Gilera Cougar choke,and cuts off on low revs
vcrmoss
PostPosted: 19:51 - 01 Feb 2010    Post subject: Gilera Cougar choke,and cuts off on low revs Reply with quote
How you doin everyone?
So i just got 2001 Gilera Cougar 125cc and as a result of being slightly over excited i forgot how to operate choke lever on it.I believe that when the lever is up facing forward its on and off when pushed down.Is there anyone who could reassure me on this?
Secondly it annoys me when it cuts off every time i let it go idle.Any suggestions on that...should I start by cleaning the carburetor or is it consequence of the above (wrongly set choke)....
cheers
Lukaz2205
PostPosted: 17:38 - 09 Feb 2010    Post subject: Reply with quote
what you need to do is get a carb off a Honda CG125.
they use the City Fly motor which pretty much a CG with different gear ratios.
the carbs used are pretty cack, soon as you stick that carb on you'll be fine.
also keep an eye out for no power when you throttle, this is due to the needle getting ground down by the retaining W clip and dropping it into the hole and just doing nothing at all but have a rough tick over.
also keep the spokes adjusted properly as the hub can wobble and make you crash into a hedge if not looked at.
1st....2nd....3rd....4th.....into 5th......6th field and stopped in a heap!
crackpotterpi...
PostPosted: 18:29 - 09 Feb 2010    Post subject: Reply with quote
my g/f has a gilera cougar,you pull the choke lever up to put it on,try adjusting the idle screw its on the right hand side of the carb at the bottom after you get it warm try adjusting it Smile
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
Lukaz2205
PostPosted: 14:26 - 12 Feb 2010    Post subject: Reply with quote
the problem is though, when you do adjust it, it will eventually make little difference as it will eventually not want to tighten anymore.
Odie
PostPosted: 18:08 - 12 Feb 2010    Post subject: Reply with quote
The cougar carb is fine as it is, yes, up is choke on, down is off.
As for not ticking over, you say you have turned the tick-over screw in and it do nothing.... is the slide in the right way round, has been known!
Where are you?
vcrmoss
PostPosted: 20:49 - 06 Mar 2010    Post subject: Reply with quote
...cleaned the carb now and its certainly in need of proper adjustment,which gives me a little bit of a headache.I played with the idle screw but after changing the spark plug i have noticed that the engine is running way too rich. Im am not sure how to adjust it properly to make air/fuel mixture correct,which i believe would solve the problem.
Secondly after refitting the carburettor I found that there is no spring on pilot screw which seems to be present on every type of carb on this type of engine (Honda CG) .Guessing its missing and will possibly need to get hold of one then.However im not sure about this as engine manual is for Honda CG not Gilera Cougar.
Hence the important question: do all pilot screw have springs???
Odie
PostPosted: 23:27 - 10 Mar 2010    Post subject: Reply with quote
What info do you need on the engine?
I have a paper copy of the manual, can scan, pm me if interested, also yes there should be a spring.
odie
vcrmoss
PostPosted: 23:44 - 10 Mar 2010    Post subject: Reply with quote
odie
Odie thnks for reply.I just got new set of jets and pilot jet with a spring and will be fitting it on Friday.Im currently using Honda CG manual,seems that everything is almost exactly the same (at lest could not see any diffrences in carb section)Do you have one for Gilera?
Im new to the game and loving it Big Time......... current ride: Gilera Cougar 125 (cruiser style Italian Honda CG)
The last post was made 15 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 58.12 Kb
