| motorcycledir... |
 motorcycledir... L Plate Warrior
 Posted: 16:25 - 20 Feb 2010 Post subject: Legal advice re stop and search + court case |
Hi all
I'm looking for some advice on a police stop and search I had last October.
The two police officers stopped me for no apparent reason, treated me with contempt and were quite obviously wasting time stopping me in the first place.
They gave me an endorsable (i.e. points) £60 fine for having a loose chain, they didn't take my license away, they didn't fill out the paperwork they gave me properly (I have it in front of me, incomplete), my payment of the fine was returned pending further action and I never received the points. I've just received a summons with the offense:
"The motorcycle chain was loose"
At the time I was told to get an MOT before I could ride again, which I did the following day, and passed. I know the chain was in perfect order as I had literally just changed the rear wheel, and was riding to work.
As I have never been to court I need some advice as to the strength of my case. Obviously I want to plead not guilty, but how much is it going to cost me if I lose? At the end of the day it's my word against theirs. I have no photographic proof. The only case I can sum up for myself is this:
- the officer did not check the chain properly. The following day at the garage the mechanic suggested he could testify that to check the chain's tension you need to be seated on the motorcycle, not just poke it when slack. Is this sufficient to defend myself in court??
- the officer also did not ask me whether I had a tool kit on me, which was inside the motorcycle. If he was really unsatisfied with the chain's tension, all that it required was a turn of a bolt with a spanner I had stored under the seat. Instead, after ignoring my questions about what was wrong, I was handed the paperwork and told to have a good day.
I'm told this is a 3 points offense. I've talked to my insurance company who tell me that my premium will not go up by much when I renew - these days a lot of riders have points. But that's not the point, I feel this is totally unjustified - it's whether the court fees are going to break the bank or not!
Any advice on this would be greatly appreciated,
Thanks
Matt ____________________ Founder of www.motorcycledirectory.co.uk |
| MarJay |
 MarJay But it's British!
| Quickly |
 Quickly Crazy Courier
 Posted: 17:16 - 20 Feb 2010 Post subject: |
As above, get legal advice, but when you do bear in mind that to be found guilty the prosecution has to establish your guilt "beyond reasonable doubt".
If you can establish corroborated evidence which cannot by its nature be contradicted by the police officer (ie the tester saying the chain is fine) together with discrepancies in the procedure followed (ie an incomplete form) then you'll place in the mind of the judge reasonable doubt.
Do seek legal advice, but do also be sure to go through absolutely everything that took place during the stop and search: did he ask you a question about the bike which would be obvious to someone who rode? Was he called on the radio while he was with you? Where did you stop? Was it busy? Did he say anything about having to be somewhere else, perhaps as a reason to 'let you off' lightly? Was there anyone else present?
All of these things used in the correct way could bring into question his suitability to inspect a bike and/or the reliability of both his judgement at the time and his testimony now.
As the poster above me said there really isn't an equivalent to seeking legal advice, but very often people don't mention 'small' things which - taken together - can be used to establish a degree of reasonable doubt.
Unfortunately however I am studying Scottish Law not English, so as regards the ins and outs I can't be of any help. Just be sure to seek legal advice. Ask about legal aid too. It may require you to sign your savings over to someone else to qualify, but if you do qualify for legal aid it might eliminate some of the financial risk.
 ____________________ ... |
| motorcycledir... |
 Posted: 18:01 - 20 Feb 2010 Post subject: |
Thanks guys, great advice here.
Obviously I wasn't going to base my sole decision on a forum post Pete, but as I have never been in this situation before I thought I'd just check.
I'll let you guys know how it pans out, thanks again
| Flip |
 Flip Super Spammer
| MarJay |
 Posted: 18:37 - 20 Feb 2010 Post subject: |
| Quickly wrote: | As above, get legal advice, but when you do bear in mind that to be found guilty the prosecution has to establish your guilt "beyond reasonable doubt". |
No they don't.
In a civil case, they have to establish guilt to within a "balance of probability".
Only criminal cases necessitate proof "Beyond reasonable doubt". Only criminal cases qualify for legal aid. 2/10 must try harder.
I'd be more interested in 1) Were they a DOT qualified vehicle inspector. and 2) Do they have any direct knowledge and/or experience of motorcycle mechanics/maintainance.
If the answer to these is no, it is not unreasonable to suggest that, being the holder of a motorcycle licence, the test for which includes a section on chain maintainance, you are more qualified than they are to decide on the condition of the chain.
I would be asking them to outline the procedure they used to check the chain tension, what the free play on your chain was and what the acceptable level of free play in mm is on your bike.
The reason being, if they show ignorance of the correct procedure for checking chain tension, did not measure the chain free play and have no idea what the correct level of free play is to compare this measurement to. The magistrate will throw it out.
Happily, they are all different with regard to how the manufacturer recommends the chain be checked so if they are guessing, they will almost certainly get it wrong. I'd suggest you bring along your owners manual stating how it should be done.
For example:
On a KLE500, the chain tension has to be measured with the bike on the side stand, the wheel is rotated to the tightest spot of the chain and slack measured there. 35-45mm of free play is acceptable.
On a GPX600, the tension has to be measured on the main stand with the rear wheel propped off the ground. Rotate to tight spot, measure. 35-40mm is acceptable.
Deviate from this, you didn't check the chain tension. Case dismissed. Don't bring such ill prepared rubbish before me again Mr Plod.
I'd be willing to bet they aren't even aware of the existance of a tight spot on a chain, never mind how to find it and that you're supposed to measure free play at that point. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Quickly |
| and |
 and World Chat Champion
| salty21 |
 salty21 World Chat Champion
 Posted: 20:32 - 20 Feb 2010 Post subject: |
odds are it will never reach the court room, but you will probably waste a good part of your day surrounded by scum in a waiting area
i was told to be there by 9.30am for an allocated time slot of 10.00am.................... i didn't get in till 3pm:s ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| Maruchino |
 Maruchino Spanner Monkey
The last post was made 16 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
