Guess what this is
hayling1984
PostPosted: 16:43 - 08 Feb 2010    Post subject: Guess what this is Reply with quote
Can you? I'm pretty sure I know what this is...
PostPosted: 16:44 - 08 Feb 2010    Post subject: Reply with quote
Looks like ice to me.
PsychoHippy
Jammy Git
PostPosted: 16:47 - 08 Feb 2010    Post subject: Reply with quote
I agree with ms51ves3, it looks like carb icing.
I spend all my money on bikes and beer, the rest I simply waste!
hayling1984
How about now?
https://i45.tinypic.com/ay2cli.jpg
PostPosted: 16:50 - 08 Feb 2010    Post subject: Reply with quote
So your fuel has frozen? Or has some water got in your tank and frozen at the bottom stopping any petrol getting out.
Where are you anyway? It's not even that cold here any more.
hayling1984
PostPosted: 16:53 - 08 Feb 2010    Post subject: Reply with quote
or if something has leaked onto it and evaporated.
This is what I thought, turns out there was no jubilee clip on the fuel line on this bike. Uncover it this morning to start work and bam
Just outside Brighton, it's actually snowing outside now.
smegballs
PostPosted: 17:13 - 08 Feb 2010    Post subject: Reply with quote
I had this on my MZ fuel tap one day.
Petrol was leaking out from the water trap bowl lip and running down the fuel line.
My thinking is that as the petrol evaporates it is working as a very effective refrigerant and cooling down the carb body well below zero. Thus the moisture in the atmosphere condenses on the cold carb leaving a pretty ice pattern.
I'm pretty sure its not got much to do with ambient temperatures being below freezing as when the MZ froze it was a cold (but nowhere near freezing) day. When I got hope and noticed the leak I duly turned off the fuel tap (to save fuel being wasted) and as soon as the flow of cooling petrol stopped the ice soon melted Crying or Very sad
The Artist
PostPosted: 17:36 - 08 Feb 2010    Post subject: Reply with quote
I think it is salt.
Only one way to find out.... lick it.
Carl_steveo
PostPosted: 18:13 - 08 Feb 2010    Post subject: Reply with quote
Ermmm......Ermmm .....I know this one.
It's ermmm a coral reef growing on your carb. Theres an eel in the second picture.
Current: Honda Nsr 125
Live: Sunderland
DrDonnyBrago
PostPosted: 22:09 - 08 Feb 2010    Post subject: Reply with quote
as someone said, fuel systems can get pretty cold due to evaporative cooling - had a banjo fitting iced up last time I pulled my tank
Easy test - does it melt when you touch it?
yes = ice
no = salt
Ah and carb icing refers to ice forming on the inside of the carb due to the drop in pressure around the venturi and the evaporating fuel.
buddy
PostPosted: 11:05 - 09 Feb 2010    Post subject: Reply with quote
so when aluminum furrs up its actualy salt?
so you could get that off with just warm water instead of with a wire brush maybe?
When this baby hits 88 miles per hour... you're gonna see some serious shit.
MaybeGuy
PostPosted: 11:41 - 09 Feb 2010    Post subject: Reply with quote
your head gaskets blowing
The Artist
PostPosted: 14:35 - 09 Feb 2010    Post subject: Reply with quote
When aluminium furs up it is alu oxide, the white powdery stuff.
Ice melts when heated so try melting it with your finger.
If is hard a sharp crystal like and doesn't melt it is salt.
truslack
PostPosted: 15:17 - 09 Feb 2010    Post subject: Reply with quote
Frozen petrol, my MZ often freezes like that.
smegballs
PostPosted: 15:33 - 09 Feb 2010    Post subject: Reply with quote
What is it with MZ's and strange occurrences eh? Laughing
PostPosted: 18:27 - 09 Feb 2010    Post subject: Reply with quote
That's the result of a fuel leak - fix the leak and it will stop.
hayling1984
PostPosted: 17:55 - 12 Feb 2010    Post subject: Reply with quote
tip of the ice burg Razz
robocog
PostPosted: 18:14 - 12 Feb 2010    Post subject: Reply with quote
Icing fuel
Hopefully have attached a pretty picture of mine doing similar when I neglected a slight leak this winter..
Pretty isn't it?
Regards
Rob
Needs a bigger garage...
smegballs
PostPosted: 18:20 - 12 Feb 2010    Post subject: Reply with quote
Well its not the fuel freezing straight up, I don't know how cold it would have to be to freeze petrol but I'm sure it would be at least -25 degrees, probably colder.
Its the cooling formed by the petrol evaporating.
robocog
PostPosted: 18:25 - 12 Feb 2010    Post subject: Reply with quote
I guess that could also explain why it makes furry/spikey patterns radiating out from the source of the leak rather than just hanging down (due to gravity) in a frozen icycle type affair
On mine it also wouldn't shock me if there was guite a high water content in there as well as fuel...LOL
Regards
Rob
The last post was made 15 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.35 - MySQL Queries: 13 - Page Size: 102.16 Kb
