GPZ 500 Indicator Problem...
Tris
PostPosted: 01:38 - 02 Mar 2010    Post subject: GPZ 500 Indicator Problem... Reply with quote
Well I've looked on google and on here, but I cant find anything similar....
What happened:
Working fine... dry day.... started flickering both directions (NOT blinking fast as if a bulb died).... then stopped working...kaput... nothing.
What works:
Main beem
Dip beem
Break light
Horn
Ignition
What I've tried:
Changing flasher relay... No change.
Checked and changed fuse.... No change
Checked all bulbs.... No blown bulbs
Tried to keep it as simple as possible and explain as well as I could, anyone got any ideas of what it could be at all? I dont like tinkering with my main form of transport, so only done basic checks, but frankly I wouldnt know any more than that, so I'm stumped.
Its a 1994 Reg Kawasaki GPZ 500, Single disk front and back, if that helps at all.
Many thanks for reading.
8 Years riding, and many more to come...
Current bike: Kawasaki er6f
joan33987
PostPosted: 02:14 - 02 Mar 2010    Post subject: Reply with quote
hm.... i experienced a similar problem, My right indicator on my GPZ500s, intermittely fail. when i flick on the right indicator, the indicator relay just buzz, but the left indicator worked as normal. I bought a new indicator relay from ebay, it didn't fix the problem, but the relay buzz has gone, but the indicator still didn't work. At last I use WD-40 to clean the connectors to the relay, and it seemed to cure it.
Don't know whether your problem is related to mine, the indicator relay is under the seat behind the right side panel? of the bike. I don't have the bike with me at the moment, couldn't accurately tell you which side.
It might be your indicator switch?
current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project
el_oso
PostPosted: 12:47 - 02 Mar 2010    Post subject: Reply with quote
you should hear a buzzing and click when you flick the switch to either side. say from left to right.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 16 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 36.84 Kb
