VFR 400 Fuel pump
bruce_lee_22
PostPosted: 23:03 - 15 Jan 2010    Post subject: VFR 400 Fuel pump Reply with quote
hey does anyone know where i can get a vfr 400 nc30 89 model fuel pump? i think mine's gone, bike wont start up properly at all anymore
VFR 400 & RVF 400
st3v3
PostPosted: 23:06 - 15 Jan 2010    Post subject: Reply with quote
Tried Ebay?
MaybeGuy
PostPosted: 23:32 - 15 Jan 2010    Post subject: Reply with quote
they dont have one.
its a diaphragm valve. check your vacuum hose isnt perished.
if your thick, its the one that goes from your fuel tank into the cylinder block.
i was sold a non runner nc30 for £400. the vacuum hose had popped off. then fired straight up.
bruce_lee_22
PostPosted: 16:31 - 16 Jan 2010    Post subject: Reply with quote
mattsprattuk wrote:
they dont have one.
lol no its not the vacuum hose mate Sad it nearly starts, and thats about it really, can only be a fuelling problem Sad, i've tried ebay also, can find one anywhere Sad
VFR 400 & RVF 400
st3v3
PostPosted: 18:33 - 16 Jan 2010    Post subject: Reply with quote
Checked carbs?
MaybeGuy
PostPosted: 18:42 - 16 Jan 2010    Post subject: Reply with quote
You cant find one because they dont exist.
Sounds like the symptoms of a vacuum hose to me. Have you even checked?
Frost
PostPosted: 23:02 - 16 Jan 2010    Post subject: Reply with quote
They definatly don't have one. The fuel is in the tank above the engine and gravity sends it to the carb to be mixed. Sounds like you might have old stale fuel in your tank, if the fuel is old, changing it will fix the problem.
If the fuel is fresh then your problems mixture related and might be a problem with the choke/throttle stops/idle speed. These can be fiddled with by getting the tank off. If these are all fine a blocked jet would be the next most likely cause and will require you to remove and dismantle the carbs. dismatling and checking is simple, but getting the carbs back on the V4 engine layout is tricky.
st3v3
PostPosted: 23:46 - 16 Jan 2010    Post subject: Reply with quote
They are bloody tricky, a mate of mine had one and took them off, took us all day to get them back because they sit unevenly, so when you get the back two fitted, then the front two the back one's move out of position and you go on like this for hours.
Get's most frustrating after half an hour, we were at it for a few... Laughing Evil or Very Mad
Theoutsider
PostPosted: 23:52 - 16 Jan 2010    Post subject: Reply with quote
I`ve got a nc30.I have a VFR 400 nc30 and it doesn`t have a fuel pump,check the hoses like everybody on here said,if not try new plugs,they can die so easy.
bruce_lee_22
PostPosted: 02:08 - 17 Jan 2010    Post subject: Reply with quote
cheers guys, already took carbs off now, gonna clean them incase, and my jet's also gonna change the vacuum hose, so basically do everything you all suggested, but my bro thinks its my vacuum hose Thumbs Up thanks Thumbs Up
VFR 400 & RVF 400
bruce_lee_22
PostPosted: 00:19 - 18 Jan 2010    Post subject: Reply with quote
new update Smile me and my bro cleaned carbs, checked the jets cleaned them aswell incase, and also my vacuum hose has perished, but right near the nipple.....so rubber was hard to get off, so just gonna put carbs back in and new vacuum hose on, and hopefully should be sorted Thumbs Up Thumbs Up Thumbs Up Just wanna say thanks guys for all your help Thumbs Up Thumbs Up Thumbs Up
VFR 400 & RVF 400
Frost
PostPosted: 08:04 - 18 Jan 2010    Post subject: Reply with quote
Trick to getting the carbs back on:
Push the carbs into the front rubbers about a centimeter.
Let the carbs rest on the rubbers at the back.
With the aid of a flat screwdriver lever the rear rubbers over the top of the back of the carbs.
Push down firmly and it will all go together.
Essentially your just shoving the carbs down into the rubbers, but making sure that the tops of the rubbers don't get pushed down.
MaybeGuy
PostPosted: 11:36 - 18 Jan 2010    Post subject: Reply with quote
As above.
Its a 5 minute job to get them back on using that method.
Lol @ everyone else who spent ages doing it.
bruce_lee_22
PostPosted: 23:48 - 18 Jan 2010    Post subject: Reply with quote
mattsprattuk wrote:
As above.
yep done that Smile so upto now, me and my bro checked my carbs and also cleaned them, and the jets also, and got a new vacuum hose on, and the bike still wont start, fuel is getting into it as it struggles to fire up and backfires proving fuel is going through, so the only thing now is my sparkplugs? let me know if you think its anything else please, worked so hard last few days on it Sad
VFR 400 & RVF 400
serlant
PostPosted: 00:10 - 19 Jan 2010    Post subject: Reply with quote
could be something as simple as the spark plug leads not on the right cylinders? double check them?
Frost
PostPosted: 01:33 - 19 Jan 2010    Post subject: Reply with quote
If it's backfiring its getting more fuel than it is air and spark. Might be worn out spark plugs or a semi flat battery. Might be a blocked air filter or incorrect mixture settings.
bruce_lee_22
PostPosted: 22:31 - 19 Jan 2010    Post subject: Reply with quote
checked the air filter mate, and also battery just been fully charged, so it HAS to be spark plugs im hoping
VFR 400 & RVF 400
bruce_lee_22
PostPosted: 04:35 - 21 Jan 2010    Post subject: Reply with quote
Very Happy yo guys Very Happy managed to get it working, changed spark plugs etc Very Happy runs fine, also thanks to cleaning my carbs and jets, it doesnt struggle to start up anymore its great Very Happy thanks a lot for your help much appreciated Very Happy Very Happy
VFR 400 & RVF 400
Frost
PostPosted: 10:44 - 21 Jan 2010    Post subject: Reply with quote
We expect pictures of wheelies and burnouts by the end of the day.
bruce_lee_22
PostPosted: 16:08 - 21 Jan 2010    Post subject: Reply with quote
hehe Very Happy yeah will do some ill get a mate to video it or something =) only small problem now, somtimes about 6000rpm the exhaust sounds hollow as if fuel isn't being put through?
VFR 400 & RVF 400
Theoutsider
PostPosted: 01:44 - 22 Jan 2010    Post subject: Reply with quote
It`s always the plugs
bruce_lee_22
PostPosted: 18:20 - 23 Jan 2010    Post subject: Reply with quote
yeah thanks for your help Very Happy
got another small problem as i was putting bike back together noticed my throttle cable was twisted, and looks buggered, and i test rode it, in 1st and 2nd gear its fine can get to 16k revs but in all the other gears it wont go over 8000 rpm and i havent a clue what wrong any ideas?
VFR 400 & RVF 400
Frost
PostPosted: 19:29 - 23 Jan 2010    Post subject: Reply with quote
Sounds underpowered, probably fuel related. They naturally have a bit of a flat spot in power delivery around 6k but this gets much worse if the fueling is wrong. Try getting it to 13k in 2nd then changing to 3rd so the revs will be at about 9k and see if it pulls the gear then. If it doesn't you have big fueling problems. If it pulls it you just have a flat spot. Sticking some m3 washers under the needles helps to remove it if its duel to a sports exhaust.
bruce_lee_22
PostPosted: 22:58 - 23 Jan 2010    Post subject: Reply with quote
it is fueling mate i can tell, but i dont know what it could be Sad i tried what you advised but didnt work Sad im gutted, any ideas on what it may be or what i could do mate?
VFR 400 & RVF 400
Frost
PostPosted: 10:36 - 24 Jan 2010    Post subject: Reply with quote
If the carbs arn't sealed onto the rubbers properly you can get some running problems. As you've had them off and their a bastard to get back on, they are probably the first thing to check.
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.56 - MySQL Queries: 15 - Page Size: 130.02 Kb
