Sticker virgin
Quickly
PostPosted: 17:23 - 26 Feb 2010    Post subject: Sticker virgin Reply with quote
I've never really been one for putting stickers on bikes so I'm looking for some advice. I guess I never really liked a sticker 'that way', but I've found 'the one' and I'm going to take the plunge this weekend.
My first thought was just to wash the bike and stick it on. However, after washing it I'm now also going to give the bike a polish and then a going over with an anti-corrosion spray (that leaves 'a thin film').
I wondered at what point I should put the sticker on? Obviously wash the bike first. Is it a good idea to polish the sticker as well? Probably not. Or to put it on pre-spray so that the film covers the sticker (this might hold the sticker on firmer, or it might damage it)?
Any help appreciated.
(BTW, it's a custom design with one of my favourite quotes done up in an Olde English font, due to go on the tank)
PostPosted: 17:36 - 26 Feb 2010    Post subject: Reply with quote
Don't polish the bike before you put the sticker on, the polish might prevent it from adhering to the bike.
Wash the bike, dry the bike, stick on the sticker and then polish carefully.
Quickly
PostPosted: 17:39 - 26 Feb 2010    Post subject: Reply with quote
Cheers, should I polish over the sticker or around it? Same with the corrosion spray?
That_Hornet
PostPosted: 19:48 - 26 Feb 2010    Post subject: Reply with quote
Spray some window cleaner on where you want your sticker, the stick it on. That gives you a little play with movement for a while until the cleaner drys.
Worked with mine.
chip
PostPosted: 19:54 - 26 Feb 2010    Post subject: Reply with quote
or soapy water worked for me otherwise you will look at it later and it wil be a tad bit higher then u want it and you wont beable to do anything about it Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
andybon
If you want it to stick better, I found warming the panel/area up slightly with a hairdrier usually helps
Designed by a Genius. Built by a Craftsman. Ridden by a t**t
DazHornet
PostPosted: 19:55 - 26 Feb 2010    Post subject: Reply with quote
wash the bike, then dry it and then try to warm the area up as best as possible before puttin the sticker on ...
whether this is just rubbing it hard, the mrs' hair dryer, heat gun it doesnt matter. the sticker will stick better and therefore last longer with the heat.
and be careful with the anti-corrosion spray try to not spray directly onto sticker!
Clanger
Stirrer
PostPosted: 20:05 - 26 Feb 2010    Post subject: Reply with quote
Have a search for Robby's post on a similar subject matter, lots of people answered his question...may find the answer you need. Thumbs Up
The last post was made 16 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 57.27 Kb
