Pinlock - still misting
Blue_SV650S
PostPosted: 18:37 - 03 Feb 2010    Post subject: Pinlock - still misting Reply with quote
I have pinlock, and still get a silly amount of misting ...
Does anyone else suffer from misting even with pinlock? Thinking
Am I supposed to take the pinlock off every now and then and clean it with say soapy water to get rid of any built up grime/grease?!?! Thinking
TUG
PostPosted: 19:11 - 03 Feb 2010    Post subject: Reply with quote
Mine does but its cos moistures been under it you have to tighten the pins up to make it sit right an seal too.
Haz ER-5, innit!
Oliver_FF
PostPosted: 19:14 - 03 Feb 2010    Post subject: Re: Pinlock - still misting Reply with quote
I've found that after 6 months of getting a new visor+insert the thing does start to fog up a little but only in excessively cold temperatures and only in the bottom-middle of the visor. Open some air vents and it should go away Wink
Happened on my original cheapo ?90 Lazer helmet, ?300 Shoei Multitec and current ?450 Schuberth C3. I can only assume it happens with every other helmet going...
Current bikes - 2001 CBR600F, 2007 CBR1000RR Fireblade
Previous bikes - '05 CG125, '97 CB500, '06 CBF600S, '04 ZX-6R, '07 Ducati 749
Pickledswede
PostPosted: 19:20 - 03 Feb 2010    Post subject: Reply with quote
I get this aswell, a big blob right in front of one of my eyes at the bottom or top normally. More of a problem than normal mist cause you can't wipe it away and it's only in front of one of your eyes, fucking up depth perception.
I find that opening your visor and making sure the pinlock is pushed firmly against the visor top and bottom before setting off helps alot.
But if I've ridden in the morning and leave wet gloves in my helmet (no other space in my locker) it often mists up more on the way home. It's hard to adjust the pins to make it fit better cause I have to take the pinlock out to adjust them and really have no idea whether twisting this way or that makes any difference, it always slips down over time anyway letting moisture in, so best just to squish it against the visor before setting off each time!
sickpup
Old Timer
PostPosted: 19:57 - 03 Feb 2010    Post subject: Reply with quote
Learn to breathe through your nose Wink
TUG
PostPosted: 21:42 - 03 Feb 2010    Post subject: Reply with quote
I do and it still mists up but tbh its because of how cold it is of late, its ridiculous.
Haz ER-5, innit!
neil.
PostPosted: 21:55 - 03 Feb 2010    Post subject: Reply with quote
You just need to make sure that the seal between the pinlock and your visor is good all the way around, which can be really tricky, but you'll get there in the end - the pins are a funny shape and you can twist them so they push the seal down properly. I've found that removing and washing it every once in a while with soapy water really helps. Just be careful as they scratch really easily - I ruined one as I used the wrong side of a sponge (scouring pad bit) by accident. Embarassed
Seb
PostPosted: 22:11 - 03 Feb 2010    Post subject: Reply with quote
+1 on the above. Wash it, stick it back in the pins and adjust them round so that the seal is fairly tight and won't move easily, don't over do it though as you can actually mark the inside of your visor eventually.
Some visors seem to seal better than others though, the stock clear visor my arai came with was terrible and never really wanted to seal right whilst my dark tint was almost impossible to mist up (although the pinlock stuck so well it scored the inside of the visor near the top much to my surprise), I recently got one of the new max vision visors which works perfectly though, plus I don't get the top of the pinlock obscuring my sight at times Thumbs Up
2010 Triumph 1050 Sprint ST
PostPosted: 22:12 - 03 Feb 2010    Post subject: Reply with quote
My brand new pinlock fitted to a brand new visor by a qualified Arai service person misted up first time out.
And that's misting on the inside of the pinlock, not between the visor and the insert in an Arai condor with all the vents open and the visor in the "cracked open" position. Still landed up riding half the journey home with the visor open.
It was all a bit shite really. I was expecting to be able to ride with my visor closed during the winter for the first time in my life and it didn't happen.
I wont be buying another one when this one is dead, it makes things slightly better but not ?20 worth of better.
Flip
PostPosted: 23:56 - 03 Feb 2010    Post subject: Reply with quote
https://www.pinlock.be/documentbank/InsPFFS10.pdf
Pinlock visors are over rated. Mine went in the bin. Thumbs Up
TheDonUK
PostPosted: 01:12 - 04 Feb 2010    Post subject: Reply with quote
I agree, All the hype about pinlock is very overrated. It came with my multitec but was rubbish, i threw it away.
The only working solution is a Fog City Insert, but they only last about a year or so.
Serendipity
PostPosted: 09:16 - 04 Feb 2010    Post subject: Reply with quote
It?s weird that Pinlock generates such a stark love / hate contrast.
I definitely fall in the love camp. I spent over ten years commuting with pollution masks to try and minimise fogging. In 2006 I bought a new Shoei XR1000 that came with a free Pinlock insert and it was a complete revelation. That winter my riding was transformed. I could see!
Some peripheral vision is lost as the unprotected bits of visor round the edge of the Pinlock easily mist up, but the main bit of Pinlock stays resolutely clear. The only time it ever fogged up at all was while riding in the recent snow and even then it wasn?t too bad.
I don?t go near it with soapy water. I clean the outside of the visor while it?s on the helmet then pop the visor off to wipe the inside with a damp cloth. I may remove the insert once every six months, especially in the summer to soak off layers of bugs, but otherwise it stays put. I have a clear visor with a clear insert and a dark visor with a clear insert. Both have been 99.9% reliable and have now lasted over three years.
There?s nothing different about the way I breathe. Trust me, I?m a mouth breather with almost bovine levels of hot, wet halitosis, but I can still see where I?m going.
I never have to lift my visor at traffic lights and I?ve become averse to riding with my visor open because it makes my eyes water.
I can?t comment on rival makes because I haven?t tried them, but I bet they're just as effective. I seriously recommend giving them another chance, especially if you ride in cold, wet weather.
Edited for spelling
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
supZ
PostPosted: 12:01 - 04 Feb 2010    Post subject: Reply with quote
+1 to Serendipity
pinlocks great, never have any problems really. only one i had recently was i took the insert out of my helmet after it being in there for over a year to clean it and it had gotten used to being bent like that for so long that it wouldnt seal again.
bought another insert and its back to being perfect again
in the meantime im bending the old one back the other way to reuse when i need it Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
salty21
PostPosted: 16:59 - 04 Feb 2010    Post subject: Reply with quote
my visor rarely fogs up and it's only a standard thing with no inserts or anything. I found that if you push your top lip out past your bottom one and exhale that way so your blowing down, out the helmet it stops it. Seems like a bit of a faf but after a while you dont even realise your doing it, just becomes second nature.
The only time i do have problems it when its really foggy in the countryside and the inside of the visor get's wet aswell Confused
Blue_SV650S
PostPosted: 18:23 - 04 Feb 2010    Post subject: Reply with quote
Yep, it is an Arai and like you, even when ajar and vents open it mists like feck Thumbs Down
To be fair I have had exactly the same problems with 'fog city', so I don't think the problem is limited to pin-c-o-ck design ...
I'll whip it off and give it and the visor a wash ... at least you can do that with one of these!! Thumbs Up
PostPosted: 18:47 - 04 Feb 2010    Post subject: Reply with quote
But Pinlock is the better of the anti-fog systems isn't it?
There is probably a BCF Poll somewhere.
Biggest problem i have is water droplets/spray staying on the outside of my visor. I've tried lots of sprays. Yes it does clear if i'm doing +50mph and i turn my head abit. I think it was G who said get one of those finger-wipe things.
Soz for busting in your thread Blue_SV650S, but this mist on the outside of my visor is a real problem of late.
Pat
Blue_SV650S
PostPosted: 19:00 - 04 Feb 2010    Post subject: Reply with quote
G is right, the outside of the visor is easy ...
https://www.hein-gericke.co.uk/shop/product_info.php/products_id/6553
https://www.hein-gericke.co.uk/shop/images/HG%20Visor%20Wipe500.jpg
Very simple idea, but totally changed my biking life that product!! Thumbs Up
Pickledswede
PostPosted: 19:07 - 04 Feb 2010    Post subject: Reply with quote
Just realised how much of an idiot I am. Took the visor off and had a proper look at the pins, turns out the pointy bits don't have to point any particular direction, and they visor is much tighter if they're pointing outwards... Whereas I'd thought they could only be adjusted within 180 degrees and must stay pointing inwards. Why? No idea.
Anyway now I've pointed them outwards and the visor is very tight, so hopefully should stop moisture getting in...
On the topic of the outside of the visor I just wipe it away with a finger, doesn't have to have a wipey thing and your finger will curve better to the visor without one I think, making it a broader wipe! If it's raining your gloves will be wet anyway so no problems making them more so. Obviously this leaves a bit of residual moisture on the visor but it doesn't tend to bother me too much, I just wipe it occasionally!
nasty
PostPosted: 19:23 - 04 Feb 2010    Post subject: Reply with quote
I bought a new Pinlock ready visor and Pinlock insert for my AGV Ti-Tech back in October.
It has never misted/fogged up so does the job but when I removed the insert to clean it the other day most of the silicone beading from the top part of the insert had fused to the inside of my visor, the insert simply came away from it.
Give it the visor a clean but left the silicone in place on the visor and put the insert back in - still works a treat but not happy that the silicone beading degraded in the way it has over the last 4 or so months Sad
I had a Fog-City Hyperoptiks on another helmet which was just as good Thumbs Up
Incidently the original flat race visor that comes with the Ti-Tech is also very good at not fogging.
ZX6R F3
Charlie
PostPosted: 20:29 - 04 Feb 2010    Post subject: Reply with quote
https://www.nippynormans.com/INSTANT-VISOR-CLEANER/productinfo/NNP%2DVC50/
I'd say that is better if you aren't arsed about what it looks like... Could be worth connecting the lid to the base via string so you can drop it by mistake. My Dad loves his.
nasty
PostPosted: 20:38 - 04 Feb 2010    Post subject: Reply with quote
These do the trick for me, rubber blade on the first finger of the left hand, works great.
https://www.hein-gericke.co.uk/shop/product_info.php/cPath/6_149/products_id/3702
ZX6R F3
Flip
PostPosted: 22:25 - 04 Feb 2010    Post subject: Reply with quote
That's just a box with a sponge in it. Laughing People pay ?15 for that? Laughing
I'm happy with my free V sponge that I keep under my seat for visor cleaning. Those visor wiper things that Blue posted are very good. I have two, Shame I can't find the fcukers. Sadly neither of those products are good for misting. Best thing for misting is to keep the visor open one click and man up tbh.
Charlie
PostPosted: 22:35 - 04 Feb 2010    Post subject: Reply with quote
But if people are lazy and can't be arsed to make a mounting braket, find a box and attach a sponge; then they will pay ?15 for it.
clicky
That stuff works but gets washed off quite easy, if your planning a long run it could be worth putting some on. Don't flip your visor up when its raining to try and save it.
PostPosted: 23:00 - 04 Feb 2010    Post subject: Reply with quote
My solution to that is don't ride in the rain Laughing
The last post was made 16 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 135.82 Kb
