xj 600 n clucking gearbox
sergino1
PostPosted: 07:42 - 11 Feb 2010    Post subject: xj 600 n clucking gearbox Reply with quote
hello everyone.
i have got a xj600 n 1997 here in australia.
everytime i change gears, i hear a clunk noise, it happens either im going up or down,was told that the chain needed ajusting, what u guys think.
thanks in advance.
Frost
PostPosted: 07:46 - 11 Feb 2010    Post subject: Reply with quote
Might well be the chain i know mine used to get louder on gear change as it got looser. Also it might be your clutch needing adjustment. If it goes 'Klunk' when you first up it into 1st and the chain bounces up and down then it's both Laughing
sergino1
PostPosted: 08:04 - 11 Feb 2010    Post subject: Reply with quote
cool, thanks for that, i will adjust both tomorrow and see how it goes.
thanks
sergino1
PostPosted: 05:11 - 17 Feb 2010    Post subject: still have a clunk Reply with quote
ajusted the chain and the clutch cable, still no go,still got the clunk noise,the gear lever feels a bit stiff almost,do you guys think that it could be the clutch plates needing replacing.
thanks
sergino1
PostPosted: 05:24 - 17 Feb 2010    Post subject: Reply with quote
one more thing, when i have the bike in the center stand and put it into first while holding the clutch in , the rear wheel still spins around.
thanks again
PostPosted: 07:49 - 17 Feb 2010    Post subject: Reply with quote
Before adjusting the clutch cable you should adjust the release mechanism on the engine. The cable adjuster is just for setting the free-play in the cable not adjusting the clutch itself.
Frost
PostPosted: 12:27 - 17 Feb 2010    Post subject: Reply with quote
thanks again
Thats the clutch needing adusting. It will be the cause of the clunking when your putting it in gear. Wind the adjuster on the handle bars in all the way, then take as much slack out of the adjuster on the side of the engine, then fine tune by turning the handle bar adjuster out till the rear wheel no longer spins, but the clutch doesnt slip at high rev's.
Ichy
PostPosted: 13:29 - 17 Feb 2010    Post subject: Reply with quote
Sometimes the rear wheel will spin even with the clutch in simply due to drag from the oil.
I still think its worth adjusting your clutch cable.
PostPosted: 14:24 - 17 Feb 2010    Post subject: Reply with quote
All my bikes do this from my Little RXS100 to my TDM900. When was the last time the oil was changed?
Frost
PostPosted: 19:38 - 17 Feb 2010    Post subject: Reply with quote
Bikes sometimes do it due to a worn clutch. With a worn clutch in order to maintain sufficient friction at full throttle the clutch plates have to be run under more pressure meaning they are closer together when the clutch is pulled in. Thats what happened on my XJ600 anyway. I could never find a point of adjustment between slipping and dragging until i changed the plates. In your case it's almost certainly just in need of adjustment, but if this keeps happening the above is what i would be trying.
sergino1
PostPosted: 20:39 - 17 Feb 2010    Post subject: Reply with quote
the oil been changed 2 days ago, i was advised to use 15w50, but i think i should have used 10w30 or 20w40,maybe the oil was to thick,i have ajusted the clutch as much as i could, i will change the oil again, and if that dosent work, i will have to change the clutch plates,
thanks for all your help..
PostPosted: 21:50 - 17 Feb 2010    Post subject: Reply with quote
15-50 is fine I run it in my four.
sergino1
PostPosted: 10:38 - 25 Feb 2010    Post subject: parts Reply with quote
hello guys , i wonder if anyone knows where to order diversion parts from , can seam to find any one in australia, i know that weemoto ships to aus, but was wondering if anyone knew of anyone in australia.
thanks again
Frost
PostPosted: 19:43 - 25 Feb 2010    Post subject: Reply with quote
I got my clutch plates from Wemoto Thumbs Up
iooi
PostPosted: 21:25 - 25 Feb 2010    Post subject: Reply with quote
Have you tried any of the dealers selling parts on ebay from Australia ?
Failing that check out the Divvy owners club in my sig. Pretty sure there are a couple in Aus who maybe able to help.
Noxious89123
PostPosted: 22:05 - 25 Feb 2010    Post subject: Reply with quote
DaFrostyOne wrote:
thanks again
Neutral It's quite normal for the wheel to turn on the stand with the clutch in and bike in gear.
The last post was made 15 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 87.49 Kb
