Auxiliary Fuel Tank when balancing carbs??
bigup
PostPosted: 20:37 - 24 Jan 2010    Post subject: Auxiliary Fuel Tank when balancing carbs?? Reply with quote
hi guys
im wanting to balance my carbs and was thinking of using an auxiliary fuel tank but no idea what i can use
don't really want to use my tank incase it falls and gets damaged
what do you guys use in this case?
im thinking radiator overflow bottle?
or something like this: https://cgi.ebay.co.uk/Lawnking-Mountfield-GGP-SV150-Fuel-Tank-Re-con-18550143_W0QQitemZ160364357724QQcmdZViewItemQQptZUK_Home_Garden_GardenPowerTools_CA?hash=item255675e85c
does it need to have duel feed or single?
bike is a Bandit 600 03 plate.
Thanks
andys675
PostPosted: 21:21 - 24 Jan 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/YAMAHA-RD500-RZ500RD-RZ-AUXILIARY-FUEL-TANK_W0QQitemZ270516886446QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3efc101bae
job done
TUG
PostPosted: 21:46 - 24 Jan 2010    Post subject: Reply with quote
Get a scott oiler refill bottle, leave the spout lid on and cut the bottom off the bottle then theres your aux fuel tank. Thumbs Up
Haz ER-5, innit!
PostPosted: 22:02 - 24 Jan 2010    Post subject: Reply with quote
job done
If you want to throw away your money.
You can make one using a pen, a coke bottle and some Araldite.
TUG
PostPosted: 22:04 - 24 Jan 2010    Post subject: Reply with quote
Or you could use my option or similair to it so theres no fuck balling about... seriously.
Haz ER-5, innit!
bigup
PostPosted: 22:17 - 24 Jan 2010    Post subject: Reply with quote
thanks for the suggestions guys.
how about one of these: https://cgi.ebay.co.uk/MINI-MOTO-MINIMOTO-petrol-tank-DIRT-BIKE-SPARES-PARTS_W0QQitemZ390145070037QQcmdZViewItemQQptZUK_Sporting_Goods_Pocket_Bikes_LE?hash=item5ad67553d5
Alexio
PostPosted: 22:21 - 24 Jan 2010    Post subject: Reply with quote
I would have thought that any plastic container at all would be suitable like chives suggested. Maybe old milk bottles? I seem to have loads of those laying around Thumbs Up
CaPo
PostPosted: 03:16 - 25 Jan 2010    Post subject: Reply with quote
I used a metal tin last time I done this, stuck it on the roof of my shed next to the bike and siphoned the fuel down the feed hose to get it started. Worked perfectly.
PostPosted: 10:38 - 25 Jan 2010    Post subject: Reply with quote
Yes, but where as to make mine you can find everything in your house, if he doesn't use a Scottoiler, he won't have an empty Scottoil bottle Rolling Eyes
finpos
PostPosted: 12:35 - 25 Jan 2010    Post subject: Reply with quote
cable tIe and the bIggest syrInge they wIll gIve you In your local chemIsts, costs pennIes. Best to say you don't want the needle!
Petrol eats some plastIcs, so take care wIth mIlk cartons etc.
F.
crazyjoyce
PostPosted: 19:14 - 25 Jan 2010    Post subject: Reply with quote
after spending what seemed like hours shouting and swearing with coke bottles and hose etc trying to get a fuel tight seal - i'd buy a ready made one!
TUG
PostPosted: 21:44 - 25 Jan 2010    Post subject: Reply with quote
Local bike shops should be full of them, i have a few at work for all sorts of different jobs. Rolling Eyes
Haz ER-5, innit!
TUG
PostPosted: 21:50 - 25 Jan 2010    Post subject: Reply with quote
Right go down to your local mechanics and see if they've any empty scottoiler refills failing that pm me your address and i'll send you mine ffs.
Haz ER-5, innit!
That_Hornet
PostPosted: 21:53 - 25 Jan 2010    Post subject: Re: Auxiliary Fuel Tank when balancing carbs?? Reply with quote
Thanks
Did a 99 Bandit tonight.
Single feed into the carbs. The 2 pipes connected to the left of the tank are the fuel in and the vacume pipe. (connected to carb 4).
Ed Case
PostPosted: 22:43 - 26 Jan 2010    Post subject: Reply with quote
If there's a motor-mower repair shop in your area see if they've got a used fuel tank(with tap) they can let you have. Mine cost a fiver, just the job !. Very Happy
Ed Case
PostPosted: 22:45 - 26 Jan 2010    Post subject: Reply with quote
stirlinggaz
PostPosted: 10:41 - 27 Jan 2010    Post subject: Reply with quote
hi,
i have never bought anything that i can make myself.
i have 2 contraptions that only took at most 5 minutes each to make up.
my first one was a glass jar, the type that frankenfurters come in. (the tall ones)
just pierced a hole through the lid & shoved a lenth of fuel hose through it.
o-ring inside & out & some instant gasket/sealant round it for good measure.
as i was worried about the glass jar breaking , i made an other out of a fairy liquid bottle.the nozzle is coincidently the exactly the same diameter as fuel hose. (you just need to open up the actual hole a bit,with an awl or similar pointed object, if you want a good flow of fuel)
did no-one ever watch blue peter, lol
cheers,
GAZ
alun111
PostPosted: 09:31 - 28 Jan 2010    Post subject: Reply with quote
I made one out of a coolant overflow/reservoir tank that my mate gave me. It has a screw on cap for filling, a bottom hole and a top hole. I bought a length of clear fuel hose and a plastic petrol-proof tap on ebay for about ?5 and connected them to the bottom hole. The top hole is a vent hole so that the fuel will flow. I got a metal coat hanger from a local charity shop, cut it up and twisted it back together through the tank's mounting hole at the top - making it easy to hang up.
bigup
PostPosted: 13:25 - 28 Jan 2010    Post subject: Reply with quote
i ended up getting a mini moto fuel tank, looks very good and will do the job nicely, only ?8 delivered on ebay.
Thanks guys
el_oso
PostPosted: 14:08 - 28 Jan 2010    Post subject: Reply with quote
you overpaid.
water bottle filled with petrol. bit of hose from b&q. sorted. under ?1. i was going to use this method to get home from Leicester when my vacuum tap got blocked.
if you are quick you can quite easily balance the carbs using the petrol still stored in the lines
Duke 390
Car: Jeep Wrangler 4.0L
TUG
PostPosted: 21:04 - 29 Jan 2010    Post subject: Reply with quote
Thanks guys
HOW MUCH!?!?! could of sent you mine for free... ah well, sorry mate can't help you unless you help me help you.
Haz ER-5, innit!
RS2MATRIX
PostPosted: 22:44 - 29 Jan 2010    Post subject: Reply with quote
i was also thinking about this, cant i just use the fuel in the carbs and run it with no tank at all? I have a feeling i could balance them all before the fuel runs out, no?
Reiju RS2 Matrix
Kawasaki ZXR400
PostPosted: 22:53 - 29 Jan 2010    Post subject: Reply with quote
My bike can run at tickover for about a minute with just the fuel in the float bowls, longer if I put the choke on.
PostPosted: 14:48 - 30 Jan 2010    Post subject: Reply with quote
I used to have one made form a 2-stroke motorcycle oil reservoir.
The last post was made 16 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 125.62 Kb
