VFR 400 (NC24) Engine flat spot???
Bishbash
PostPosted: 12:03 - 19 Jan 2010    Post subject: VFR 400 (NC24) Engine flat spot??? Reply with quote
I did a VFR 400 up for my woman and I have ridden it twice, now, it will be OK for her to ride, but I want to get it perfect for her, so here is the issue;
I have bought new plugs, swapped the HT leads, and it runs on all 4 cylinders and I cleaned the carbs when I fitted them.
The bike will idle perfectly and rev to the limit and probably beyond. The issue resides in high gears and top speed, If I thrash the bike from stand still it will accelerate beautifully up until about 90mph then it does not want to go any further. I have tried slipping the clutch to get it to do something, but it doesn't, it just hits that flat spot and stays there.
I have accelerated gently and the same issue is there. It feels like it is restricted. I am pretty sure it isn't, but I will pull the carbs out to check to see if it has a kit in there. But am dubious to do so as it takes a while to due to the carbs.
Has anyone got any idea why it is doing this? ANY IDEA! I cannot figure it out.
Thanks
Karma
P.
PostPosted: 12:10 - 19 Jan 2010    Post subject: Reply with quote
Might not help, but my GS did that, but at around 80mph in 5th.. it kind of just not bogged down, but refused to pull harder.
Did a plug chop, was wet and apparently was over fuelling like mad.
Frost
So it won't go past 90 in any gear? or does it struggle at a certain number of revs? or just fail to pull higher gears?
Might well be restricted in some way.
Bishbash
PostPosted: 12:14 - 19 Jan 2010    Post subject: Reply with quote
Yeah I am 80% sure it wont pull past 90mph in any gear, I will check it this weekend, in fact if I don't figure it out, I will stick my camera on there and post the link, might help solve the issue. You might be able to hear something I don't.
PostPosted: 14:52 - 19 Jan 2010    Post subject: Reply with quote
Check all of the breathers are OK and not kinked or trapped under the tank. The Airbox breather is a particular pain as I recall.
My NC21 wouldn't go past about 90 when it was 33bhp restricted though, the carbs are a bitch to remove. You have to make sure that you get them squarely on the rubbers before pushing them down, and you most defintely must loosen the clips which hold them on or you'll just pinch them when you try to put them back.
Bishbash
PostPosted: 15:36 - 19 Jan 2010    Post subject: Reply with quote
The breathers should be OK due to it running through all the other gears,but I will check them.
That's interesting to know about your NC21 not going over 90 when restricted. Makes me think it's got some washers in there now.
Azonicben
PostPosted: 16:20 - 19 Jan 2010    Post subject: Reply with quote
Has it got kph or mph clocks?
I know on the Nc29(cbr400) they are restricted for the japanese market, a mechanical speedo converter takes away the restriction. The restriction kicks in at 180kph ~ 110mph of course the converter makes the clocks read in mph so the bike never reaches 180kph on the dial as its 180mph with the converter.
cheapos on eBay===> https://cgi.ebay.co.uk/mechanical-kph-mph-speedo-converter-honda-yamaha-suzuki_W0QQitemZ120520228310QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item1c0f90bdd6
https://cgi.ebay.co.uk/KPH-KM-H-MPH-KILOMETRE-MECHANICAL-CONVERTER-MOTRAX_W0QQitemZ370322860990QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5638f66bbe
This may work, depends whether the vfrs are restricted in the same way, a light bit of googling suggests they may be Thumbs Up
EDIT:
In standard trim an NC was restricted to around 111 mph or 180 klicks :-
The restriction is controlled by a sensor in the speedo, which can be circumvented fairly easily.
* First remove the speedo assembly - two bolts, speedo cable and the two connector blocks.
* Remove the cover from the speedo - Lots of black posidrive screws plus the odometer knob. This is held in place by a tiny posidrive screw in the end, which is normal ......
* Remove the speedo unit - undo 4 silver posidrive screws at the rear of the assembly.
* You should now be able to see the sensor. It is a cam shaped disc attached to the speedo drive, which makes contact with a metal strip (you will see its connected to one of the two wires that come in through the back of the speedo) at the magic 180 klick mark. All one needs to do is bend the strip out a tad so it doesnt make contact with the disc and snap ..... the bike is derestricted.
You will also see that the two wires entering the speedo are connected together by a resistor. This is just to tell the bikes electrics if the sensor has been disconnected, and if it is not in the circuit causes the bike to misfire above 5500 rpm.
Disclaimer: This work if tried is entirely at your risk
From ==> https://www.vf750fd.com/motorbikes/NC24.html
So you could rip your speedo to bits, or the converter should do it Thumbs Up
Robby
Dirty Old Man
PostPosted: 20:07 - 19 Jan 2010    Post subject: Reply with quote
NC24s don't have an electric speed limiter like on the NC30. They just limit their top speed by being shit.
You should be able to check for restrictors by getting the tank and airbox lid off, opening up to full throttle and pushing the slide out of the way, that should let you see down to where the restrictor is.
Bishbash
PostPosted: 08:48 - 20 Jan 2010    Post subject: Reply with quote
Definitely not the speedo, but thanks for the reply.
Robbie, you might have saved me quite a bit of work, fingers crossed I can see that far down.
Thumbs Up Wink
Bishbash
PostPosted: 09:21 - 26 Jan 2010    Post subject: Reply with quote
OK, I had a quick look as Robbie suggested, but I could not see anything, so before I rip the bike apart, here is a speed test of the bike, anything abnormal, let me know, it could help.
https://www.youtube.com/watch?v=Vn89-Fid3Kw
Oh let me know what you think of my new bullet camera/sound too. Thumbs Up
P.
PostPosted: 23:29 - 26 Jan 2010    Post subject: Reply with quote
well its orgasmic up until 90..
is it definitely not over fuelling? the revs bounced, not sure if it was your clutch doing so, but it went up then down then up again then down.
my gs pulsed a bit like that when it was over fuelling, only when going fast though, i say fast 80-100ish
Bishbash
PostPosted: 09:17 - 27 Jan 2010    Post subject: Reply with quote
It was me slipping the clutch to try to get something more. But it didn't.
By over fueling, you mean running rich, right? I don't think it would effect it that much....Would it? Thinking
Bikeless
PostPosted: 09:58 - 27 Jan 2010    Post subject: Reply with quote
Looks like it has a 33bhp restriction.
P.
PostPosted: 12:32 - 27 Jan 2010    Post subject: Reply with quote
if its the yellow bike you were doing up for your partner, you included pics of restriction washers.. dunno if you put them in though.
My GS was a bag of shit when it was running rich, like overly rich.
Bishbash
PostPosted: 15:24 - 27 Jan 2010    Post subject: Reply with quote
Yeah it is the same bike for the Mrs, but I didn't put the restrictions that I bought in the carbs.
I guess it means I am pulling the bike to bits again....Well the carbs anyway. Crying or Very sad
Billing
PostPosted: 21:05 - 27 Jan 2010    Post subject: Reply with quote
Might be worth getting one of those colourtune things and seeing if your mixture is good on all the cylinders, i think the vfr takes the 10mm one (the spark plug number should begin with a C i.e CR8EA)
How about seeing if a motorbike shop will put the bike on the dyno and see if that reveals anything Smile
Bishbash
PostPosted: 13:32 - 28 Jan 2010    Post subject: Reply with quote
That costs bucks though, not too keen on spending more dosh on it. Wink
I will take it apart on Saturday morning and see what I can see.
But, that sounds interesting, I will take a look online to see what it does, are they easy to use?
Billing
PostPosted: 01:21 - 29 Jan 2010    Post subject: Reply with quote
Yup, I've been reading about them, they're basically a clear spark plug, you can see the colour of the flame inside the cylinder, just youtube 'colortune' and it should give you some idea of how it works.
if nothing else I'll see what they are on trade at halfords (they're ?35 on the shelf) and if its cheap enough I'll get one, may be able to lend it to you for a bit.
Bishbash
PostPosted: 13:18 - 29 Jan 2010    Post subject: Reply with quote
Hetzer wrote:
Has it ever done more than 90mph since you've owned it? If not check to see if the forward or rear sprockets have been changed from standard.
Only bought it last October and It hasn't been over 90 yet.
But, I never thought of the sprockets, the teeth are in good nick, cos I checked them when I had the bike in bits. Time to count some teeth.
Thanks, good thought. Thumbs Up
Billing
PostPosted: 00:53 - 03 Feb 2010    Post subject: Reply with quote
Any updates Bishbash? If you're still having problems someone over on 400greybikes.info might be able to help you, they seem a fairly good bunch Smile
0l0dom0l0
PostPosted: 12:26 - 03 Feb 2010    Post subject: Reply with quote
from the video it definatly looks like somethings up. it is fairly unlikely, but have you checked for a throttle body restrictor in the carbs? (ie the other form of restriction instead of the washers) as it should pull way harder than that up past 60. if the carb dismantle reveals nothing then im out of ideas Smile. keep us posted!
Bishbash
PostPosted: 11:13 - 04 Feb 2010    Post subject: Reply with quote
I havn't had any time what so ever to look at the bike, I am planning to do it on saturday, so we'll see.
I will take a peek at the throttle restriction, another good idea. Thumbs Up
Bishbash
PostPosted: 09:43 - 09 Feb 2010    Post subject: Reply with quote
OK, finally had a chance to take a look at the carbs, there are no restriction kit in there Crying or Very sad
I have no clue what's wrong with it now, would it be simply due to it's age? It has done 32000 miles, it's not a great deal I know, but it is how it has been treated in those miles...... Thinking
0l0dom0l0
PostPosted: 22:41 - 11 Feb 2010    Post subject: Reply with quote
hmm. well i would be going down the compression test route now. check those rings are okay. as long as the bike had a full service history then it should be fine. im just trying to think of any other things that cause this problem
another idea, i dont know if anyone mentioned about the sprockets but check the bike hasnt been seriously up geared by accident and it just simply doesnt have the power to pull past 90.
strange question but if you lie on the tank will it go any faster? or is it like just complete stop at 90?
good luck!!
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 135.13 Kb
