cagiva mito USD forks. need some help
steven_191
PostPosted: 18:37 - 07 Feb 2010    Post subject: cagiva mito USD forks. need some help Reply with quote
i got these gold USD forks. not sure what make they are although they do have the cagiva elephant stamped on the bottom but someone mentioned they may be Marzucchi? something like that.
anyway. i took them off today and one of them feels as if there is no spring in it. i have been told before that one fork deal with bound and the other rebound which would explain it. but then i wouldve thought that for uprated forks they would be just like the rest?
anyone know if this is correct? heres a picture. well there would be a picture if it worked....
steven_191
PostPosted: 18:54 - 07 Feb 2010    Post subject: Reply with quote
crap. didnt think its was right.
steven_191
PostPosted: 18:58 - 07 Feb 2010    Post subject: Reply with quote
the forks look like these
https://cgi.ebay.co.uk/CAGIVA-MITO-125-FRONT-SUSPENSION-FORKS-FORK-LEGS-LEGS_W0QQitemZ260549724410QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3ca9f948fa
anyone know who makes them so i can work out if where need parts from?
steven_191
PostPosted: 23:27 - 25 Feb 2010    Post subject: Reply with quote
my forks
PostPosted: 23:35 - 25 Feb 2010    Post subject: Reply with quote
I told you just take them apart and see if the other springs are similar.
steven_191
PostPosted: 23:52 - 25 Feb 2010    Post subject: Reply with quote
sugar tits my arse. moobs
Adrian89
PostPosted: 00:35 - 26 Feb 2010    Post subject: Reply with quote
I can confirm that one fork leg definitely inst meant to have a spring in it so you are ok, it sounds weird I know, but look in the manual.
Those forks are off a mk2 mito, the same as my old bike.
That's how they are meant to be believe it or not.
History: x8r-x 50cc, Mito mk2 125cc, NC23-RRJ 400cc
Present: NC23 RRK 400cc x2, Rothmans and Urban Tiger
PostPosted: 00:44 - 26 Feb 2010    Post subject: Reply with quote
Vincent wrote:
Nope, both forks are the same. Someone is either pulling your leg, or you're trying to pull ours.
The Marzocchi forks on the early RS250s did have different functions on each side. I think there was a spring in one side, with damping stuff in the other, but oil in both sides. It's not that common on motorbikes, but where weight's more of an issue on mountain bikes it's very common.
Because they're well clamped, it shouldn't be an issue having each leg do a different thing.
MaybeGuy
PostPosted: 08:02 - 26 Feb 2010    Post subject: Reply with quote
sell me those forks now!!!
Ill swap them for a pair of mito evo forks that have the same amount of springyness in each, or cash.
Its for a good cause
steven_191
PostPosted: 19:54 - 26 Feb 2010    Post subject: Reply with quote
sell them? are they that good?
i dont actually have any manuals but i found a pdf online
https://www.marzocchi.co.uk/documents/techinfo/CAGIVA%20MANUAL.pdf
thats as close to my forks as i have found. are these ones supposed to be any good then?
also, what oil should i use?
MaybeGuy
PostPosted: 20:09 - 26 Feb 2010    Post subject: Reply with quote
not good, just i need them, and theyre hard to come by. the ones i have have got pitted stanctions and are pretty much useless.
PostPosted: 20:12 - 26 Feb 2010    Post subject: Reply with quote
ABE do replacement stanchions. Although it would come to close to £200.
MaybeGuy
PostPosted: 20:13 - 26 Feb 2010    Post subject: Reply with quote
yeah, i looked into it. i wont be doing that though.
my options at the moment are to mill the evo forks so the wheel fits in line.
steven_191
PostPosted: 20:28 - 26 Feb 2010    Post subject: Reply with quote
check around ebay. there were quite a few on there last week. i was going to buy a pair to replace these if it turned out i had knackered internals.
steven_191
although this has ended, there were no bids, so maybe worth a go
https://cgi.ebay.co.uk/cagiva-mito-125-marzocchi-front-forks-spares-parts/300387776132
MaybeGuy
PostPosted: 20:29 - 26 Feb 2010    Post subject: Reply with quote
theyre from an evo
steven_191
PostPosted: 20:41 - 26 Feb 2010    Post subject: Reply with quote
i dont really know the difference in fitment. good job i havent bought anything else.
wheres the best place to get oil seals for these? and apart from seals and oil, is there anything else i should be replacing? or does it depend on whats worn out?
The last post was made 16 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 99.25 Kb
