 minimaterix L Plate Warrior
 hmmmnz Super Spammer
 Posted: 06:22 - 18 Jan 2010 Post subject: |
did you make sure the pick ups went back in the same place??
ok 3 things are needed to make a bike run,
compression
spark (at the right time)
fuel (atomised and mixed with air)
so you have spark, probably at the right time
have you cleaned out the carb?? make sure there is no water ect mixed in with the fuel, and clean all the jets out
and the last, if all else fails pull your head and barrelll and check your rings and bore(you'll have to drain your cooling system, and you'll preobly need a gasket set as well)
have fun ____________________ the humans are dead
I kick arse for the lord
