What fingers do you cover the brake and clutch with?
HP
PostPosted: 19:13 - 01 Mar 2010    Post subject: What fingers do you cover the brake and clutch with? Reply with quote
On my mod 1 which I done on the weekend using youtube videos my examiner warned me about using you index and middle finger on the brake and clutch lever saying i wouldnt be able to stop quick enough and he saids the mod 2 examiner will mark me down, can someone tell me if this is true and also is it a minor or a major because it is a habit which i can't get out of and i feel comfortable and in control of my bike.
Cheers Harry
Rufus
PostPosted: 19:33 - 01 Mar 2010    Post subject: Reply with quote
how your examiner will see it, god knows. you are expected to use all four fingers when applying the brake or clutch though. whether it's a failing offense to use one finger is questionable if you are indeed in control of the bike, as thats what the test is about.
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
Handsome
I was told during lessons to brake with all four fingers as I normally do it with just the first two, four fingers equal more pressure, resulting in stopping sooner...
Still ride with just the two to pull the lever in though, but I've never heard of that though regards the marks and the examiner never mentioned it with regards to my riding...
I did pass before all this Mod 1, Mod 2 came in though...
Whosthedaddy
PostPosted: 19:38 - 01 Mar 2010    Post subject: Reply with quote
4 for me, can't seem to get the hang of just using 2.
TUG
PostPosted: 19:41 - 01 Mar 2010    Post subject: Reply with quote
Rear brake/Clutch - four fingers
Front brake - two on the lever light braking normally all four under normal to heavy braking.
Haz ER-5, innit!
3/4 on the clutch (heavy springs) 2 on the brake. You don't need more than 2 fingers if your brakes are well maintained (on a modern bike anyway)
cyberglass
PostPosted: 20:04 - 01 Mar 2010    Post subject: Reply with quote
R1
as above 3-4 on the clutch and 1 or 2 on the brake
Dl650
2-3 on the clutch both hands on the brake and pray to god i stop before i hit anything Mr. Green
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
HP
PostPosted: 21:23 - 01 Mar 2010    Post subject: Reply with quote
cheers i may go for an hours training before my test to get rid of any bad habits but i practised some emergency stops using two fingers and i looked like i was stopping within the dsa figures so hopefully it will be fine as it feels so much more comportable having two fingers on the lever and the handle.
Clanger
Stirrer
PostPosted: 21:28 - 01 Mar 2010    Post subject: Reply with quote
For me it's three fingers, but only because I have the tiniest little fingers in the world!!! Very Happy
yen_powell
PostPosted: 22:19 - 01 Mar 2010    Post subject: Reply with quote
me too.
When I taught CBT/DAS I had to use four fingers (or three if I couldn't reach, depends on what bike I was using at the time) on the front brake in front of the pupils or I got told off by the bosses.
On the way home, in my time, I switched back to two fingers, which I think is safer personally, more control and less likely to grab a handful in an emergency, but hey, you're passing a test, not learning to ride safely, that comes later, so you have to do what the examiner wants to see.
It's a left over from the days when brake levers would come back to the handlebar under maximum braking and should be dumped like hand signals were a few years ago.
XT1200Z and a DR350 in bits
T0MMY
PostPosted: 22:37 - 01 Mar 2010    Post subject: Reply with quote
It's not just about the pressure you can apply with two fingers, it's more about the fact that on many bikes you won't be able to pull the brake lever as hard as possible before it has hit your two unused fingers. I naturally go with 2 but try to use 4. It isn't a problem if your bike has good modern brakes but if they're at all spongy it might be.
Just try pulling the lever as hard as you possibly can whilst stationary and see if you can get it to reach your fingers. I couldn't on my CBR but I can on my XT350.
ZX6R + CBR600RR
crackfinder
PostPosted: 22:39 - 01 Mar 2010    Post subject: Reply with quote
There are no DSA figures for stopping distances for the emergency stop....requirements are to a stop as quickly as you can while maintaining control of the bike, i.e. no skidding, the only figure I can think of is you must reach a minimum speed of 50kph when doing the emergency stop,
Very Happy
Alexio
PostPosted: 22:44 - 01 Mar 2010    Post subject: Reply with quote
All four fingers on both. My clutch and brake cables are getting harder and harder to use and my brake is probably nearing the end of it's life judging by how useless it's becoming anyway Laughing
I've noticed I use less on better maintained bikes.
PostPosted: 22:46 - 01 Mar 2010    Post subject: Reply with quote
Four on both.
HP
PostPosted: 22:47 - 01 Mar 2010    Post subject: Reply with quote
yeh cheers for the advice tommy i tried that and i can't make the lever hit my fingers, i also agree that using two fingers will probaly lead to a quick yet controlled stop where as grabbing a handful could lock up thefront wheel. crack finder the stopping distances i was talking about is the ones from the highway code what i remember from my theory is that 40mph is 36m and 30mph is 26m.
crackfinder
PostPosted: 23:10 - 01 Mar 2010    Post subject: Reply with quote
ok, but as far as i know they're not interested in stopping distance (unless you take the piss) they just want to see you bring the bike to a controled stop a.s.a.p
PostPosted: 23:16 - 01 Mar 2010    Post subject: Reply with quote
1 on the brake, 3 on the clutch, but it's been a long time I've had to worry about riding "properly" Smile
The Tot
PostPosted: 23:17 - 01 Mar 2010    Post subject: Reply with quote
4 on the clutch and 3 on the brake. I use my middle, ring and pinky on the lever whilst the index and thumb is used to control the throttle. Dead handy for me when i'm down-shifting and braking at the same time.
Never argue with autism
CRF_Rider
PostPosted: 23:36 - 01 Mar 2010    Post subject: Reply with quote
2 for the clutch 2 for the front brake sometimes even just 1 on the front brake. I have 2 finger levers and i have come from a trials background too. Also i ALWAYS ride covered.
Find much more modulation and control in two fingers rather than just 'grabbing a handful'. Also the front brake on the CRF is very very keen, 2 finger stoppies are incredibly easy.
One of my friends has to use four as he cant get on with only using 2 fingers. Just personal preference IMO Thumbs Up Altough i will say i did break a finger on my clutch hand using two and went down as my fingers got trapped between the clutch lever and the bar. this was on the R6 before i switched to two finger levers like im used to.
I got told to use four on my test an he asked why am i only using 2 fingers so i said "its just how i know, also if it were an emergency im not going to 'grab a fistfull and deck it" so he responded saying that "if they (the test centre) wanted to be technical it could be classed as not in full control of the veichle." He agreed on why i was only using 2 but said "for the test use all four and just get through it. Then go back to using two if ya want."
I'd use all four for the test then do which ever feels more comfortable to you Thumbs Up
P.S i find 2 finger levers last longer too as they dont go to the end of the bar so less likely to get snapped in an off Thumbs Up
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
Gazz
PostPosted: 23:42 - 01 Mar 2010    Post subject: Reply with quote
ms51ves3 wrote:
Four on both.
Same here, never had any urges to use less.
Although when I was doing my CBT years ago, we were warned against using anothing other than 4 fingers.
dodger
PostPosted: 00:09 - 02 Mar 2010    Post subject: Reply with quote
Last 3 fingers using the brake. All 4 using the clutch, evidently my hands are too weak to use just 1/2... Laughing
My Bikes: Piaggio NRG| Aprilia RS 125| Suzuki GSX-R 600|Yamaha Fazer Ducati 848
Europe 2008
Alexio
I find it easy enough to use four fingers to brake and still have my thumb and palm of my hand hold the throttle at somewhere above idle still which makes a big difference when shifting down as you say. The less vigorously I'm braking the more I can brake and properly control the throttle at the same time though. Even hill starts with just the front brake, it's very fun to practice and get right.
Nixon
PostPosted: 17:16 - 02 Mar 2010    Post subject: Reply with quote
Hmmm what does your examiner actually mean though? strictly speaking in examiner language:
Cover = Holding fingers on or over the leaver in anticipation of braking or operation of clutch.
Operate = Actually physically operating the brake or clutch.
Your examiner shouldnt be telling you to cover the clutch/brake at all, but shoudl be telling you to use all available fingers to operate the clutch/brake
The same goes for the rear brake and IIRC an examiner can give a minor per incidence.
PostPosted: 18:13 - 02 Mar 2010    Post subject: Reply with quote
Very Happy
Strange - they say you must do at least 31mph before doing an emergency stop. When I did mine it was in a 30-limit Smile
crackfinder
PostPosted: 18:34 - 02 Mar 2010    Post subject: Reply with quote
Pete. wrote:
Very Happy
thats one of the reasons that module 1 is carried out off road, minimum 50kph for the swerve, and minimum 50kph for the emergency stop, 50kph = 32mph
Very Happy
The last post was made 16 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 130.72 Kb
