god damn ice, theres now a hole in my engine
spakmitten
PostPosted: 08:43 - 22 Feb 2010    Post subject: god damn ice, theres now a hole in my engine Reply with quote
right i launched my r6 up the road on my way home from work yesterday morning on a patch of stealth ice, easy things to fix being bent clutch and gear change and an indy
but the part i need help with is the left hand side of the engine
it ate up about 20ish feet of road on its "little slide" and has a very slight oil leak, i think there's a fine crack/hole in it or hopefully it just took a whack and the gasket is fooked, but im gunna investigate later on today and get all the fairings off
how much do you reckon this is gunna cost me to fix if it is a hole Sad
cyberglass
PostPosted: 08:53 - 22 Feb 2010    Post subject: Reply with quote
You would have to post pics so we can see the extent of the damage and give you an estimate.
If its just the engine cover thats ripped through then they can be had for cheap on the bay.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
MarkJ
PostPosted: 09:27 - 22 Feb 2010    Post subject: Reply with quote
What cyberglass said - giz a look
spakmitten
PostPosted: 09:29 - 22 Feb 2010    Post subject: Reply with quote
i cant find my camera imma gunna have to go take a pic with my phone
it dosnt look as bad now as when i was in OH NO MY BIKES DEAD panic mode yesterday
spakmitten
PostPosted: 09:50 - 22 Feb 2010    Post subject: Reply with quote
right best pic i can get at the moment until i get the plastics off
spakmitten
PostPosted: 09:51 - 22 Feb 2010    Post subject: Reply with quote
it looks just like surface damage but i cant work out where this oils is coming from
PostPosted: 10:26 - 22 Feb 2010    Post subject: Reply with quote
US price for that cover is $57, so probably £57 over here.
smegballs
JB Weld or magical R6 fixing goop as its locally known Thumbs Up Wink
spakmitten
PostPosted: 11:16 - 22 Feb 2010    Post subject: Reply with quote
hi thanks keith, the cheapest i can find is about £130 where should i be looking and what is the official part name or number
PostPosted: 11:19 - 22 Feb 2010    Post subject: Reply with quote
Ebay. £40-60 by the look of things.
PostPosted: 11:33 - 22 Feb 2010    Post subject: Reply with quote
I got the price from the US Ron Ayers site which has loads of fiche online.
Any Yamaha dealer should be able to order one for you.
spakmitten
PostPosted: 12:28 - 22 Feb 2010    Post subject: Reply with quote
excellent stuff guy many thanks
is it an easy thing to replace on my own or should i get the local spanner jockeys to do it for me
PostPosted: 12:29 - 22 Feb 2010    Post subject: Reply with quote
Should be easy enough to do yourself.
spakmitten
PostPosted: 12:32 - 22 Feb 2010    Post subject: Reply with quote
as far as i know all i have to do is drain oil
take plastics off
whip off the broken cover replace gasket and new cover fill up oil etc etc
nothings gunna fall out of the engine when i take the side off is it
PostPosted: 12:46 - 22 Feb 2010    Post subject: Reply with quote
You can probably get away without draining the oil, especially if you have someone who can hold the bike and lean it to the other side while you do it. However unless the oil is new then you may as well change it at the same time.
Nothing should fall out when you take that cover off. There is the generator bolted to the inside of it.
The last post was made 16 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 85.15 Kb
