help... yamaha yz 125 spark plug and oil/fuel mixture
neiloggy1
PostPosted: 20:43 - 30 Dec 2009    Post subject: help... yamaha yz 125 spark plug and oil/fuel mixture Reply with quote
hi all
i have a yz 125 1996 model
currently has a br9eg in it
i have been told to use a br9eix and fuel mix of 32/1
is this right please help...
thanks in advance neiloggy.
98 zx9r
neiloggy1
PostPosted: 23:52 - 30 Dec 2009    Post subject: Reply with quote
come on simple questions like this and no1 has an answer
if no1 can answer this i wouldnt dream of asking about anything serious
lol
is there ne 1 out there...
98 zx9r
prawny1
PostPosted: 01:17 - 31 Dec 2009    Post subject: Reply with quote
32-1 would be o.k for normal use,
That is about 31.25ml oil per litre of fuel or 125ml per 4 litres,
For low rev slow speed riding like woods stuff that gives a lot of oil build up in the crankcase you can go to about 40-1 or 25ml oil per litre fuel or 125ml per 5 litres,
For high rev high speed riding you need a stronger mixture because the oil in the fuel will have less chance to seperate in the air stream, you can go as little as 25-1 or (approx) 41ml oil per litre of fuel but anything additional to your 32-1 mix will help if you run with the throttle nailed over fields etc.
As far as the plug goes I should imagine if it's recommended as an alternitive to the stock plug number then it should work fine,
stirlinggaz
PostPosted: 13:24 - 31 Dec 2009    Post subject: Reply with quote
the only difference between the plug you already have & the one you mentioned is the tip.
the br9eix is platinum tipped & therefore costs 3 times as much as an ordinary copper/iron tipped plug. (stick to the normal ones, you can buy more & treat them as disposable. how you gonna feel after spending nearly a tenner on a spark plug & it fouls after a few miles?)
& those mixtures sound ideal .(although i thought the yz had an oil pump?)
cheers,
GAZ
neiloggy1
PostPosted: 22:25 - 10 Feb 2010    Post subject: Reply with quote
the yz motorcross definately has no oil pump
i thought most motorcross bikes are premix??????
98 zx9r
The last post was made 15 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 44.39 Kb
