Carb issue.
st3v3
PostPosted: 02:07 - 09 Feb 2010    Post subject: Carb issue. Reply with quote
I've lost the bolt that screws the petrol pipe lug thing onto the side of my carb, I can't find a replacement online and can't get to the shop to get a new one, since the carb is firmly fastened back in the bike and it's taken me 3 weeks to get it back in there. Laughing
Ideas?
hmmmnz
PostPosted: 02:21 - 09 Feb 2010    Post subject: Reply with quote
what bike is it???
the humans are dead
I kick arse for the lord
alun111
PostPosted: 02:38 - 09 Feb 2010    Post subject: Reply with quote
3 weeks?!
If it's what I'm thinking of it's called a "spigot", not sure if this will help your search at all.
DrDonnyBrago
PostPosted: 10:52 - 09 Feb 2010    Post subject: Reply with quote
What bike is it and where in the UK are you?
truslack
PostPosted: 12:48 - 09 Feb 2010    Post subject: Re: Carb bolt thingy Reply with quote
Ideas?
Is it a dellorto carb? If so, Isn't it just an M8 bolt and a small gasket or O ring?
st3v3
PostPosted: 02:38 - 11 Feb 2010    Post subject: Reply with quote
Sorry chaps, I presumed since I've had one bike for 3 years and banged on about it some might have remebered at some point. Laughing
I've got a bolt for it now, yes Mark it is a Dellorto. My problem is now that I'm missing some seal thingy instead, I got a bolt from B&Q after much size comparing and being stung hard(robbing cunts).
I've got it all tightened up etc, but whe I turn fuel tap on it leaks... it leaks with so much that there's no fuel getting through the carb.
It's a Honda NS125R, I'm near Leeds and it's pissing me off.... again. Mad Laughing I might be able to get something bodged for it tomorrow, if not il be after more inspiration cos getting hold of a seal for a carb isn't a everyday task. Eh?
DrDonnyBrago
PostPosted: 10:29 - 11 Feb 2010    Post subject: Reply with quote
Try sending the service dept of www.fowlers.co.uk an email or give them a ring, they stock/source parts for loads of bikes esp Honda.
Or, email david silver spares, they're pretty good too
truslack
PostPosted: 10:45 - 11 Feb 2010    Post subject: Reply with quote
If it's the seal around the bolt, an O-ring with a 7-8mm inside diameter should do.
hayling1984
PostPosted: 18:45 - 12 Feb 2010    Post subject: Reply with quote
Is this close to your problem? Would I be right in thinking jubilee clip will do?
baldy
PostPosted: 19:15 - 12 Feb 2010    Post subject: Reply with quote
It uses a fiber washer to seal, not a o-ring. What happened to the original?
I have one on a knackered nsr carb. Its just a m6 bolt with a little washer.
You can get the fiber washers from maplins i think, they use the same kind of thing to insulate mother boards.
One day i will rule the world, just not today.
PostPosted: 20:16 - 12 Feb 2010    Post subject: Reply with quote
Failing Maplins, suspect Halfords will have a box of assorted fibre washers for not a massive amount.
st3v3
PostPosted: 23:24 - 12 Feb 2010    Post subject: Reply with quote
It's not quite like in the pic above, it's a seal about the size of say, a 1 pence peice and as said, seals the fuel pipe connector as it bolts to the side of the carb.
It's the same as the bit on this, to the left of each carb..
https://www.alfa-pages.co.uk/phbh_carbs/2_carbs.jpg
(which incidentally, by pure coincidence is a pic off google that is ripped off Keith's site afaik Laughing) Cheers fella. Thumbs Up Razz
PostPosted: 23:28 - 12 Feb 2010    Post subject: Reply with quote
There is normally a circular filter under the banjo shaped piece, but not all carbs had them. Ones used in the NSR often don't seem to use them (and not sure about the NS).
As to that pic, was taken for a thread on BCF Laughing
st3v3
PostPosted: 23:31 - 12 Feb 2010    Post subject: Reply with quote
I think they just opened a Maplin's at Clifton Moor here in York, may pop along tomorrow if time is allowing but with the unit's up there, you can barely swing a cat so stocking such trivial items isn't likely.
Failing that with the Leeds branch gone (afaik) hell knows where to go... Sad
I'll get a decent pic tomorrow in the light when I don't risk frostbite. Laughing
PostPosted: 23:37 - 12 Feb 2010    Post subject: Reply with quote
Is it an O ring or a fibre washer?
Whatever it is, try your local pound shop. They usually stock assortments of things like that.
st3v3
PostPosted: 23:44 - 12 Feb 2010    Post subject: Reply with quote
Oooooh, it's one of these:
https://www.thisoldtractor.com/gtbender/mg_images/carburetor_assembly_vhb_106.jpg
Then, logically sit's like so:
https://www.thisoldtractor.com/gtbender/mg_images/carburetor_assembly_vhb_107.jpg
PostPosted: 23:47 - 12 Feb 2010    Post subject: Reply with quote
It is a filter. Common to loads of bikes using Dellorto carbs.
st3v3
PostPosted: 23:53 - 12 Feb 2010    Post subject: Reply with quote
Rather than 'borrowing' one off the next bike I see equipped, where else can I get one? Smile
PostPosted: 23:55 - 12 Feb 2010    Post subject: Reply with quote
Could you not make one with some fine mesh and a couple of O rings? Laughing
PostPosted: 23:56 - 12 Feb 2010    Post subject: Reply with quote
Quickest is probably to go and find a breakers with an RS125 in.
New just use the Dellorto importers:-
https://www.dellorto.co.uk/
st3v3
PostPosted: 01:50 - 13 Feb 2010    Post subject: Reply with quote
Does this sound about right?
https://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=4052&CategoryID=2&PartsectionID=68
PostPosted: 11:15 - 13 Feb 2010    Post subject: Reply with quote
Part 53 on this page:-
https://www.dellorto.co.uk/merchandise/products.asp?CategoryID=2&PartsectionID=24
The page one you were linking to was for the old square slide carbs. Not sure what the last bike was to use those (maybe 1970s Morinis).
st3v3
PostPosted: 23:47 - 13 Feb 2010    Post subject: Reply with quote
Ordered. Thumbs Up
st3v3
PostPosted: 19:09 - 17 Feb 2010    Post subject: Reply with quote
Got the filter, worked a treat. Very Happy
Now the annoying part. It has a leak, 99% sure it's petrol but thre's no leak from anywhere that contains petrol (carb etc).
The leaking comes off the bottom of the engine, if I put the bike on the stand it favours coming out of the alternator cover which is bolted on in a way I can't get off myself (due to fairings etc). My worry is, big end bearings. If these were gone, what's the likelyhood of petrol running through the engine and out the bottom, without any parts moving? Piston rings would provide a decent seal in the barrel for a start; surely?
I swear at this rate it's good for nothing but a scrapyard ornament. Mad Rolling Eyes Evil or Very Mad
The last post was made 16 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 132.14 Kb
