triumph tt600 starting problems part two!!stator replacement
stevekingchef
PostPosted: 13:27 - 05 Feb 2010    Post subject: triumph tt600 starting problems part two!!stator replacement Reply with quote
hi guys
cheers for reading my post
well it all started a good time ago.my bike was not starting and died.
after much help from here i changed the regulator rectifier and all the wiring due to it being fried.
the problem has come back again.
here are the current symptoms
bike refusing to start all system primes up but zero activity.
bump started fine so every now and then bike dies(not while riding)if turn off come back and it just wont start.
now the bike doesnt want to bump start at all??
i changed the clutch switch but this seems to make no difference.
last night i charged my spare battery put it in and starter moter was turning over but not starting the engine?strange never had any problems starting before well when starter kicked in.
came back to bike today nothing at all.
im completly lost as to what to do.
could i need a new stator?new starter motor?loose connection in wireing?take it to dealer(god know how to get it there)and prey they done take all my cash!!
any help or ideas is great as i dont want to throw money at stuff as im not flush with cash.
PostPosted: 13:58 - 05 Feb 2010    Post subject: Reply with quote
Could be any number of things. You need to know if it is sparking for a start.
When cranking over does the rev counter move? If so then it suggests it is getting a signal.
Looking at the wiring diagram it looks like the clutch switch prevents the starter from working, but the side stand switch isn't clear. I would guess that it cuts out the ignition. As such I would check that this is working OK.
stevekingchef
PostPosted: 14:13 - 05 Feb 2010    Post subject: Reply with quote
hi kickstart.
if i understand you correctly you think it may be the side stand?
how would i check this.
i am off to the shops to buy a multimeter now but have no idea how to use it.
i cant see that two clutch switchs are bad.im also charging the battery that fired it up and gonna put that back in.
thanks for your speedy reply kickstart your a ledgend!!
stevekingchef
PostPosted: 14:16 - 05 Feb 2010    Post subject: Reply with quote
hi kickstart
also when it was turning over the rev conter was moving slightly and coughing and spluttering.now theres nothing at all!!
PostPosted: 14:17 - 05 Feb 2010    Post subject: Reply with quote
That it is cranking over suggests the clutch switch is OK. Not firing could be the side stand switch.
However not sure if you are saying that having charged the battery and left it on the bike overnight there are no signs of life (ie, not even a neutral light). If so then that suggests something is shorting to earth and flattening the battery.
stevekingchef
PostPosted: 14:29 - 05 Feb 2010    Post subject: Reply with quote
hi sorry for my vaugness.
there is power on the bike lights speedo all work system primes up when turn on ignition but pull the clutch hit start and nada nothing.
PostPosted: 14:49 - 05 Feb 2010    Post subject: Reply with quote
If the battery was flat then the lights might be dim and you would probably get a click from the starter relay when you tried. No click suggests the battery isn't the problem.
Basically the starter and ignition are fairly seperate.
The starter just needs to dump a load of power to the starter motor. This comes directly from the battery via the starter relay, and then to the starter motor. The starter relay is basically just a big electrically operated switch. 2 big wires and 2 small wires, with the small wires being there to operate the relay. On the TT600 of the 2 small wires to the relay, one goes to earth via the clutch switch (so to count this out from being the problem you can just disconnect it and short the contacts) while the other comes from the starter button. It also triggers the headlight cutout relay, so if the starter button is working I would expect the headlight to switch off while you try and start the bike.
Ignition wise is a bit more complicated (and the wiring diagram isn't that great). Looks like fuse number 6 feeds power to the coils and to the injectors (brown / pink wire). These appear to be controlled by the ECU (along with controlling the fuel pump, etc). The injection system has a chaptor of the manual to itself!
stevekingchef
PostPosted: 15:25 - 05 Feb 2010    Post subject: Reply with quote
thanks so much Keith
im off to work shortly but will check the starter button as you suggested and will try to start with the cluth switch disconnected many many thanks its one hell of a nightmare
english engineering best in the world
steve
stevekingchef
PostPosted: 15:41 - 05 Feb 2010    Post subject: Reply with quote
hi keith
just checked and the light does not go out flash off like it normally does!!
i also unplugged the clutchwire but i think u meant im meant to short this which i didnt!!
so i guess the next move is to get hold of a starter button??
thanks so much for your help these past few days i really lost hope with the bike and as my only mode of transport i was panicing loads!!
you have calmed me down loads
cheers
steve
PostPosted: 15:45 - 05 Feb 2010    Post subject: Reply with quote
Yes, you need to short out the clutch switch, not just disconnect it. Basically when you pull the clutch it connects up the earth side for the starter relay.
If the headlight isn't turning off then that suggests that the starter button isn't providing any power. With luck just a dirty contact in the switch.
stevekingchef
PostPosted: 14:23 - 12 Feb 2010    Post subject: Reply with quote
hi
finnally got time to put in new starter button today and its not that!!
if anyone has a idea where to go from here ???
cheers again from a frustraited tt owner!!
steve
The last post was made 15 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 71.84 Kb
