Buying a crashed bike.......
SimonJ
PostPosted: 22:57 - 28 Jun 2004    Post subject: Buying a crashed bike....... Reply with quote
I'm thinking of buying a written off bike, as a cheap way of getting on the road.
Any advice, good idea, stupid idea etc?
I am a mechanic, so should have no problem getting it fixed, (never worked on a bike though!)
Is this where the sig goes then?
McJamweasel
BCF Junkie
PostPosted: 22:59 - 28 Jun 2004    Post subject: Reply with quote
It depends on how badly damaged it is.
Make sure you check everything over as much as you can, if you don't know bikes then take someone who does. Depending on the bike, forks can be got for around £100 if they are bent, fairings can be very costly to replace. If its taken a heavy impact then it will be worth checking the frame is straight.
PostPosted: 23:18 - 28 Jun 2004    Post subject: Reply with quote
There are different classes of write off's, so have a read through [this so you know what the differences between them all are.
Frost
PostPosted: 01:16 - 29 Jun 2004    Post subject: Reply with quote
buying a broken bike and fixing it is a great, cheap way of getting on the road. the last time i saw someone do they they bougtha a bike which had been in a head on argument with a wall. after replacing the front wheel and forks the thing was good as new. overall the bike cost £1000 less than just buying the same bike from a dealers.
bikes aren't difficult to work on so long as they are old and basic. when it comes to newer kit then ebing a bike specialist really does help alot.
McJamweasel
BCF Junkie
PostPosted: 10:54 - 29 Jun 2004    Post subject: Reply with quote
Oh yeah, just a warning. Do not buy an Aprilia RSV Mille that has been in a front end impact, even if repaired - the frames tend to crack at the headstock.
priller
PostPosted: 10:20 - 30 Jun 2004    Post subject: Reply with quote
Unless you can do most of the work yourslef and the bike is very cheap insurance right offs aint normally worth the effort.
If you bought a bike for £1000 that was worth £2000 in good condition. By the time you've spend £500 in parts to get a working bike its still going to be registered as a write off, so you're going to have a hard time selling it on again.
SimonJ
PostPosted: 23:33 - 30 Jun 2004    Post subject: Reply with quote
Well I am a mechanic, so will do all the work myself.
The figrues are more like a £3500 bike for about £800, so is pretty cheap.
It will be my first bike, so I'm not going to bother replacing the fairings, just reattach them somehow, and a quick spray over, so I'm not too pissed off when I drop the bloody thing!
The last post was made 21 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 52.38 Kb
