| BanditJeff |
 BanditJeff Trackday Trickster
 Posted: 21:29 - 29 Jan 2010 Post subject: MZ Mastiff 660e |
Any thoughts from anyone on these bikes ?
Saw this one that finished on e bay today, but wasn't sure if it was a good price or not...
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300389569829&_trkparms=tab%3DWatching
For a while now i've been wanting an enduro/supermoto as a second bike. Was gonna get a DRZ 400 but when i test rode one i found it too gutless on the road so thought i'd look at higher cc stuff with a bit more power. |
 Posted: 21:34 - 29 Jan 2010 Post subject: |
It's an XTZ660 motor manufactured under licence.
The Baghira was the same price as the mastiff but was taller and had compression and rebound adjustable forks. Came with either 17" or 21" front wheel. Other differences were a square headlight and a high level mudguard.
The spec of the componants was very good anthough the bike as a whole is pretty heavy compared to many "proper" enduro bikes. A good package though. I had one and liked it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| BanditJeff |
 Posted: 21:58 - 29 Jan 2010 Post subject: |
Oil every 3k miles as I remember. It takes the XTZ oil filters.
A bit of a fanny to change the oil because it's dry sump and oil in frame but it's a well proven engine design.
When I had mine, I was the only person in Europe to have blown an engine within the warranty period (casting failure on the conrod). It was so unusual for an engine to fail, they had it shipped back to Germany so they could strip it down to find out what went wrong, then repaired it with new parts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
 G The Voice of Reason
 Posted: 22:07 - 29 Jan 2010 Post subject: |
XTZ engine still doesn't make much power, but with even more weight.
You mention 'enduro', which concerns me - I wouldn't consider it a supermoto, with the only real advantages it has over something like an SV650 is the lack of power, which can often be more power - but then you could just mildly restrict an SV650 for the same effect . |
| BanditJeff |
| BanditJeff |
| G |
 Posted: 23:00 - 29 Jan 2010 Post subject: |
Fair enough, if you want to pay more for less .
If it's the styling rather than aspects of the ride, then a TDM850/900 might be worth considering as they're a fair bit less 'gutless'. |
| BanditJeff |
 Posted: 01:30 - 30 Jan 2010 Post subject: |
Tops out at about 110mph. Up to that it'll ride rings around an SV650. In fact, you get away with murder handling wise.
Should be noted I'm a dyed in the wool Suzuki hater though.
For a winter hack you could do FAR worse then an MZ. What isn't powder coated is stainless or plastic. Including a stainless exhaust as standard. Probably the best bike I've ever owned in terms of tolerance for neglect.
No idea on price but I'd hold out for a baghira if I were you. The suspension is far superior and they ought to be a similar price.
Here's my baggy (got stolen in the end). I fitteed a low level exhaust and some kick-arse spot lights. Otherwise standard.
https://i48.photobucket.com/albums/f216/stinkwheel/Glentrool_2005_15.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| BanditJeff |
 Posted: 09:33 - 30 Jan 2010 Post subject: |
| stinkwheel wrote: | Tops out at about 110mph. Up to that it'll ride rings around an SV650. In fact, you get away with murder handling wise.
https://i48.photobucket.com/albums/f216/stinkwheel/Glentrool_2005_15.jpg |
I'll deffo give the Mastiff or the Baghira a ride if i find one local. Cheers for your input. |
| garth |
 garth World Chat Champion
 Posted: 11:16 - 30 Jan 2010 Post subject: |
| G wrote: |
The SV handling isn't amazing as stock, but I always found it was perfectly acceptable for the vast majority of road riding, So I'd find it hard to believe that the MZ was that much better - in what areas, as it's obviously not power and serviced SV brakes are fine for stopping from high speed on one wheel if desired.
If the MZ was ultra-light, I could understand some more due to a 'spirtely feel', but it's actually listed as being heavier. |
Simply handling. Same size wheels, same tyres, better suspension, more forgiving geometry.
It goes where it's pointed without having to think about it. You can take liberties with the handling, change lines partway round corners and generally mess about in a way that would have you off many bikes. Get onto a rough/uneven/bumpy road surface and twistier roads (of which there are many in the UK) and the difference is even more noticeable. It keeps both wheels on the ground at speeds and angles where other bikes do not.
The spec of the suspension is top-notch for factory fitted equipment. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| funmonkee |
 funmonkee Super Spammer
 Posted: 10:14 - 14 Feb 2010 Post subject: |
I've had a baggy (see my profile). They are great fun bikes. Brilliant in town - it's tall and light; not bad on fuel; can take a little city 'offroading' (*)
Only downside for me was the top speed. It can reach 100ish, but from 75 onwards it feels like it'll explode. Obviously it a single so that's natural Oh and other than the engine and front discs (Vmax front discs fit), it's a bugger for spares.
I bought a Speed Triple and it killed the MZ for me. The S3 is grunty, has a good top speed, is smooth and has a good riding position...
Saying that, given some spare buck$ and a bigger garage I'd buy another Baggy. They look fantastic and as Stinkwheel says VERY forgiving on corners.
HTH
(*) Kerbs, steps etc
https://i133.photobucket.com/albums/q73/funmonkee/baghira/IMG_0159.jpg ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| G |
 Posted: 10:57 - 14 Feb 2010 Post subject: |
| stinkwheel wrote: |
Simply handling. Same size wheels, same tyres, better suspension, more forgiving geometry. |
Never found a massive problem with the SV when riding on roads, but the suspension can be easily and cheaply upgraded (GSXR shok + aftermarket fork internals). I haven't found trail bike geometry to be that much more forgiving really - infact the longer travel can cause some issues with significantly changing that geometry, though it's not a big thing either way really to my mind.
| Quote: | light; not bad on fuel; can take a little city 'offroading' |
Similar weight to my GSXR, the internet tells me, not what I'd describe as light (about 50% over what I'd hope for in a big single making that power). Up-gearing my KTM a bit it'll fairly happily sit at 100mph, though a fair bit of wind of course. The GSXR will do that in first gear, which I think justifies the weight it's got .
Got a picture of my TRX with the rear wheel at the bottom of the steps and the front half way up - suspect I could have got them up properly if I didn't have 35 psi in the rear tyre! Take the GSXR over kerbs daily. Can do it at higher speeds with softer longer travel suspension, but generally wouldn't want to in town. |
 Posted: 13:54 - 14 Feb 2010 Post subject: |
On a twisty back road or a rough road, the increased effort and concentration the SV requires to do the same job would ultimately make the MZ the faster bike in practical terms.
I think what funmonkee is referring to regarding steps and kerbs is riding up and down steps and gassing it off kerbs. Speed bumps and humpback bridges also become something to look forward to on a rideout. As do mini roundabouts (and the occasional proper roundabout if nobody is looking).
If we're talking about upgrading. I bet you could do the 720cc conversion to the MZ for around the same price as a GSXR rear shock and a fork revalve. Combine that with ditching the crashbars and various bits of subframe that add loads of weight and it all of a sudden becomes a lot faster.
MotoCal used to have a 720 Mastiff demonstrator, it was totally banzai and quick enough to be worth entering in some of the local supermoto racing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| funmonkee |
 Posted: 18:20 - 14 Feb 2010 Post subject: |
I've ridden a sportbike (gsxr750) off and on steps, kerbs, speed bumps, small garage walls etc..but found the fork seals did last long; whereas the MZ just seems to naturally cope with that stuff (one garage attendant said ' cheeky! try doing that with a road bike') ...maybe due to it's WP suspension- it just was good/easy for that stuff. As for weight; I've never ridden an SV. The MZ was very light to me, but when you realise my garage at that time included a Vmax and Hayabusa amoungst others, then it was a very light bike in my experience
I rate the MZ for city riding as it's forgiving and fun. Avoid snow I fell off it. I didn't like the top speed - but it's unrealistic to expect ore from the XT engine, I think a twin is the way to go for me. I have my eye open for a superduke  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| G |
 Posted: 19:32 - 14 Feb 2010 Post subject: |
Well. Can't say as I ever bottomed the baggy out, not even in Ireland where the roads are shit.
Around a foot of travel at each end (from fully unloaded to fully compressed). I wouldn't say the suspension was soft so much as there was a lot of it. You got the impression it was extending into dips rather than compressing over bumps, if that makes any sense.
You could brake REALLY hard so you were leaning forwards over the bars yet not be doing a stoppie on account of the rear suspension still unloading. Made a god-awful clattering noise when it eventually did. Was a favourite trick to do at traffic lights. The driver sees a motorcyclists head appear in his field of view then disappear backwards again as the front suspension unloaded.
I wouldn't dream of doing shit like that on my VFR, I'd fall off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| funmonkee |
The last post was made 16 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
