cam timing placement and shims....
jimathy
PostPosted: 12:50 - 07 Mar 2010    Post subject: cam timing placement and shims.... Reply with quote
I am in the process of putting back together my engine. Only issues now are
a/ do I want the thicker shims on exhaust or inlet sides?
and b/
Where should I place the cams in relation to TDC? Both are identicle, but have several differing number/letters etc on them. Going clockwise from E) E1 16E (1/4 turn) I, (1/4 turn) 3 (2 teeth) 1, (1/4 turn) 2, back to E. How do i want to place them on IN and EX in order for them to do the right thing?
any help appreciated
EDIT, IN on the right of pic
jimathy
PostPosted: 17:17 - 07 Mar 2010    Post subject: Reply with quote
can anyone one help with the timing especially. I can't see any marks on the block to line up the E or the I, but i assume they will want to go at TDC, but will they want to be horizontal, or level with the top of the head (given that the engine is on an angle), or do they want to be 3 o'clock on the IN and 9 on the out, or what?!?!?!?
Please help!
Billing
PostPosted: 18:55 - 07 Mar 2010    Post subject: Reply with quote
On my NC23 you're supposed to line the crank up with the marks under the cover, then fit the cams so that the appropriate marks are touching (IN mark @ 3 o'clock, EX mark @ 9 o'clock.)
It would probably be best for you to get a workshop manual for your bike, or tell us what bike it is so we know Laughing
steven_191
PostPosted: 19:01 - 07 Mar 2010    Post subject: Reply with quote
cam timing 'usually' starts with piston 1 at TDC. but ive only got that experience from car engines.
jimathy
PostPosted: 19:14 - 07 Mar 2010    Post subject: Reply with quote
A moto roma RDG 125, single piston 125cc DOHC that's been refurbed by yours truly.
I took photo's of the engine with the cams in place before stripping, but now can't find the bloomin things! lol
PostPosted: 21:45 - 07 Mar 2010    Post subject: Reply with quote
As a rough guide, the cam lobes will be pointing at 10 o'clock and 2 o'clock on TDC when they are set right. If you have marks that make them do this and none others nearby then use those marks.
Make sure that once you fit the cams up you turn the engine over two whole turns carefully by hand in case you got it wrong.
jimathy
PostPosted: 20:04 - 08 Mar 2010    Post subject: Reply with quote
and any idea on the shims if they are different thicknesses?
thicker to IN or EX?
PostPosted: 20:28 - 08 Mar 2010    Post subject: Reply with quote
You cannot guess where to put the shims, you have to use the proper size on according to your valve clearances.
Read my thread on shim-based valve adjustment here:
https://www.bikechatforums.com/viewtopic.php?t=150267
jimathy
PostPosted: 20:44 - 08 Mar 2010    Post subject: Reply with quote
That's the point, i got 2 thick, and 2 thin, but don't know which go on intake and which on exhaust.....
PostPosted: 21:20 - 08 Mar 2010    Post subject: Reply with quote
Well then you fit all four shims and measure your clearances. If you get any with no clearance at all you have put in a thick shim where a thin one should be.
Don't get this wrong it will burn out the valves if you have too little clearance.
jimathy
PostPosted: 17:43 - 09 Mar 2010    Post subject: Reply with quote
When you say "clearance" these are Shim under valve shims, so will i still be able to tell?
PostPosted: 18:01 - 09 Mar 2010    Post subject: Reply with quote
Where the shims reside makes no difference. First measure your shims and make a note of where you put them in the head. Next, assemble the whole camtrain and make sure you line up the marks so the valves open the right time, to stop the valves from hitting the piston at around TDC. Now you must follow the method in my post listed above, for setting valve shims.
If your clearances were within spec before you started you should only have to swap shims around to achieve correct clearances. If not, you're gonna have to buy a shim or three.
I think you should really find some knowledgable help, seems like you're struggling a bit here.
PostPosted: 18:09 - 09 Mar 2010    Post subject: Reply with quote
Presume you mean they go under a bucket, with the cam operating the bucket. They take up the excess clearance so the clearance between the bucket and the cam is correct (ie, they just lift the bucket up a bit).
They are made very precisely and there will be numerous different sizes available. A small amount of wear in the valve seats or small differences in manufacturing tolerances (ie, tiny difference in valve length, cam size, etc). Hence you need to measure the clearances and choose and appropriate size shim to get the clearance within specs.
jimathy
PostPosted: 19:45 - 09 Mar 2010    Post subject: Reply with quote
Fair enough, sounds good. Is there somewere i can buy shims? i just did a serch online and am finding it impossible! i have access to a micrometer and measuring equiptment of various types. Is there a good place to buy from?
PostPosted: 19:56 - 09 Mar 2010    Post subject: Reply with quote
Many bike manufacturers use similar diameter shims, such as 9.5mm, you need to measure yours and buy the correct diameter ones.
I have a bike shop locally that has boxes of them and does them on exchange for £2 each. Places like wemoto sell them new.
jimathy
PostPosted: 19:59 - 09 Mar 2010    Post subject: Reply with quote
ok, cool. many thanks chap, i'll update somewhere on here when i get the thing running!
PostPosted: 20:03 - 09 Mar 2010    Post subject: Reply with quote
Here's a pretty good reference for what models use the more popular shims, 7.5 and 9.5mm:
https://www.sudco.com/75valveshims.html
https://www.sudco.com/95valveshims.html
The last post was made 15 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 100.38 Kb
