| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
| Frost |
 Frost World Chat Champion
| Phoenix |
 Phoenix Twisted Firestarter
| map |
 map Mr Calendar
 Posted: 12:38 - 26 Feb 2010 Post subject: |
| Feasty |
 Feasty World Chat Champion
 Posted: 12:49 - 26 Feb 2010 Post subject: |
Just be careful you don't set it so that if you've left a car/bike parked under the door it doesn't suddenly come down on them!  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| CaNsA |
 CaNsA Super Spammer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| Pedd |
 Pedd World Chat Champion
 Posted: 14:16 - 26 Feb 2010 Post subject: |
Combination of a little 555 timer and an ir beam, the timer runs for say 2mins then shuts the door, but only if the ir beam is clear, (so if your bike/car you etc is blocking the beam then it cant shut)
Would imagine that the door has an input for a button to shut the door just hook the timer output upto that via the ir beams switch relay. ____________________ Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around  |
| The Shaggy D.A. |
 Posted: 14:37 - 26 Feb 2010 Post subject: |
If you just want it to shut the door after a given period of time, AND you have a one hit manual push switch on the inside to open/close the door, then this circuit will do the biz for you.
https://www.kpsec.freeuk.com/projects/timer.htm
The on/off switch will act as the arm/disarm, and an additional microswitch needs to be wired in series that is closed when the garage door reaches its fully open position. The circuit doesn't draw any power until that switch is closed, so the battery will last ages.
Once the circuit is powered on, the timer starts. Instead of (or as well as) the beeper, a simple relay is needed that will trigger the garage's manual push switch.
Total cost? Maybe about £3. £5 if you want a shiny box. Less if you don't want the green and red LEDs. and even cheaper if you want a fixed time period rather than a selectable one. Total time? Maybe an hour on the circuit, then however long it takes to mount it and bodge the garage door sensor switch
[edit] If you can wait until April, I'll do it for the price of parts, petrol and a bacon sarnie or two  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Kwaks |
 Kwaks I'm not a fast rider
| Handsome |
 Handsome World Chat Champion
| MarkJ |
 MarkJ World Chat Champion
| Tarmacsurfer |
 Posted: 18:32 - 26 Feb 2010 Post subject: |
Cheers folks, will have a read through the links and info shortly
The door already has an IR safety beam in place, if the beam is interrupted the door won't close and if it's triggered as the door is descending it immediately stops and opens. There's also a manual switch in place so that is the obvious place to make additions to the circuit, given the pointers here then I'm probably competent enough with a soldering iron to make up anything I can see a shopping list for and diagram of.
MarkJ, of course. No offence taken. ____________________ I'm immortal. Well, so far. |
| Pedd |
 Posted: 18:42 - 26 Feb 2010 Post subject: |
dont forget you need an output of some sort from the door to tell the unit its actually open, could be a standard output the unit has or one grabbed of an indicator light or door switch. ____________________ Dont Click HERE
| Clanger |
 Clanger Stirrer
| MarkJ |
| Frost |
| CaNsA |
 CaNsA Super Spammer
The last post was made 16 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
