cbr125 again
chip
PostPosted: 16:05 - 07 Feb 2010    Post subject: cbr125 again Reply with quote
rite erm i leave bike idleing for 10 mins, i notice lights seem very dimm, so i give bike a rev and is heavily miss fireing,
bike dont start up again, seems to me like a flat battery , maybe not charging up but would a flat battery cause a miss fire?
so anybody have an idea where there rectifier(charger thingy) is on these lol
i am also looking into changing the coil pack as iv heard these are a common thing on these
so all comments welcome
cheers
PostPosted: 16:08 - 07 Feb 2010    Post subject: Reply with quote
spark plug??
recharge the battery if its not showing the correct voltage.
Alexio
Yes, flat battery can cause a mis-fire because your bike won't spark properly or with a strong spark which could sometimes dump fuel in to your exhaust to be ignited there on a different stroke of the engine. I think.
Or am I just thinking of a backfire? I think misfire is where the fuel ignites at the wrong time, probably also a spark plug issue. Try the plug.
chip
PostPosted: 16:15 - 07 Feb 2010    Post subject: Reply with quote
wel iv gota look into why the battery aint charging propperly , sort that and then i wil definatly go get a shiny new plug and a coil pack,
chip
PostPosted: 18:09 - 07 Feb 2010    Post subject: Reply with quote
have just managed a quick test on battery and it dont seem to be charging so looks like im after a new rectifier and hopefuly all will be fixed
anyone any suggestions on anywhere in bolton for spares?
PostPosted: 22:38 - 07 Feb 2010    Post subject: Reply with quote
try a new battery??
might not be the regulator, where abouts are you, ive got 3 batteries for the CBR... just so happen to be the same as my other 125's.
My GS500 started to have a crap spark on the way back from Peterborough, ended up broken down in essex as my battery wasnt charging.
Turned out to be a fuse, just was so dirty it didnt make contact!
chip
PostPosted: 00:12 - 08 Feb 2010    Post subject: Reply with quote
iv used a bosch tester on the battery from work which basically is coming up 91% cold start capacity (minimum 74%) and states "good battery"
but cant get a reliable charge rate from the tester as with this tester you are suppose to test with no electrics on whatsoever do test 1 and the switch all lights on and do test 2 so it can check the load but as the lights are always on i dont 100% trust the results,
its just come to me, i will unplug the front lights tomorrow and repeat the charge rate test
will update when iv done the test
chip
PostPosted: 14:21 - 09 Feb 2010    Post subject: Reply with quote
phh right gota another regulator and i still have same problem. im going to try and see if i can get hold of another battery to try , other than that any other suggestions to what can cause the battery to not charge up?
PostPosted: 14:27 - 09 Feb 2010    Post subject: Reply with quote
battery could just be crap, they do happen to do that... mine happened over a weekend Sad
Where are you based? ive got 2 or 3..
I'd say battery though...
chip
PostPosted: 14:48 - 09 Feb 2010    Post subject: Reply with quote
im in bolton mate
looking at the wireing diagram theres 3 yellow wires going to the actualy alternator, is it possible a wire could come loose?
ino the alternator is inside the left engine case but like a car is belt driven, are these chain driven or just work off friction or sumat?
The last post was made 16 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 62.49 Kb
