MZ Mastiff 660e
BanditJeff
PostPosted: 21:29 - 29 Jan 2010    Post subject: MZ Mastiff 660e Reply with quote
Any thoughts from anyone on these bikes ?
Saw this one that finished on e bay today, but wasn't sure if it was a good price or not...
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300389569829&_trkparms=tab%3DWatching
For a while now i've been wanting an enduro/supermoto as a second bike. Was gonna get a DRZ 400 but when i test rode one i found it too gutless on the road so thought i'd look at higher cc stuff with a bit more power.
PostPosted: 21:34 - 29 Jan 2010    Post subject: Reply with quote
It's an XTZ660 motor manufactured under licence.
The Baghira was the same price as the mastiff but was taller and had compression and rebound adjustable forks. Came with either 17" or 21" front wheel. Other differences were a square headlight and a high level mudguard.
The spec of the componants was very good anthough the bike as a whole is pretty heavy compared to many "proper" enduro bikes. A good package though. I had one and liked it.
BanditJeff
PostPosted: 21:43 - 29 Jan 2010    Post subject: Reply with quote
I'm really more interested in reliability and not having to service it every few hundred miles.... so i'm not really looking for high spec race stuff or ultra light stuff for off road.
One thing that appealed to me about this bike was the cheap insurance, got an online quote of only ?70 TPFT, and thats without using my no claims that are on my Bandit.
But i know nothing about these bikes or what price they go for.
PostPosted: 21:58 - 29 Jan 2010    Post subject: Reply with quote
Oil every 3k miles as I remember. It takes the XTZ oil filters.
A bit of a fanny to change the oil because it's dry sump and oil in frame but it's a well proven engine design.
When I had mine, I was the only person in Europe to have blown an engine within the warranty period (casting failure on the conrod). It was so unusual for an engine to fail, they had it shipped back to Germany so they could strip it down to find out what went wrong, then repaired it with new parts.
PostPosted: 22:07 - 29 Jan 2010    Post subject: Reply with quote
XTZ engine still doesn't make much power, but with even more weight.
You mention 'enduro', which concerns me - I wouldn't consider it a supermoto, with the only real advantages it has over something like an SV650 is the lack of power, which can often be more power - but then you could just mildly restrict an SV650 for the same effect Smile.
BanditJeff
PostPosted: 22:17 - 29 Jan 2010    Post subject: Reply with quote
So servicing mileage is ok then.... that would only be once a year for the mileage i'd do on it. And good reliability, well apart from yours that seemed to be a one off. So it looks like a contender to me if i like the way it rides.
So is this price of ?1,500 about right for 2003 model with 19,000 miles ? Or is it too expensive ? Just wanted a rough ball park figure for price if another one comes up.
This guy on e bay may come back to me if his supposed buyer doesn't pan out.
BanditJeff
PostPosted: 22:21 - 29 Jan 2010    Post subject: Reply with quote
Yes but i want a bike with this styling... not a small road bike like an SV650.
PostPosted: 23:00 - 29 Jan 2010    Post subject: Reply with quote
Fair enough, if you want to pay more for less Wink.
If it's the styling rather than aspects of the ride, then a TDM850/900 might be worth considering as they're a fair bit less 'gutless'.
BanditJeff
PostPosted: 23:18 - 29 Jan 2010    Post subject: Reply with quote
Until i've ridden one of these MZ's i've no idea if i'll want one.... i may find it as gutless on the road as the DRZ.
Just wanted some opinions from someone who'd owned one.... and i like the idea of a trallie style bike to hoon around on in the winter so i dont get my shiney new Bandit shitted up with road crud and salt.
PostPosted: 01:30 - 30 Jan 2010    Post subject: Reply with quote
Tops out at about 110mph. Up to that it'll ride rings around an SV650. In fact, you get away with murder handling wise.
Should be noted I'm a dyed in the wool Suzuki hater though.
For a winter hack you could do FAR worse then an MZ. What isn't powder coated is stainless or plastic. Including a stainless exhaust as standard. Probably the best bike I've ever owned in terms of tolerance for neglect.
No idea on price but I'd hold out for a baghira if I were you. The suspension is far superior and they ought to be a similar price.
Here's my baggy (got stolen in the end). I fitteed a low level exhaust and some kick-arse spot lights. Otherwise standard.
https://i48.photobucket.com/albums/f216/stinkwheel/Glentrool_2005_15.jpg
PostPosted: 08:41 - 30 Jan 2010    Post subject: Reply with quote
I'm also a dyed in the wool badly specced bke hater Smile.
The SV handling isn't amazing as stock, but I always found it was perfectly acceptable for the vast majority of road riding, So I'd find it hard to believe that the MZ was that much better - in what areas, as it's obviously not power and serviced SV brakes are fine for stopping from high speed on one wheel if desired.
If the MZ was ultra-light, I could understand some more due to a 'spirtely feel', but it's actually listed as being heavier.
BanditJeff
PostPosted: 09:33 - 30 Jan 2010    Post subject: Reply with quote
I'll deffo give the Mastiff or the Baghira a ride if i find one local. Cheers for your input.
garth
PostPosted: 10:46 - 30 Jan 2010    Post subject: Reply with quote
I've a red baghira with about 10k miles on which you can have for less than that. Pm me for more info.
PostPosted: 11:16 - 30 Jan 2010    Post subject: Reply with quote
Simply handling. Same size wheels, same tyres, better suspension, more forgiving geometry.
It goes where it's pointed without having to think about it. You can take liberties with the handling, change lines partway round corners and generally mess about in a way that would have you off many bikes. Get onto a rough/uneven/bumpy road surface and twistier roads (of which there are many in the UK) and the difference is even more noticeable. It keeps both wheels on the ground at speeds and angles where other bikes do not.
The spec of the suspension is top-notch for factory fitted equipment.
funmonkee
PostPosted: 10:14 - 14 Feb 2010    Post subject: Reply with quote
I've had a baggy (see my profile). They are great fun bikes. Brilliant in town - it's tall and light; not bad on fuel; can take a little city 'offroading' (*) Laughing
Only downside for me was the top speed. It can reach 100ish, but from 75 onwards it feels like it'll explode. Obviously it a single so that's natural Karma Oh and other than the engine and front discs (Vmax front discs fit), it's a bugger for spares.
I bought a Speed Triple and it killed the MZ for me. The S3 is grunty, has a good top speed, is smooth and has a good riding position...
Saying that, given some spare buck$ and a bigger garage I'd buy another Baggy. They look fantastic and as Stinkwheel says VERY forgiving on corners.
HTH
(*) Kerbs, steps etc Thumbs Up
https://i133.photobucket.com/albums/q73/funmonkee/baghira/IMG_0159.jpg
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
PostPosted: 10:57 - 14 Feb 2010    Post subject: Reply with quote
Never found a massive problem with the SV when riding on roads, but the suspension can be easily and cheaply upgraded (GSXR shok + aftermarket fork internals). I haven't found trail bike geometry to be that much more forgiving really - infact the longer travel can cause some issues with significantly changing that geometry, though it's not a big thing either way really to my mind.
Similar weight to my GSXR, the internet tells me, not what I'd describe as light (about 50% over what I'd hope for in a big single making that power). Up-gearing my KTM a bit it'll fairly happily sit at 100mph, though a fair bit of wind of course. The GSXR will do that in first gear, which I think justifies the weight it's got Razz.
Got a picture of my TRX with the rear wheel at the bottom of the steps and the front half way up - suspect I could have got them up properly if I didn't have 35 psi in the rear tyre! Take the GSXR over kerbs daily. Can do it at higher speeds with softer longer travel suspension, but generally wouldn't want to in town.
PostPosted: 13:54 - 14 Feb 2010    Post subject: Reply with quote
On a twisty back road or a rough road, the increased effort and concentration the SV requires to do the same job would ultimately make the MZ the faster bike in practical terms.
I think what funmonkee is referring to regarding steps and kerbs is riding up and down steps and gassing it off kerbs. Speed bumps and humpback bridges also become something to look forward to on a rideout. As do mini roundabouts (and the occasional proper roundabout if nobody is looking).
If we're talking about upgrading. I bet you could do the 720cc conversion to the MZ for around the same price as a GSXR rear shock and a fork revalve. Combine that with ditching the crashbars and various bits of subframe that add loads of weight and it all of a sudden becomes a lot faster.
MotoCal used to have a 720 Mastiff demonstrator, it was totally banzai and quick enough to be worth entering in some of the local supermoto racing.
PostPosted: 15:50 - 14 Feb 2010    Post subject: Reply with quote
Not a big difference in my experience.
And yes, I appreciate he probably wasn't talking about /actually/ riding up steps Wink - I regularly ride up kerbs/wheelie off them on sports bike - perfectly ample suspension travel.
It's like people in 4x4s that make a big thing of going up kerbs etc - even my relatively sporty coupe can handle most kerbs fine. My Laguna could actually take speed bumps near my work smoother/quicker than a fairly stock L200 could.
People do use some of the bit-heavier LC4 KTMs for supermoto racing, but I'd want some serious weight loss to try and be competitive on such a heavy bike on a supermoto track (with dirt).
Though, of course with a decent chunk of skill anything's possible Smile :
https://www.seppes.com/photos/635375312_hHs2c-XL.jpg
PostPosted: 16:23 - 14 Feb 2010    Post subject: Reply with quote
Looks like the offroad part of the Japanese 400cc+ bike test to me. The "Uneven pitch obstacle course".
funmonkee
PostPosted: 18:20 - 14 Feb 2010    Post subject: Reply with quote
I've ridden a sportbike (gsxr750) off and on steps, kerbs, speed bumps, small garage walls etc..but found the fork seals did last long; whereas the MZ just seems to naturally cope with that stuff (one garage attendant said ' cheeky! try doing that with a road bike') ...maybe due to it's WP suspension- it just was good/easy for that stuff. As for weight; I've never ridden an SV. The MZ was very light to me, but when you realise my garage at that time included a Vmax and Hayabusa amoungst others, then it was a very light bike in my experience Very Happy
I rate the MZ for city riding as it's forgiving and fun. Avoid snow I fell off it. I didn't like the top speed - but it's unrealistic to expect ore from the XT engine, I think a twin is the way to go for me. I have my eye open for a superduke Karma
PostPosted: 18:48 - 14 Feb 2010    Post subject: Reply with quote
I've thought about this in the past - trail bikes tend to have softer suspension (though less for decent supermoto setups that have to deal with very heavy braking from speed with high grip).
So if you could handle occasionally bottoming out, you could just make your road bike a bit softer for the same smoothness over bumps.
Note the superduke only has slightly longer travel suspension (about 1", for which you're talking of course maybe 1/3" up and 2/3" down) than a slightly more 'road' bike like an Aprilia Tuono.
I haven't popped fork seals excessively from playing on sports bikes - I'm not sure there's really going to be more pressure than doing a 100mph-50mph stoppy or something, which I've done many times on road bikes in the past.
PostPosted: 19:32 - 14 Feb 2010    Post subject: Reply with quote
Well. Can't say as I ever bottomed the baggy out, not even in Ireland where the roads are shit.
Around a foot of travel at each end (from fully unloaded to fully compressed). I wouldn't say the suspension was soft so much as there was a lot of it. You got the impression it was extending into dips rather than compressing over bumps, if that makes any sense.
You could brake REALLY hard so you were leaning forwards over the bars yet not be doing a stoppie on account of the rear suspension still unloading. Made a god-awful clattering noise when it eventually did. Was a favourite trick to do at traffic lights. The driver sees a motorcyclists head appear in his field of view then disappear backwards again as the front suspension unloaded.
I wouldn't dream of doing shit like that on my VFR, I'd fall off.
PostPosted: 19:34 - 14 Feb 2010    Post subject: Reply with quote
I always thought a detuned MZ 1000S engine in a suitably stiffened and up-braked baghira chassis would have been an entertaining tool and would have pissed off BMW no end.
funmonkee
PostPosted: 20:13 - 14 Feb 2010    Post subject: Reply with quote
Forgot to add, the weight of my baggy was waay lighter than a standard machine. Purely down to the exhaust system. The original are as heavy as a car exhaust Laughing
I really liked the MZ1000SF Thumbs Up lots of goodies Thumbs Up
The last post was made 16 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 136.72 Kb
