| Ichy |
 Ichy World Chat Champion
| Alexio |
 Alexio World Chat Champion
 Posted: 00:05 - 06 Feb 2010 Post subject: |
Wouldn't you use one of those electromagnetic switches?
https://en.wikipedia.org/wiki/Reed_switch
The voltage could power an electromagnet which closes a circuit - that circuit could either short circuit the LED or you could use a small NOT logic gate I suppose?
Either way, when voltage is low enough you'd not be able to power the magnet. I'm in no way an electrician and know pretty much nothing about electrics but this was the first thing that came to my mind and how I might attempt this problem. I'm sure there's an easier way to do it though? ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| Fortuna |
 Fortuna World Chat Champion
| Tango675 |
 Tango675 Crazy Courier
| Ichy |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 17:41 - 06 Feb 2010 Post subject: |
I'm guessing the sender is a variable resistance type, rather than a switch. You could alter this circuit, replacing the phototransistor with the sender, and the 1K resistor with a variable one, so you can set the sensitivity. You'll probably want a dropping resistor inline with the LED, seeing as it'll be 12v, not 3v
https://www.evilmadscientist.com/article.php/nightlight
Problem would be smoothing the output, otherwise every bump you went over would leave it flashing. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Ichy |
 Posted: 18:00 - 06 Feb 2010 Post subject: |
| carvell |
 carvell Scuttler
| Ichy |
The last post was made 16 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
