Can my crankcase be alloy welded
Dr Nick
PostPosted: 13:42 - 01 Jul 2004    Post subject: Can my crankcase be alloy welded Reply with quote
Got some pics of the damage the chain did to my crankcase, its basically sheared off 2 mounting points, one for the water pump, and one for the sprocket guard.
As im not having any luck finding a s/h engine or crankcase, my dad reckons he can 'build it up with aluminium weld and tap a thread in' possibly, does it look like this can be done? i believe i will need to take the crankcase out, becuase i can't do it while its in the bike, as it will destroy the seals etc.
Does anyone think this can be done, ive tried findapart, but havent had one phone call.
Any replies appreciated
thanks
pics of the damage :-
https://www.the-npf.com/bugger/bugger1.jpg
https://www.the-npf.com/bugger/bugger2.jpg
https://www.the-npf.com/bugger/bugger3.jpg
https://www.the-npf.com/bugger/bugger4.jpg
is that it
McJamweasel
BCF Junkie
PostPosted: 13:54 - 01 Jul 2004    Post subject: Reply with quote
It may be possible, it depends on what type of alloy it is. When I took my holed magnesium alloy crankcase cover in to have some crap screws removed I asked the bloke to try and weld it, he did but it didn't work.
PostPosted: 18:20 - 01 Jul 2004    Post subject: Reply with quote
The sprocket cover one should be OK. Not vast amounts of stress and will not matter too much if it is not quite perfect.
The water pump mount might be more of a problem. Get it wrong and the pump will probably leak, or wear rapidly.
dibbster
PostPosted: 20:38 - 01 Jul 2004    Post subject: Reply with quote
Fingers crossed it can be, but they are a sod to do.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
jayluvmito
PostPosted: 20:41 - 01 Jul 2004    Post subject: Reply with quote
we have had crank cases welded on honda cb750's/900's and triumph speed triples..looks like a basic job for a experienced welder...
one day...
kev
I Hump Things
PostPosted: 07:14 - 02 Jul 2004    Post subject: Reply with quote
Only thing to remember is the weald comes out at 2600 degrees so any gaskets withing about 3 inches will die and will need replacing.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
The last post was made 21 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.3 - MySQL Queries: 13 - Page Size: 49.32 Kb
