painting exhaust
flumpy7
PostPosted: 00:35 - 23 Feb 2010    Post subject: painting exhaust Reply with quote
Hi guys
Just picked up a cheap hartford vr125z (taiwanese, CG engine) for the missus to learn on. The exhaust needs painting again as the finish has really degraded. Its not blowing or anything. Its that black stuff that scooters often have. Can i just take it off, spray it and replace it, or are there any mechanical issues i need to be aware of? Cheers in advance
el_oso
PostPosted: 02:58 - 23 Feb 2010    Post subject: Reply with quote
black?
many people have just sprayed over the top with that high temp BBQ spray paint and has looked fairly reasonable from pictures that i have seen.
Duke 390
Car: Jeep Wrangler 4.0L
oldbiker
PostPosted: 20:57 - 23 Feb 2010    Post subject: Reply with quote
I tried bbq paint on my tzr exhausts, after the first long hot run all the paint flaked away from the down pipes so that was £5 wasted.
Now I use PJ1 exhaust paint about £6 for one can just enough for both exhausts and respray once a year I have found pj1 to be excellent
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
andybon
PostPosted: 21:21 - 26 Feb 2010    Post subject: Reply with quote
On my scooter i had a few years back, I used a can of high temperature paint. Just rubbed it down cleaned it up and sprayed it on. It flaked after a while but i rubbed it down and gave it another coat and it never came off again.
Designed by a Genius. Built by a Craftsman. Ridden by a t**t
oldbiker
PostPosted: 10:34 - 28 Feb 2010    Post subject: Reply with quote
Vincent wrote:
Did you use Plastikote BBQ paint or a cheap Generic make?
tried plastikote both high gloss and matt, I had a couple of cans left from other jobs.
They both look good till the exhaust gets hot
tutton
PostPosted: 13:35 - 28 Feb 2010    Post subject: Reply with quote
Find that exhaust paint called PJ something..
good stuff that is.
There is a gap of 326 days between these two posts...
Parp
PostPosted: 13:10 - 21 Jan 2011    Post subject: Reply with quote
What would you rub the exhaust down with?
PJ1 does not mention painting exhausts, would an exhaust paint that has a higher temp rating not be better?
Thanks in advance.
Blackwolf
Burgerfist
PostPosted: 13:48 - 21 Jan 2011    Post subject: Reply with quote
Rub it down with wire wool/brush.
As its a cheap exhaust it may be worth wrapping it? Should keep it lasting for longer and keeping the rot away?
Parp
PostPosted: 15:26 - 21 Jan 2011    Post subject: Reply with quote
Would wrap not just collect dirt and if the bike was left out in the rain, water as well?
Blackwolf
Burgerfist
PostPosted: 16:23 - 21 Jan 2011    Post subject: Reply with quote
i think the wrap hardends and becomes non porous
0l0dom0l0
PostPosted: 19:19 - 21 Jan 2011    Post subject: Reply with quote
It does trap moisture yes. Its designed for engine bay applications in cars, where they see very little moisture.
Never heard of this PJ stuff though, will have a look into it.
I have tried both halfords VHT paint, and also the plasticote stuff. The plasticote was the better out of the two, but wasn't fantastic.
Raffles
PostPosted: 23:19 - 21 Jan 2011    Post subject: Reply with quote
Back in the day Sperex was the stuff to use. It wasn't very durable but I don't think that any aftermarket paint is going to last very long under conditions of such extreme heat.
https://a1autowise.com/ssmhpdb.aspx
Dazbo666
PostPosted: 02:34 - 22 Jan 2011    Post subject: Reply with quote
I used wire wool and Plastikote matt BBQ paint on the downpipes of the GPZ.
It all lasted for a number of months of daily commuting before the colour started fading and I had to respray.
Word of the day : DILLIGAF
Parp
PostPosted: 18:53 - 30 Jan 2011    Post subject: Reply with quote
Edit
Parp
PostPosted: 16:13 - 31 Jan 2011    Post subject: Reply with quote
Edit
The last post was made 15 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 85.77 Kb
