Powder coating my wheels
beatts
PostPosted: 20:13 - 16 Jan 2010    Post subject: Powder coating my wheels Reply with quote
Hi I have an FZ6 and the wheels are a little bit worse for wear.
They have a few chips and are quite pitted and so I would like to remove them and get them acid dipped then powder coated.
How easy a job is stripping the wheels. I need to remove the bearings and so I assume I will need to buy new bearing. Do they need to be pressed in professionally or can I do it by hand somehow?
Many thanks
kingsmith
PostPosted: 20:22 - 16 Jan 2010    Post subject: Reply with quote
just take every thing of the wheels bearings seals everything, easy to take apart, and fitting you can get them pressed in but i never bother just knock them in, as long as they go in straight you be ok.
and as you have them apart you might as well fit new bearings. but thats up to you? you might damage them removing them then you might not.
get pics up before and after as well.
good luck.. Thumbs Up
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
el_oso
PostPosted: 22:46 - 18 Jan 2010    Post subject: Reply with quote
when you knock the bearings out try not to hit the sealing surfaces. take your time and hit them out squarely by tapping opposite edges.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 16 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 35.62 Kb
