The rs125 projects.
steveh
PostPosted: 21:54 - 28 Jan 2010    Post subject: The rs125 projects. Reply with quote
Well, i made a post in random banter about deciding what to do with a RS125 (top end siezure) that i gained.
So logic dictates, buy another one! Very Happy
Got the siezed one for ?95.
and the crashed, running one for ?50.
should be interesting, hopefully make some pennies too.
pics below.
also, anyone got any ideas whats damaged the piston, i was thinking the headgaskets gone (brown stain on surface) and its been leaking in and weakening the piston due to massive drop in temp, and its failed?
steve.
MaybeGuy
PostPosted: 22:40 - 28 Jan 2010    Post subject: Reply with quote
my vote is for powervalve hitting the piston. assuming the chip is on the exhaust side.
steveh
PostPosted: 22:47 - 28 Jan 2010    Post subject: Reply with quote
yeah, EX side, the guy that owned it said he heard a big "bang" and it cut out, ive removed the powervalve and there isnt a mark on it, but that being said, pistons are alloy, the valve is steel.
MaybeGuy
PostPosted: 22:59 - 28 Jan 2010    Post subject: Reply with quote
its apparantly quite common on them. a pin comes loose or something and it lets the valve slide further than it should? could be complete shit.
either way, you got a good deal with the prices.
PostPosted: 10:56 - 29 Jan 2010    Post subject: Reply with quote
No real way for the power valve to touch the piston on the RS125 engine (think Matt is thinking of the RS250 which uses a totally unrelated engine).
Those prices for the bikes are complete steals.
My guess would be that it has overheated and smeared half the piston up the side of the barrel (exhaust side being the hotest).
ballbag
PostPosted: 15:59 - 29 Jan 2010    Post subject: Reply with quote
Kieth is correct, the RS250 engine was actually taken from the Suzuki RGV250 (VJ22 model I think) - Aprillia just changed the CDI to their own. Anyway, that engine is known for dropping powervalve pins into the engine with fairly horrific consequences.
twotakt
PostPosted: 20:25 - 30 Jan 2010    Post subject: Reply with quote
Bargain on both of them, well done
R.I.P. Tareree Shiimi, 1985-2008
PostPosted: 23:15 - 30 Jan 2010    Post subject: Reply with quote
I hate RS125s, but even I'd have them at that price.
I'm jealous Sad
aprilia_simon
PostPosted: 21:41 - 07 Feb 2010    Post subject: Reply with quote
Good on you with the prices, look forward to see it running as I have the same bike.
steveh
PostPosted: 21:54 - 07 Feb 2010    Post subject: Reply with quote
heres a pick of the piston, looks like its been nipping up for a while, the locating peg for one of the rings is missing, so my theory is its worn out, rings have spun round and clipped the exhaust port.
Had one bike running, started to strip, clean and paint parts now.
https://www.bikepics.com/pictures/1897101/
aprilia_simon
PostPosted: 02:38 - 08 Feb 2010    Post subject: Reply with quote
my RS is 12713 km, I have no idea if its has a rebuild since then, should i do a top end rebuild ?. barrier and piston + rings ?.
steveh
PostPosted: 19:02 - 08 Feb 2010    Post subject: Reply with quote
I dont have a massive amount of experience with these, but usualy (depending on how its been ridden) 10k is were the grenade pin falls out and somthing nasty happens. Laughing
But, if its been looked after this might not be the case.
have a look at the base of the barrel, see if it says "aprillia/rotax"
If yours says somthing different like "mitika" its had the top end changed.
top end gasket sets arnt expensive, so if your wanting this bike to serve you well, it might be in your best interest to check it out, as its better to catch it now, than wait till it goes bang in a big way and your spending £300+ on a new barrel etc.
Hope this helps.
aprilia_simon
PostPosted: 19:54 - 08 Feb 2010    Post subject: Reply with quote
Okay thanks bud, will have look after work.
The last post was made 16 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 77.69 Kb
