zx6r spark plugs
brett750
PostPosted: 19:42 - 29 Jan 2010    Post subject: zx6r spark plugs Reply with quote
hi.
i have a thread in show and tell, and was just wondering if i will have to remove my carbs to change the spark plugs on a zx6r j1?
i also plan to remove the restrictors from the carb manifolds. could i do this by loosening or will they need removing?
thanks
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
brett750
PostPosted: 20:25 - 29 Jan 2010    Post subject: Reply with quote
iv already got the tank off, and the air box will be comeing off tomorrow.
is it a hard job to take the carbs off because im not known for my mechanical abilities. will they need setting back up?
thanks
evoboy
PostPosted: 21:15 - 29 Jan 2010    Post subject: Reply with quote
To get at the plugs on my J1 2000 model zx6, you onto need to remove the airbox, but its still an arse of a job to do.
To take out the restrictors, you take the airbox off, loosen the clamps on the bottom of the carbs (3mm allen key i think), then pop the carbs off and move them back a bit...
You shouldnt even need to take off any pipes or cables. Smile
APT Motorcycles
brett750
PostPosted: 00:09 - 30 Jan 2010    Post subject: Reply with quote
well i hope your right mate. ill let you know tomorrow or sunday. cheers
brett750
PostPosted: 16:58 - 30 Jan 2010    Post subject: Reply with quote
managed to do the spark plugs today. the one on the left (clutch) side was a bugger to get out but its all good now. will be having a crack at taking the restrictrs outa the carbs tmorro. wish me luck.....
temeluchus
PostPosted: 17:18 - 30 Jan 2010    Post subject: Reply with quote
with the airbox off, you can probably just loosen the clamps on the carbs, lift them onto the head and pull the restrictors out of the inlet rubbers. I doubt youll need to disconnect the throttle cables.
The last post was made 16 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 54.21 Kb
