Electronics wizards, your advice please.
Tarmacsurfer
PostPosted: 00:59 - 26 Feb 2010    Post subject: Electronics wizards, your advice please. Reply with quote
Skip to ** if you can't be arsed to read the preamble.
I have an electric garage door (of the roller shutter variety). Wonderful piece of kit, I love it to bits and due to certain issues it has helped immeasurably with my mobility over the last few years. There is however one small problem that has recently become more pressing.
Due to the cocktail of prescription medication that I'm currently swilling my memory is getting steadily worse, to the point that for the second time I today left the house and totally forgot to click the remote and close the garage behind me. Given the large supply of tools and the assorted bikes in there this is a Very Bad Thing. Thankfully I realised, turned back and took care of it (unlike last time when I was out for the entire evening and didn't discover my error until I returned home).
**How difficult would it be to add a timer circuit to the system to close an electric garage door after X minutes open? Ideally with a manual override to disable the circuit and allow for situations like working in the garage with the door open. Basically something to close the door if I forget to do so as I leave.
Any advice gratefully received, if it's possible and you can actually build such a gizmo then feel free to PM me and throw a price in my direction.
I'm immortal. Well, so far.
Frost
PostPosted: 03:37 - 26 Feb 2010    Post subject: Reply with quote
Yup it's doable. You will need:
Processor chip capable of timer functions and switch input.
Switch to tell the system to leave the door open.
Switch to detect the door has closed.
Power source.
Big motor.
Relay capable of switching the motor.
The actual programming of it would be very simple, mounting the switch important to get right. The biggest problem you will face is the motor and mechanism for actually closing the door. You will probably need to find a second hand one and gear it accordingly. A bike starter motor might do it.
Phoenix
Twisted Firestarter
PostPosted: 04:44 - 26 Feb 2010    Post subject: Reply with quote
The garage door is already electric so he doesn't need those. I would've thought you can just get the appropriate timer circuit premade from Maplin or just the chip itself if you're going to make it, which I assume you're not. An override switch would be possible, it can just be an interruption switch between the timer circuit and door controller but you'd obviously have to remember to disable the switch too otherwise you could open the door with the remote and it wouldn't auto close if you forgot to turn off the override switch, maybe hook it into the light so it's only overidden when the light is on.
map
Mr Calendar
PostPosted: 12:38 - 26 Feb 2010    Post subject: Reply with quote
DaFrostyOne wrote:
Yup it's doable. You will need:...
Confused
Not sure about that one.
Would have thought switch required to activate the timer when door open (magnetic security door switch maybe).
Then timer runs and output to the door mechanism to close when required.
As said override on/off required to keep door open (could be in-line switch for the door open sensor).
Alternative could be a sort of reverse PIR sensor. Along the lines of door opens, you get your kit out of the garage and then when PIR senses NO movement activates output to close door*. I'm sure such things do exist off the shelf (e.g. toilets in some buildings switch lights on as you enter then turn off when you leave). Questions are (a) are they affordable and (b) will they interface to existing remote door open/close.
Just some thoughts.
Let us know how you solve it Thumbs Up
<edit>
*Having said that most PIRs that do lights have an adjustable timer to turn them off. If it then detects movement turns back on
</edit>
Feasty
PostPosted: 12:49 - 26 Feb 2010    Post subject: Reply with quote
Just be careful you don't set it so that if you've left a car/bike parked under the door it doesn't suddenly come down on them! Laughing
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
CaNsA
PostPosted: 12:53 - 26 Feb 2010    Post subject: Reply with quote
An IR beam across the doorway to signal when u have left the garage then to automatically close the door. no timer needed?
PostPosted: 13:15 - 26 Feb 2010    Post subject: Reply with quote
So it shuts the door when you've wheeled the bike out, but not yet got your helmet and gloves? Lovely Smile
Pedd
PostPosted: 14:16 - 26 Feb 2010    Post subject: Reply with quote
Combination of a little 555 timer and an ir beam, the timer runs for say 2mins then shuts the door, but only if the ir beam is clear, (so if your bike/car you etc is blocking the beam then it cant shut)
Would imagine that the door has an input for a button to shut the door just hook the timer output upto that via the ir beams switch relay.
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
PostPosted: 14:37 - 26 Feb 2010    Post subject: Reply with quote
If you just want it to shut the door after a given period of time, AND you have a one hit manual push switch on the inside to open/close the door, then this circuit will do the biz for you.
https://www.kpsec.freeuk.com/projects/timer.htm
The on/off switch will act as the arm/disarm, and an additional microswitch needs to be wired in series that is closed when the garage door reaches its fully open position. The circuit doesn't draw any power until that switch is closed, so the battery will last ages.
Once the circuit is powered on, the timer starts. Instead of (or as well as) the beeper, a simple relay is needed that will trigger the garage's manual push switch.
Total cost? Maybe about £3. £5 if you want a shiny box. Less if you don't want the green and red LEDs. and even cheaper if you want a fixed time period rather than a selectable one. Total time? Maybe an hour on the circuit, then however long it takes to mount it and bodge the garage door sensor switch Smile
[edit] If you can wait until April, I'll do it for the price of parts, petrol and a bacon sarnie or two Smile
Kwaks
I'm not a fast rider
PostPosted: 14:53 - 26 Feb 2010    Post subject: Reply with quote
I am a lazy barsteward.
Just buy one imo
https://www.protectrix.com/cgi-bin/ProtectrixBuy.cgi
www.cliqueycuntsmcc.co.uk
Handsome
PostPosted: 15:14 - 26 Feb 2010    Post subject: Reply with quote
Sticker on the dash of the car and a waterproof one on the dash of the bike simply saying " Door " ?...
MarkJ
PostPosted: 15:54 - 26 Feb 2010    Post subject: Reply with quote
Please don't take offence at this, but if you are on medication which affects your memory in this way, should you be riding/driving vehicles? I take it you have been cleared by the doctor?
Tarmacsurfer
PostPosted: 18:32 - 26 Feb 2010    Post subject: Reply with quote
Cheers folks, will have a read through the links and info shortly Thumbs Up
The door already has an IR safety beam in place, if the beam is interrupted the door won't close and if it's triggered as the door is descending it immediately stops and opens. There's also a manual switch in place so that is the obvious place to make additions to the circuit, given the pointers here then I'm probably competent enough with a soldering iron to make up anything I can see a shopping list for and diagram of.
MarkJ, of course. No offence taken.
Pedd
PostPosted: 18:42 - 26 Feb 2010    Post subject: Reply with quote
dont forget you need an output of some sort from the door to tell the unit its actually open, could be a standard output the unit has or one grabbed of an indicator light or door switch.
Dont Click HERE
Clanger
Stirrer
PostPosted: 19:11 - 26 Feb 2010    Post subject: Reply with quote
Seconded. Shocked
MarkJ
PostPosted: 19:49 - 26 Feb 2010    Post subject: Reply with quote
I don't know if they exist, but maybe a pressure switch/pad of some sort that won't be triggered by the weight of a person, but by the weight of a bike/car? You could then just wire it up to the wires that come from the "down" button
Frost
PostPosted: 13:30 - 02 Mar 2010    Post subject: Reply with quote
map wrote:
[quote="DaFrostyOne"
Confused
Would have thought switch required to activate the timer when door open (magnetic security door switch maybe).[/quote]
Same thing really. Difference is that a switch to detect the door is closed turns the motor off at the right time but will still close a partly open door.
A switch to detect it being in an open state will only trigger if the door fully opens and won't know if the door has failed to close or when to turn the motor off.
CaNsA
PostPosted: 17:18 - 02 Mar 2010    Post subject: Reply with quote
this thread is getting far to complicated.....
Why not just get the wife to close the door?
Or buy a midget....
The last post was made 16 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 102.26 Kb
