless.
I use a cover (often held down with a bicycle cable lock) and/or motion sensing alarm+immobiliser, Almax 3 (lamp post -> frame of bike when possible), and the bike's own steering lock. And the bike is datatagged. The bike? A 1995 CB500 (it's worth so much more than you'd expect to me). That may be overkill. I don't care Razz
-- Ingah
Mira
PostPosted: 17:44 - 16 Jan 2010    Post subject: Reply with quote
I looked at the V3 but it's a bit more expensive than I was thinking. I'll have to see what funds I can scrape together.
My ground anchor will be a hardie anchor, I was planning on looping the chain through the rear wheel and swing arm. Front wheels are a bad idea.
DMan
PostPosted: 18:36 - 16 Jan 2010    Post subject: Reply with quote
Another tip is to try and keep the chain off the ground, stops any decent leverage being gained.
Best tip, remember to always put the effort in to put all this stuff on each time, cos the one time you think "I just have sank to eat then sort the bike out" is the time your bike goes.... trust me..... Sad
2001 Hornet 600 - "Faster than yellow" Blue; Current: 1998 Yammy FZS 600 "Fazer" Black
You show me how to control a wild fucking gypsy and I'll show you how to control an unhinged, pig-feeding gangster.
Skudd
PostPosted: 19:20 - 16 Jan 2010    Post subject: Reply with quote
Yes Mira. you could bite their ankles. Laughing
I would get a ground anchor and a good chain or two, the alarm and cover are good ideas too.
Mira
PostPosted: 19:33 - 16 Jan 2010    Post subject: Reply with quote
Laughing hay i can give a nasty bite when i want. Laughing
27cows
PostPosted: 19:38 - 16 Jan 2010    Post subject: Reply with quote
True story, this. There was a notorious thieving shitbag who used to plague the estate where my mate lived. Said mate caught said shitbag attempting to cut the lock off his DTR125...
Shitbag was discovered stark naked, D-locked by the neck to a lamppost by the old bill...who took several hours to secure the services of the fire brigade to cut lock and free thieving scumbag.
I understand the tea leaf decided to curtail his activities after this incident, at least on that estate Laughing
TUG
PostPosted: 22:28 - 16 Jan 2010    Post subject: Reply with quote
A meta 357 or 375 or whatever they're called can be wired to a horn, so its very easy to wire to your stebel nautilus idea. Thumbs Up
I can wire them. Thumbs Up Wink
Haz ER-5, innit!
st3v3
PostPosted: 00:11 - 17 Jan 2010    Post subject: Reply with quote
Alarms can easily have a wire cut, or be zapped before the bike is touched so they don't go off. Solid security is the only way.
It's an awesome idea, trick is not to be recognized or have them too fearful to mention they were caught. Wink
yambabe
PostPosted: 01:03 - 17 Jan 2010    Post subject: Reply with quote
I've got some spare alarms I could probably put your way for not much cash Mira.
They are noise-only though and won't immobilise, but can be fitted wherever you can find space on the bike (mine is under the seat on my Zephyr), are activated by movement (and you can adjust the sensitivity), attach directly to the battery terminals, don't drain your power and have a remote fob to turn them on and off.
https://i12.photobucket.com/albums/a229/Yambabe/Aug09018.jpg
https://i12.photobucket.com/albums/a229/Yambabe/Aug09020.jpg
OH says a tenner plus postage or you can come and collect seeing as we are just up the road a bit. He has a few different makes to the one in the pic but they are all broadly similar.
Greenychris
PostPosted: 02:19 - 17 Jan 2010    Post subject: Reply with quote
babyyam I will have that alarm if the OP doesn't want Smile send me a pm
Bike: Honda CB 400. Car: Pug 306 HDI.
'Car is for traveling somewhere in particular because you have to, Bike is for traveling nowhere in particular because you want to.' -skluff
RGE, Ride in peace.
Mira
PostPosted: 12:06 - 17 Jan 2010    Post subject: Reply with quote
£10.. Thinking Wink ....sold! Thumbs Up Very Happy
I'll PM to sort details out with you. Ta Babyyam!
Ingah
PostPosted: 14:21 - 17 Jan 2010    Post subject: Reply with quote
st3v3 wrote:
Alarms can easily ... be zapped before the bike is touched so they don't go off.
Shocked how?! Surely professional thieves can't make EMP grenades too now? Wink
-- Ingah
CRF_Rider
PostPosted: 15:45 - 17 Jan 2010    Post subject: Reply with quote
as for locking it through the back wheel, dont, go through the sub frame Wink much harder to remove. Also dont leave the chain on the ground Smile
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
st3v3
PostPosted: 22:58 - 17 Jan 2010    Post subject: Reply with quote
There's a fair amount of demo vids on Youtube. Thumbs Up
The last post was made 16 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 126.95 Kb
