| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 17:07 - 27 Jan 2010 Post subject: Hard to start with choke .... |
A bit odd this one ... my SV has become a bit hard to start (whirs over for ages before firing).
Found the best way to get it started quickest, is to try and start it without the choke on and as soon as it 'catches' wind in some choke.
It won't run/fire properly without the choke BTW.
I have changed the airfilter and it did make it a bit better, but it still has the problem.
Once the bike has been run for a bit (say 60s), it'll re-start easy.
Once it is going, it runs and idles flawlessly BTW.
Battery is pretty new and a proper Yuasa one, the bike turns over nicely, so not suspecting the battery in any way ...
Ideas?  ____________________ The purpose of life is to fight maturity. |
| crackpotterpi... |
 crackpotterpi... Renault 5 Driver
 Posted: 17:56 - 27 Jan 2010 Post subject: |
you could start off by checking the choke is operating at the carb end as it should and fully returning when put off  ____________________ 1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun |
| Ariel Badger |
 Ariel Badger Super Spammer
| Blue_SV650S |
 Posted: 18:07 - 27 Jan 2010 Post subject: |
| boundy |
 boundy Nearly there...
| Blue_SV650S |
| finpos |
 finpos World Chat Champion
| Blue_SV650S |
 Posted: 17:34 - 03 Feb 2010 Post subject: |
Two carbs ...
Right, I had a looksee and BOTH of the choke plungers are working (i.e. the cables are not broken).
If I pull the choke on when the bike is hot/running, the revs 'dip' then pick up .. it revvs to ~4k rpm ....
I am not convinced it is enriching the mixture much though as it rides fine with the choke on ... i.e. not seeming as if it is running silly rich .... but then perhaps it wouldn't anyway!?  ____________________ The purpose of life is to fight maturity. |
| crackpotterpi... |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| Blue_SV650S |
 Posted: 17:41 - 07 Feb 2010 Post subject: |
Ok, got the compressor on its a55 ... just blowing down the air jets that are by the bell mouth ... lots of fuel came out of various orifices, so I was hopeful ... but sadly NO difference
Ruddy bike ....
I could change the front plug next, but lets face it, is it really going to be that?!!!?!?!?! even if the front plug was poorly, surely it'd fire/start to fire on the rear ...  ____________________ The purpose of life is to fight maturity. |
| Devans |
 Devans Spanner Monkey
| finpos |
| Blue_SV650S |
 Posted: 20:28 - 08 Feb 2010 Post subject: |
The bike runs flawlessly once started (even when cold). I know what the SV feels like when the front plug/plug cap gets wet .. and it isn't that as it runs so well only a few seconds after starting ....
To start it it seems I have to have NO choke ... and it starts to fire pretty readily at that point .. I then 'pick it up' on the throttle and feed a bit of choke on ... which then allows me to let go of the throttle ... it sometimes stalls if I don't get it quite right, and I somply begin the process again.
It is an odd one ...
On a total curve ball ... could it be the valve clearances have closed up?? ... I have never checked them ... but I'd expect it to struggle to idle when HOT if that was the case (and it runs flawlessly).  ____________________ The purpose of life is to fight maturity. |
| silky666 |
 silky666 Captain Rulebook
| Robby |
 Robby Dirty Old Man
| Blue_SV650S |
 Posted: 20:35 - 09 Feb 2010 Post subject: |
It isn't something I have disturbed/trapped as I only started fiddling with things like that AFTER it started playing up!!
Anyhoo, after much swearing and bloodied knuckles, I have now changed the front plug ... as I suspected, there is nothing visually wrong with the plug (ok so it is a bit mucky on the outside, but the important bits (electrodes) are in good condition) ...
I'll give it a true 'cold start' tomorrow and report back ... but I think we need to start looking elsewhere now plugs have been eliminated from the equation ...  ____________________ The purpose of life is to fight maturity. |
| Blue_SV650S |
 Posted: 20:45 - 10 Feb 2010 Post subject: |
Rule number one reinforced once again!! ...95% of all carburation problems are electrical ...
I need more cold starts to confirm it, but after sticking the new* plug in there yesterday - I'll be rogered sideways with a banana - it actually started fairly rapidly on full choke when I tried it today!!!
So Mr Silky666, when is the last time you changed your plug!?!?!
*I say new, it was a 2nd plug and of the wrong heat grade and 'variant' (supposed to be a CR8E slotted in a used CR10EK) but it seems to have done the trick  ____________________ The purpose of life is to fight maturity. |
| silky666 |
| Blue_SV650S |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:52 - 10 Feb 2010 Post subject: |
You have to be the tightest rich person I know Blue (Including your oil saving escapades).
Go on, treat it to two new plugs. It deserves it.  ____________________ My Flickr |
| Blue_SV650S |
 Posted: 21:58 - 10 Feb 2010 Post subject: |
| Blue_SV650S |
 Posted: 17:47 - 12 Feb 2010 Post subject: |
Rule number one reinforced once again!! ... 5% of all carburation problems are carburation problems!!  ____________________ The purpose of life is to fight maturity. |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Blue_SV650S |
The last post was made 16 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
