Hard to start with choke ....
Blue_SV650S
PostPosted: 17:07 - 27 Jan 2010    Post subject: Hard to start with choke .... Reply with quote
A bit odd this one ... my SV has become a bit hard to start (whirs over for ages before firing).
Found the best way to get it started quickest, is to try and start it without the choke on and as soon as it 'catches' wind in some choke.
It won't run/fire properly without the choke BTW.
I have changed the airfilter and it did make it a bit better, but it still has the problem.
Once the bike has been run for a bit (say 60s), it'll re-start easy.
Once it is going, it runs and idles flawlessly BTW.
Battery is pretty new and a proper Yuasa one, the bike turns over nicely, so not suspecting the battery in any way ...
Ideas? Thinking
crackpotterpi...
PostPosted: 17:56 - 27 Jan 2010    Post subject: Reply with quote
you could start off by checking the choke is operating at the carb end as it should and fully returning when put off Smile
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
Ariel Badger
PostPosted: 17:58 - 27 Jan 2010    Post subject: Reply with quote
Try a new set of plugs.
Blue_SV650S
PostPosted: 18:07 - 27 Jan 2010    Post subject: Reply with quote
But surely the choke IS working as it won't start with it on .... also once it has fired, I can wind the choke on an the bike runs off the choke leaver as normal ... it just won't initially 'grab' with it in! Confused
Plugs are always a good place to start I suppose ... but I did inspect the rear plug when I changed the air filter ... and it seemed OK Thinking
If we can't think of another good/logical reason why it is acting like this, then I'll try swapping the rear one* for a new one and see if it improves things ... Thumbs Up
*front one is a bit of a PITA to get to as I have lowers and lots of silicone grease round it to keep the water out
boundy
PostPosted: 18:53 - 27 Jan 2010    Post subject: Reply with quote
Dont be gay, the SV spark plugs are easy to change. on the front bank, just undo the bottom of the rad and move it forward a tad.
Oh, sorry. I forgot your SV wears a skirt and bra, this is why you should get a proper one.
Blue_SV650S
PostPosted: 19:26 - 27 Jan 2010    Post subject: Reply with quote
boundy wrote:
Oh, sorry. I forgot your SV wears a skirt and bra....
Yep .. I think they look nicer, but it does make it a pain to work on (well just an overhead to get the plastic off).
Anyhoo ... just taken the rear plug out and put a new (2nd hand) plug in ...
So ... out with the CR8E (stage left) in with the CR10EK I had lying about (stage right). The 8E is not the worlds BEST plug, but it did gave a good blue thick spark on the spark test ... the 10EK gave a slightly stronger one though ...
I'll test it tomorrow and see if it is keener to start Thumbs Up
In the meantime ... any more ideas?
finpos
PostPosted: 21:11 - 27 Jan 2010    Post subject: Reply with quote
One carb or two?
You might find the choke is doing two things - opening up an enrichment jet and also propping open the throttle a bit for extra air, you'll need to look at the carb to be sure. Possibly the enrichment jet is blocked - you should be able to tell by opening the choke at idle when the engine is warm (and maybe a bit of load on the engine...), it should slow down if the enrichment jet is working, not speed up!
f.
Blue_SV650S
PostPosted: 17:34 - 03 Feb 2010    Post subject: Reply with quote
Two carbs ...
Right, I had a looksee and BOTH of the choke plungers are working (i.e. the cables are not broken).
If I pull the choke on when the bike is hot/running, the revs 'dip' then pick up .. it revvs to ~4k rpm ....
I am not convinced it is enriching the mixture much though as it rides fine with the choke on ... i.e. not seeming as if it is running silly rich .... but then perhaps it wouldn't anyway!? Thinking
crackpotterpi...
PostPosted: 18:03 - 03 Feb 2010    Post subject: Reply with quote
mmmmmmmm does sound a bit strange,most bikes if set up properly when warmed up and you put the choke on will as you say over enrichen the mixture and should make them cough a bit...........maybe worth getting the carb mixture/balance checked?
0l0dom0l0
PostPosted: 21:17 - 03 Feb 2010    Post subject: Reply with quote
i agree with 1930 ariel, just try a NEW set of plugs. might even be worth upgrading to iridium plugs, they are only a couple of quid more expensive and after all your only buying 2...
was it starting with the choke fine before? if so what have you changed since then?
Blue_SV650S
PostPosted: 17:41 - 07 Feb 2010    Post subject: Reply with quote
Ok, got the compressor on its a55 ... just blowing down the air jets that are by the bell mouth ... lots of fuel came out of various orifices, so I was hopeful ... but sadly NO difference Sad
Ruddy bike ....
I could change the front plug next, but lets face it, is it really going to be that?!!!?!?!?! even if the front plug was poorly, surely it'd fire/start to fire on the rear ... Confused
Devans
PostPosted: 23:25 - 07 Feb 2010    Post subject: Reply with quote
I'm no way technically minded, and i kinda have a similar issue, i'm purely putting down too, either too much, or two little fuel.
My bike on cold mornings needs the choke, but too much won't start it, and neither will none.
So maybe your using too much?
And don't blip the thottle either, or even touch it.
Sounds obvious but it's how i have to start my bike.
finpos
PostPosted: 08:44 - 08 Feb 2010    Post subject: Reply with quote
I suppose you could go down the "all carb problems are electrical" route, in which case I'd be deeply suspicious of the front HT lead and cap which get grief on SVs (especially the old ones which don't have the little rubber flap). You could try taking off the cap and lead and bake it in a low oven for a while (drive off all the moisture) then try a cold start, see if it makes a difference.
In my very limited experience of trying to bump start an SV, I imagine with one dead pot it'll run terribly if at all.
f.
Blue_SV650S
PostPosted: 20:28 - 08 Feb 2010    Post subject: Reply with quote
The bike runs flawlessly once started (even when cold). I know what the SV feels like when the front plug/plug cap gets wet .. and it isn't that as it runs so well only a few seconds after starting ....
To start it it seems I have to have NO choke ... and it starts to fire pretty readily at that point .. I then 'pick it up' on the throttle and feed a bit of choke on ... which then allows me to let go of the throttle ... it sometimes stalls if I don't get it quite right, and I somply begin the process again.
It is an odd one ...
On a total curve ball ... could it be the valve clearances have closed up?? ... I have never checked them Thinking ... but I'd expect it to struggle to idle when HOT if that was the case (and it runs flawlessly). Confused
silky666
Captain Rulebook
PostPosted: 20:37 - 08 Feb 2010    Post subject: Reply with quote
Blue .. can you keep me in the loop with any findings / results with this please.
I know its a totally different bike and all that... BUT my WR400 has started to act like this.
Will only start with 'no choke' ... then runs fine once warm.
I am interested to know if its a valve thang!
Robby
Dirty Old Man
PostPosted: 12:51 - 09 Feb 2010    Post subject: Reply with quote
Always going to fun to diagnose things like this, particularly if it turns out to be something has no business being related.
Any chance of a blockage or kinked pipe somewhere? Could you have disturbed a carb or the airbox in its rubber when you changed the air filter?
Blocked exhaust - could you have put a load of water down it when washing the bike.
Bad plugs, poor HT leads, bad earth, tight valve clearances, dirty jets.
A modern bike, particularly something in a moderate state of tune, can have a lot of small things wrong with it before it feels like it's running badly on the road. One or a combination of the above things could affect starting.
Change the plugs and spray loads of WD40 over the HT leads, then see if it starts behaving.
Blue_SV650S
PostPosted: 20:35 - 09 Feb 2010    Post subject: Reply with quote
It isn't something I have disturbed/trapped as I only started fiddling with things like that AFTER it started playing up!! Wink
Anyhoo, after much swearing and bloodied knuckles, I have now changed the front plug Thumbs Up ... as I suspected, there is nothing visually wrong with the plug (ok so it is a bit mucky on the outside, but the important bits (electrodes) are in good condition) ...
I'll give it a true 'cold start' tomorrow and report back ... but I think we need to start looking elsewhere now plugs have been eliminated from the equation ... Thinking
Blue_SV650S
PostPosted: 20:45 - 10 Feb 2010    Post subject: Reply with quote
Rule number one reinforced once again!! ...95% of all carburation problems are electrical ... Very Happy
I need more cold starts to confirm it, but after sticking the new* plug in there yesterday - I'll be rogered sideways with a banana - it actually started fairly rapidly on full choke when I tried it today!!! Shocked
So Mr Silky666, when is the last time you changed your plug!?!?! Thinking
*I say new, it was a 2nd plug and of the wrong heat grade and 'variant' (supposed to be a CR8E slotted in a used CR10EK) but it seems to have done the trick Mr. Green
silky666
Captain Rulebook
PostPosted: 21:07 - 10 Feb 2010    Post subject: Reply with quote
Good detectering skills Thumbs Up
But I think my plug should be ok .... it was last changed 5 years ago. No I am not joking Embarassed
New plug please mr. www.motoward.com
Blue_SV650S
PostPosted: 21:23 - 10 Feb 2010    Post subject: Reply with quote
What is slightly embarrassing is that pretty much the first thing I say to anyone that is experiencing odd symptoms is 'try changing the plug(s), I have had all sorts of weird problems that have finally been tracked down to simply a poorly plug or plug cap' ... I was just trying to avoid it myself as the front plug is a right PITA Embarassed
PostPosted: 21:52 - 10 Feb 2010    Post subject: Reply with quote
You have to be the tightest rich person I know Blue (Including your oil saving escapades). Laughing
Go on, treat it to two new plugs. It deserves it. Razz
Blue_SV650S
PostPosted: 21:58 - 10 Feb 2010    Post subject: Reply with quote
Meh ... nowt wrong with the plugs I put in, seems a shame to throw them away!! Thumbs Up
Nothing wrong with a bit of recycling!! Cool
Blue_SV650S
PostPosted: 17:47 - 12 Feb 2010    Post subject: Reply with quote
Rule number one reinforced once again!! ... 5% of all carburation problems are carburation problems!! Confused
PostPosted: 20:04 - 12 Feb 2010    Post subject: Reply with quote
Well chaps, i hope you've dished good vibes to our resident chilli muncher.
Rule #0.5 Teacher knows best
Pat
Shamelessly posting drivel since 2008
Blue_SV650S
PostPosted: 20:14 - 12 Feb 2010    Post subject: Reply with quote
Pat
I have no idea what you are on about ...
Anyway, if it wasn't obvious from my previous post, even after all that plug changing it still refuses to start* .... so unfortunately the problem has nothing to do with the plugs Sad
I do however think I have now put 1.8, 0.2 and 2 together and know what is going on Shifty
*that one above was now obviously simple 'fluke'
The last post was made 16 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 134.86 Kb
