| smegballs |
 smegballs World Chat Champion
| Frost |
 Frost World Chat Champion
| MarJay |
 MarJay But it's British!
| stinkwheel |
 Posted: 16:47 - 16 Feb 2010 Post subject: |
Shouldn't happen but can happen.
My Dad used to be in the lifting equipment business. They were out proof-loading a telescopic crane (to 3x safe working load).
The crane lifted the load just off the ground as instructed and started to pivot with it. At that point, one of the hydraulic rams in an outrigger abruptly collapsed.
250 tonnes went "Boing" on the end of 4-falls of wire rope. The jib went "ping, ping, ping." as it snapped in three places and the whole thing sort of folded in on itself.
My Dad issued an invoice for the test and a fail certificate. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Raffles |
 Raffles World Chat Champion
| chris-red |
| warped one |
 warped one Banned
| smegballs |
| Pete. |
 Pete. Super Spammer
 Posted: 22:57 - 16 Feb 2010 Post subject: |
A hydraulic cylinder in good condition will not bypass oil internally. If you get cylinder creep it's usually in the controlling valves. Some cylinders are fitted with check-valves so that they cannot creep and won't move until the valve cracking-pressure is exceeded deliberately in operation. We use these at work for our machine-mounted rock drills.
As warped said if you climb out of an elevated boom type mobile elevated working platform you'll be committing a serious breach of safety regs. You have to wear a harness in a boom type MEWP with a restraint short enough to stop you being able to climb over the rail. This doesn't apply to scissor-type platforms which are designed to allow you to move around but you still mustn't climb out of them when elevated.
The reason they park them elevated is because they use up far less floor space compared to when they are fully descended. ____________________ a.k.a 'Geri'
| Raffles |
| warped one |
 warped one Banned
 Posted: 18:32 - 17 Feb 2010 Post subject: |
CHR15 - That is a very dangerous thing to do. You should always carry someone else's if you don't have 1
Raffles - I had a boom get mardy with me on the daul carrage way going through centeral Leicester. Was quite funny having a few quys stuck up in the air and the generator refusing to start. Had to play around with the manual valves to get them down to the ground. Bloody commuters sat right behind me beeping and swearing at me. Which obviously made it take longer to do.
Warped ____________________ amnesia - Never in the history of usernames has one been more accurate. Warped indeed. You sir are a fecking oddball. |
The last post was made 16 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
