| Cigaro |
 Cigaro World Chat Champion
| pepperami |
 pepperami Super Spammer
 Posted: 10:27 - 29 Jan 2010 Post subject: |
i`ve tried welding corroded joins on exhausts before , in the main it does`nt work and unless your a good/professional welder, you will end up with even less exhaust as you blow holes in it
well thats what happened to me!!!!
poke a bit of metal in the hole and wiggle it about and see how much more corrosion there is around that hole.
you may be only able to see a small part of the corrosion from the outside, but inside a lot more may be rotten. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Ichy |
 Ichy World Chat Champion
 Posted: 15:08 - 29 Jan 2010 Post subject: |
With a stick welder it would be better to plate the hole, start the arc on the patch piece and run onto the exhaust to reduce the agresssiveness and heat of the arc. You could also consider puddle welding the plate. This assumes that you can find some decent material to weld the plate to .
Another option is to get some pipe with an ID close to the OD of your exhaust. Split the pipe in half, clamp around the split, and weld the two halfs back together.
Generally not worth the trouble welding monkey metal exhausts with a DIY arc welder but if you can get your hands on a carbon arc torch then you can have a go at brazing a patch on there. |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 02:29 - 30 Jan 2010 Post subject: |
It's gonna end in tears..  |
| reggie |
 reggie Spanner Monkey
 Posted: 02:39 - 30 Jan 2010 Post subject: |
dont even try it with a stick welder you will end up chaseing holes
you could just replace the back box with a bit of pipe what car is it btw ? ____________________ when the shit hits the fan make sure its facing the other way. |
| kingsmith |
 kingsmith Scooby Slapper
 Posted: 01:10 - 31 Jan 2010 Post subject: |
by the time you have fucked around trying to weld the back box , you might as well get a new one fitted.
10 mins in an exhust place job done. i never bother with trying to fix exhaust anymore just not worth it.
so cheap now a days, well unless you have some realy expensive system. but most not so.
luck  ____________________ honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy |
| Ariel Badger |
 Ariel Badger Super Spammer
| Robby |
 Robby Dirty Old Man
| andybon |
 andybon Nitrous Nuisance
| temeluchus |
| binge |
 binge Emo Kiddy
| Ariel Badger |
| binge |
 binge Emo Kiddy
 Posted: 06:55 - 04 Feb 2010 Post subject: |
| dansrockin |
 dansrockin Scooby Slapper
There is a gap of 248 days between these two posts... |
| ZanderJay |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 ZanderJay L Plate Warrior
 Posted: 07:41 - 11 Oct 2010 Post subject: Re: Welding up a car exhaust |
If you are beginner in the welding process, it might be that you can need weld your car into other. It is for the real safe of your car. However, arc welding can be good for that problem, this will be your good choice. ____________________ My seo |
| Blue_SV650S |
 Posted: 10:21 - 11 Oct 2010 Post subject: |
Give it a go ... I always figure 'gotta be worth a try'
Here is my latest arc-magic ...
https://www2.bikechatforums.com/viewtopic.php?t=202880
I have also repaired minimoto expansion chambers (split down the join). Again, not pretty, but it works ... just make sure you have some thin rods. ____________________ The purpose of life is to fight maturity. |
| Blue_SV650S |
| kawakid |
 kawakid World Chat Champion
| binge |
 binge Emo Kiddy
The last post was made 15 years, 325 days ago. Instead of replying here, would creating a new thread be more useful? |
