Project 'Hondzuki'
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3, 4, 5, 6  Next
Tim..
PostPosted: 09:29 - 26 Feb 2010    Post subject: Project 'Hondzuki' Reply with quote
Whilst in the middle of one of my other projects (honda vfr400, see sig).
I decided to pull out an old frame that was given to me a long time ago.
The only RGV parts i have are the vj21 chassis and the bottom yoke.
Not needing the VFR front end i had just pulled off i was surprised to see that the VFR forks fitted the RGV bottom yoke.
And so starts 'Project HONDZUKI'.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20400%20nc30/Photo039-1.jpg
Parts I have for the project;
RGV vj21 chassis
RGV vj21 bottom yoke
Honda FMX650 engine and loom
Honda VFR400 complete front end
Honda VFR400 rear wheel
Honda VFR400 grp race seat unit
Honda VFR400 swingarm and hub etc
Parts i need;
RGV vj21 top yoke
RGV vj21 fuel tank
Honda VFR400 grp race fairing
This is a project built from all the parts I already have and with the intention of building a budget race bike. All parts donations accepted Wink
Tim
www.marshallracing.co.uk
Tim..
PostPosted: 09:42 - 26 Feb 2010    Post subject: Reply with quote
Because I am changing all the rear shock mounts for VFR linkages I want to be careful to keep the nimble RGV geometry. These are the dimensions I will be using.
https://i475.photobucket.com/albums/rr119/Timon1983/RGV%20Hondzuki/untitled-2.jpg
Does anyone have the swingarm pivot height so i can jig the bike up?
The RGV vj21 also uses an 18 inch rear wheel, this means I can keep the 8 degrees swingarm droop angle (although i might raise it to 9 degrees to get jack the rear of the bike up slightly)
Last night i also found out the VFR swingarm spindle diameter is perfect for the RGV frame, machined the frame out slightly and the swinarm is in with gaps either side so i can centre it later on with spacers.
Also trail fitted the seat unit. Will get some pics up soon.
Tim
Tim..
PostPosted: 17:10 - 26 Feb 2010    Post subject: Reply with quote
Pics as promised Wink
Swingarm is in and aligned, measured the whole bike to get a good centre line. Then 'stringed' it (gotta love the old school) just to check. Just need to get the spacers made up and that will be the swingarm done.
https://i475.photobucket.com/albums/rr119/Timon1983/RGV%20Hondzuki/Photo002.jpg
The shock and linkages, however, is a whole other saga to be tackled.
Also pulled the motor out to offer it up, its going to be quite a squeeze to say the least.
https://i475.photobucket.com/albums/rr119/Timon1983/RGV%20Hondzuki/Photo042.jpg
Tim
BenR
PostPosted: 17:13 - 26 Feb 2010    Post subject: Reply with quote
How will you over come chain alignment issues?
Tim..
PostPosted: 17:21 - 26 Feb 2010    Post subject: Reply with quote
The chain runs past the frame fine, there is quite a nice gap.
As for the engine, i'm not 100% on the positon (weight distribution calcs etc) yet but the general idea is far back as I can get it. May have to raise or tilt the engine slightly to get the chain alignment right.
Tim
PostPosted: 17:40 - 26 Feb 2010    Post subject: Reply with quote
THis looks really interesting I will be following this, good luck Thumbs Up
Would sort of power is the FMX engine putting out? will you be doing any work on it? What exhaust will you be using? I can't imagine the standard FMX exhaust would fit a sports bike chassis and fairings.
Tim..
PostPosted: 17:52 - 26 Feb 2010    Post subject: Reply with quote
Thanks bud
The lump is only stock at about 37hp & 38ftlbs (ref-bikez.com), might do a bit of engine work (skim, flowing, cams etc) after the bike is done and tested.
Hopefully be able to source a decent 'race' header pipes and then make the rest of the exhaust to suit the bike.
EDIT
OH forgot to say the standard headers are very restricting on them and if I had them I still wouldn't use them.
Tim
PostPosted: 18:04 - 26 Feb 2010    Post subject: Reply with quote
Thanks bud
EDIT
Tim
What I was getting at is that the FMX pipes go round the side of the engine I'm not sure they would fit in a deltabox frame especialling with a fairing. I would have thought you would need specially made pipes that go under the engine.
Tim..
PostPosted: 18:22 - 26 Feb 2010    Post subject: Reply with quote
Not thought that far a head to be honest but yeah you're right I would run the exhausts under rather around.
Tim
MaybeGuy
PostPosted: 18:32 - 26 Feb 2010    Post subject: Reply with quote
this is all great and everything... but whats the point?
less powerful than both an RGV and a VFR.
Tim..
PostPosted: 18:45 - 26 Feb 2010    Post subject: Reply with quote
Read my first post
total money spent = £0.00
jack_zxr400
PostPosted: 12:42 - 27 Feb 2010    Post subject: Reply with quote
i love it Very Happy
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
Gazdaman
I did a trackday!!!
PostPosted: 12:56 - 27 Feb 2010    Post subject: Reply with quote
I love it too, good on ya. A unique bike that should look good, handle well, cost very little and be a hoot to build.
I'll watch this intently.
Gaz
Tim..
PostPosted: 19:55 - 28 Feb 2010    Post subject: Reply with quote
Swapped some of my other parts just hanging around for a RGV tank (with only one small dint that easily filled) and a RGV top yoke.
https://i475.photobucket.com/albums/rr119/Timon1983/RGV%20Hondzuki/Photo0024.jpg
Trail fitted the seat unit, i think it works well.
As for the name its going to be 'Hondzuki RFX650R' (Rgv + vFr + fmX + 650cc + Racing)
Tim
wabbithunter
PostPosted: 22:46 - 28 Feb 2010    Post subject: Reply with quote
fuck me timon you didnt hang about!!
cheers for the bracket mate, will have a go at fitting it tomorrow
so you machines the frame? i machined the swinger on mine!
are you gonna cut the frame to fit the linkages or try another route?
TL1000R Fighter,TL1000R ,Husaberg 650 ,883 sportser,Ducati 996,RGV/RS 250 Special Fighter
I INTEND TO LEAVE THIS WORLD THE SAME WAY I CAME IN, BLOODY AND SCREAMING
wabbithunter
PostPosted: 22:49 - 28 Feb 2010    Post subject: Reply with quote
why not?????????????????
Tim..
PostPosted: 22:58 - 28 Feb 2010    Post subject: Reply with quote
No problem bud. Yep, could wait to see the tank on the bike Wink
Yeah cut the swingarm pivot mounts backto fit the swinger in. Going to box in the chassis a bit for some extra strength.
Already cut the bottom linkage mount off the bike and unbolted the top shock mount.
wabbithunter
PostPosted: 23:02 - 28 Feb 2010    Post subject: Reply with quote
is it just the mount that needs to be cut out or does it require a chunk taken out of the lower frame rail? i really cannot remember of the top of my head??
tbh i cant even remember what the rs frame rails look like its been so long since ive seen it!! (really need to make a start on that one!!!!!!!!!!!!!!)
Tim..
PostPosted: 23:07 - 28 Feb 2010    Post subject: Reply with quote
Rather large chunk needs taking out Rolling Eyes
wabbithunter
PostPosted: 23:09 - 28 Feb 2010    Post subject: Reply with quote
Doh!
wabbithunter
PostPosted: 23:11 - 28 Feb 2010    Post subject: Reply with quote
good shit that the forks and yoke match up too!
have you got new wheels for the vfr?
im after a 17inch rear if you know of any going cheap?
Tim..
PostPosted: 23:19 - 28 Feb 2010    Post subject: Reply with quote
Yeah hopefully got some coming soon for the VFR.
PM sent about the 17"
wabbithunter
PostPosted: 23:23 - 28 Feb 2010    Post subject: Reply with quote
cheers dude
Frost
PostPosted: 03:28 - 01 Mar 2010    Post subject: Reply with quote
I've been plotting a similar project to this but i was planning a supermono track bike so i was thinking a 70bhp motor is what to aim for. Why not get it going with the free engine, then when cash is more available upgrade to something special? Smile
It's one thing to think and talk about things but quite another to just get on with it. Full marks for effort so far Thumbs Up
PostPosted: 14:52 - 01 Mar 2010    Post subject: Reply with quote
Getting 70bhp out of a single will be expensive an unreliable, a mates Husaberg had about 70bhp It was a 650 IIRC and that required an oil change every 3 hours.
The last post was made 16 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 6
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 143.08 Kb
