oil in pulse generator casing
BAN-DIT1200
PostPosted: 17:21 - 06 Mar 2010    Post subject: oil in pulse generator casing Reply with quote
Hi just began to do valve clearances for the first time on this bike and on taking off pulse generator casing found a small amount of oil in there. Anyone have any ideas how its got in ?
Blue_SV650S
PostPosted: 17:30 - 06 Mar 2010    Post subject: Re: oil in pulse generator casing Reply with quote
Is it NOT supposed to be in there then?!!? Confused
BAN-DIT1200
PostPosted: 21:38 - 06 Mar 2010    Post subject: oil in pulse generator casing Reply with quote
I dont know.There is nothing in the manual about it, I am presuming it should not be. Im thinking electricals and oil in the same place does not seem right .First time Ive tried doing valve clearances.
neatbik
PostPosted: 21:58 - 06 Mar 2010    Post subject: Reply with quote
I would imagine it should be there - what bike is it?
BAN-DIT1200
PostPosted: 00:08 - 07 Mar 2010    Post subject: Reply with quote
Its a Suzuki bandit 1200. If oil is meant to be there I dont understand why? It is only a small amount, about 50ml.
lonner
PostPosted: 08:33 - 07 Mar 2010    Post subject: Reply with quote
quite normal for oil to be there.
oil is non conductive and helps with cooling.
hth.
if it were a 2 stroke then you would have a problem
PostPosted: 09:35 - 07 Mar 2010    Post subject: Reply with quote
I don't think it should be in there, but it won't do any harm so long as it's not leaking out of the loom. If there are no through-holes into the guts of the engine to drain it away the it shouldn't be there really.
EDIT: Looking at the fiche there seems to be a square hole into the main engine gallery so yes, there would be oil in there.
https://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/2/Make/Suzuki/YearID/41/Year/2000/ModelID/6468/Model/GSF1200S_BANDIT/GroupID/270052/Group/CRANKCASE
BAN-DIT1200
PostPosted: 23:46 - 07 Mar 2010    Post subject: oil in pulse generator casing Reply with quote
Thanks for all the responses.Bike has been running a bit poorly, so I think I will finish doing the other checks and see.
Bezzer
PostPosted: 23:53 - 07 Mar 2010    Post subject: Re: oil in pulse generator casing Reply with quote
BAN-DIT1200 wrote:
Thanks for all the responses.Bike has been running a bit poorly, so I think I will finish doing the other checks. If it is still running poorly I will be removing the pulse generator to see if there is a channel which is meant to be allowing oil in or if there is a seal that needs replacing.
Don't bother,there is no seal, the oil should be there.
BAN-DIT1200
PostPosted: 21:19 - 09 Mar 2010    Post subject: oil in pulse generator casing Reply with quote
Thanks thats confirmed alright, can get on with other jobs for summer riding.
The last post was made 15 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 63 Kb
