| Bishbash |
 Bishbash World Chat Champion
 Posted: 12:03 - 19 Jan 2010 Post subject: VFR 400 (NC24) Engine flat spot??? |
I did a VFR 400 up for my woman and I have ridden it twice, now, it will be OK for her to ride, but I want to get it perfect for her, so here is the issue;
I have bought new plugs, swapped the HT leads, and it runs on all 4 cylinders and I cleaned the carbs when I fitted them.
The bike will idle perfectly and rev to the limit and probably beyond. The issue resides in high gears and top speed, If I thrash the bike from stand still it will accelerate beautifully up until about 90mph then it does not want to go any further. I have tried slipping the clutch to get it to do something, but it doesn't, it just hits that flat spot and stays there.
I have accelerated gently and the same issue is there. It feels like it is restricted. I am pretty sure it isn't, but I will pull the carbs out to check to see if it has a kit in there. But am dubious to do so as it takes a while to due to the carbs.
Has anyone got any idea why it is doing this? ANY IDEA! I cannot figure it out.
Thanks
 ____________________ My current bikes are - YZF-R1 & GS 500 E
Trackday videos - https://www.youtube.com/user/bishbash13 |
| P. |
 P. Red Rocket
| Frost |
 Frost World Chat Champion
| Bishbash |
 Posted: 12:14 - 19 Jan 2010 Post subject: |
Yeah I am 80% sure it wont pull past 90mph in any gear, I will check it this weekend, in fact if I don't figure it out, I will stick my camera on there and post the link, might help solve the issue. You might be able to hear something I don't. ____________________ My current bikes are - YZF-R1 & GS 500 E
| MarJay |
 MarJay But it's British!
| Bishbash |
 Posted: 15:36 - 19 Jan 2010 Post subject: |
The breathers should be OK due to it running through all the other gears,but I will check them.
That's interesting to know about your NC21 not going over 90 when restricted. Makes me think it's got some washers in there now. ____________________ My current bikes are - YZF-R1 & GS 500 E
| Azonicben |
 Azonicben Could Be A Chat Bot
| Robby |
 Robby Dirty Old Man
| Blau Zedong |
 Blau Zedong Banned
| Bishbash |
 Posted: 08:48 - 20 Jan 2010 Post subject: |
Definitely not the speedo, but thanks for the reply.
Robbie, you might have saved me quite a bit of work, fingers crossed I can see that far down.
| Bishbash |
| P. |
 P. Red Rocket
| Bishbash |
| Bikeless |
 Bikeless World Chat Champion
| P. |
 P. Red Rocket
| Bishbash |
 Posted: 15:24 - 27 Jan 2010 Post subject: |
Yeah it is the same bike for the Mrs, but I didn't put the restrictions that I bought in the carbs.
I guess it means I am pulling the bike to bits again....Well the carbs anyway.  ____________________ My current bikes are - YZF-R1 & GS 500 E
| Billing |
 Billing World Chat Champion
 Posted: 21:05 - 27 Jan 2010 Post subject: |
Might be worth getting one of those colourtune things and seeing if your mixture is good on all the cylinders, i think the vfr takes the 10mm one (the spark plug number should begin with a C i.e CR8EA)
How about seeing if a motorbike shop will put the bike on the dyno and see if that reveals anything  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Bishbash |
| Billing |
| Bishbash |
| Billing |
 Posted: 00:53 - 03 Feb 2010 Post subject: |
Any updates Bishbash? If you're still having problems someone over on 400greybikes.info might be able to help you, they seem a fairly good bunch  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 12:26 - 03 Feb 2010 Post subject: |
from the video it definatly looks like somethings up. it is fairly unlikely, but have you checked for a throttle body restrictor in the carbs? (ie the other form of restriction instead of the washers) as it should pull way harder than that up past 60. if the carb dismantle reveals nothing then im out of ideas . keep us posted! |
| Bishbash |
 Posted: 11:13 - 04 Feb 2010 Post subject: |
I havn't had any time what so ever to look at the bike, I am planning to do it on saturday, so we'll see.
I will take a peek at the throttle restriction, another good idea.  ____________________ My current bikes are - YZF-R1 & GS 500 E
| Bishbash |
 Posted: 09:43 - 09 Feb 2010 Post subject: |
OK, finally had a chance to take a look at the carbs, there are no restriction kit in there
I have no clue what's wrong with it now, would it be simply due to it's age? It has done 32000 miles, it's not a great deal I know, but it is how it has been treated in those miles......  ____________________ My current bikes are - YZF-R1 & GS 500 E
| 0l0dom0l0 |
The last post was made 15 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
