Hydraulic rams
smegballs
PostPosted: 15:26 - 16 Feb 2010    Post subject: Hydraulic rams Reply with quote
How long do they take to leak down the pressure?
Today I saw a cherry picker type machine with its boom up in the air just left on a site without its generator running. I also see JCB's left with the front loader up in the air parked up.
Is there any danger of a sudden leakdown and collapse of the ram?
Frost
PostPosted: 15:50 - 16 Feb 2010    Post subject: Reply with quote
No. Just like if you fill an air compressor with air and then turn it off, it won't suddenly discharge. It probably will discharge but at a very slow rate.
PostPosted: 16:24 - 16 Feb 2010    Post subject: Re: Hydraulic rams Reply with quote
No they have safety valves on them that mean even if a hose splits it will come down very very slowly indeed.
You know that bit in Casino Royale where Daniel Craig drops down on a scissor lift? Apparently that wouldn't happen!!
PostPosted: 16:47 - 16 Feb 2010    Post subject: Reply with quote
Shouldn't happen but can happen.
My Dad used to be in the lifting equipment business. They were out proof-loading a telescopic crane (to 3x safe working load).
The crane lifted the load just off the ground as instructed and started to pivot with it. At that point, one of the hydraulic rams in an outrigger abruptly collapsed.
250 tonnes went "Boing" on the end of 4-falls of wire rope. The jib went "ping, ping, ping." as it snapped in three places and the whole thing sort of folded in on itself.
My Dad issued an invoice for the test and a fail certificate.
Raffles
PostPosted: 17:17 - 16 Feb 2010    Post subject: Reply with quote
Did they get a free re-test? Laughing
PostPosted: 17:54 - 16 Feb 2010    Post subject: Reply with quote
They do it onsite to stop kids getting on them, leave them up the top by the building then climb through the building to get down.
smegballs
PostPosted: 21:03 - 16 Feb 2010    Post subject: Reply with quote
Thanks for the replies guys.
Hydraulic systems are one of of the few systems I don't really know about, apart from brakes!
PostPosted: 22:57 - 16 Feb 2010    Post subject: Reply with quote
A hydraulic cylinder in good condition will not bypass oil internally. If you get cylinder creep it's usually in the controlling valves. Some cylinders are fitted with check-valves so that they cannot creep and won't move until the valve cracking-pressure is exceeded deliberately in operation. We use these at work for our machine-mounted rock drills.
As warped said if you climb out of an elevated boom type mobile elevated working platform you'll be committing a serious breach of safety regs. You have to wear a harness in a boom type MEWP with a restraint short enough to stop you being able to climb over the rail. This doesn't apply to scissor-type platforms which are designed to allow you to move around but you still mustn't climb out of them when elevated.
The reason they park them elevated is because they use up far less floor space compared to when they are fully descended.
Raffles
PostPosted: 23:57 - 16 Feb 2010    Post subject: Re: Hydraulic rams Reply with quote
I think it was around 1977 when I saw a cherry picker in a state of distress in Moldgreen near Huddersfield. Apparently the boom had become stuck in a fully extended state and an engineer had been called to rectify the problem. He duly undid a hose and the boom lowered faster than expected and crushed the vehicles cab. Luckily no one was injured.
Maybe things are designed better nowadays but back then you would have been well advised to stand well clear.
The last post was made 16 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 72.4 Kb
