Is this the oil drain plug? Honda XR125
Bambam3
PostPosted: 17:25 - 27 Feb 2010    Post subject: Is this the oil drain plug? Honda XR125 Reply with quote
I spent ages looking on the side where you fill the oil, couldn't find anything that looked like a drain plug, just engine nuts and stuff.. looked on the other side and clocked this. Bit big though.
I'm clueless.
Looks like the position from this guys pic..
https://dansmc.com/changeoil_xl250springbolt.jpg
Cheers.
Frost
PostPosted: 17:32 - 27 Feb 2010    Post subject: Reply with quote
The oil drain bolt will be on the same side as the side stand. This allows the oil to drain out from the bottom of the engine when it's on the stand. The bolt is normally about 1 inch in size and on the very underside of the engine. Laying under the bike with it on the side stand should immediately reveal a large bolt at the very bottom of the engine.
Bambam3
PostPosted: 17:38 - 27 Feb 2010    Post subject: Reply with quote
Nothing underneath, just the small engine nuts as on the other side.
I figure that must be it.
This is a quote from the site with that pic..
One thing watch out for. Some engines that have side oil drain bolts, like 1985 and on Honda XR/XL250 engines, also have a gearshift return spring bolt near the oil drain bolt. DO NOT remove this gearshift return spring bolt! If you do, you will have to remove the engine from the frame and do a lot of work to reposition the spring. As I remember, back in the dim dark 1960s there were some two stroke engines that had the same problem. Unfortunately, I can't remember which ones. I went back and checked all my old shop manuals, but I could not find the engine. Oh well, just be aware of this little trap the manufacturer has set for you!
steveh
PostPosted: 18:09 - 27 Feb 2010    Post subject: Reply with quote
to make it easyer, Yes that is it.
The Tot
PostPosted: 03:15 - 28 Feb 2010    Post subject: Reply with quote
To verify as an ex XR owner... yes.
I'm not sure where the oil strainer is mounted... i believe it's behind the bolt... Make sure you clean that too since the XR125 does not have a cartridge-style oil filter as such.
Never argue with autism
Alexio
PostPosted: 03:43 - 28 Feb 2010    Post subject: Reply with quote
I've no idea about your bike specifically but it looks identical to the plug on my Honda CG125:
https://i8.photobucket.com/albums/a27/alsweetex/DSC00259.jpg
So I would say: yes.
Moo.
PostPosted: 14:21 - 28 Feb 2010    Post subject: Reply with quote
I would've said that looks like the oil filter gauzey thing. On my cg the oil drain bolt is underneath and has a little metal guard to protect it.
But follow these guys advice Razz yes.
A2 Passed 18/6/10
The last post was made 16 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 52.38 Kb
