carb balancers ,, anyone in stockport willing to lend a set
BrianZXR
PostPosted: 00:01 - 09 Feb 2010    Post subject: carb balancers ,, anyone in stockport willing to lend a set Reply with quote
im in stockport , honest and in need , please !!!
el_oso
PostPosted: 03:25 - 09 Feb 2010    Post subject: Reply with quote
make one yourself. get down to b&q and buy 2-3 meters of hose and fill it with liquid. oil works a bit better as it is heavier than water
see diagram. no need for extra fuel tank. engine should only be running at tick over for a minute or so, so the fuel in the lines should sufice.
when all the liquid is at equal levels balancing is done
see pic
https://members.optusnet.com.au/~macmanmike/manometer/ManometerK100RS.jpg
Duke 390
Car: Jeep Wrangler 4.0L
BrianZXR
PostPosted: 22:14 - 09 Feb 2010    Post subject: Reply with quote
Really appreciate the pic and maybe im thick but whats going on at the bottom ,the joins ,got pro 4 oil ,will get the tubing , got clips and can get wood , how do i make it ? how does it work ? im up on everything else but not used or made one of these before , your a star for the pic tho , thanks
Noxious89123
PostPosted: 23:09 - 09 Feb 2010    Post subject: Reply with quote
Basically, the oil sits in the bottom of the lines. When the engine is running and the hoses are connected to the vacuum lines, the oil will move. You need to get it so that the vacuum is the same for each carb, so the oil sits at the same level in each tube.
BrianZXR
PostPosted: 23:10 - 09 Feb 2010    Post subject: Reply with quote
arh , just had a good look at pic , i understand now , thank you very much for the pic and i will be doing it tomorrow , superstar !! cheers
Noxious89123
PostPosted: 23:42 - 09 Feb 2010    Post subject: Reply with quote
Just make sure that the lines are quit long, and that there is plenty of weight in fluid in there.
If the lines are too short, or too little fluid, It could get sucked up the vauum lines and into the carbs. And make sure there are no air leaks either, it needs to be a closed loop.
The last post was made 16 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 48.43 Kb
