| jimathy |
 jimathy Borekit Bruiser
| jimathy |
| Billing |
 Billing World Chat Champion
 Posted: 18:55 - 07 Mar 2010 Post subject: |
On my NC23 you're supposed to line the crank up with the marks under the cover, then fit the cams so that the appropriate marks are touching (IN mark @ 3 o'clock, EX mark @ 9 o'clock.)
It would probably be best for you to get a workshop manual for your bike, or tell us what bike it is so we know  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| steven_191 |
 steven_191 Nearly there...
| jimathy |
 Posted: 21:45 - 07 Mar 2010 Post subject: |
As a rough guide, the cam lobes will be pointing at 10 o'clock and 2 o'clock on TDC when they are set right. If you have marks that make them do this and none others nearby then use those marks.
Make sure that once you fit the cams up you turn the engine over two whole turns carefully by hand in case you got it wrong. ____________________ a.k.a 'Geri'
| jimathy |
 Posted: 20:28 - 08 Mar 2010 Post subject: |
You cannot guess where to put the shims, you have to use the proper size on according to your valve clearances.
Read my thread on shim-based valve adjustment here:
https://www.bikechatforums.com/viewtopic.php?t=150267 ____________________ a.k.a 'Geri'
| jimathy |
 Posted: 20:44 - 08 Mar 2010 Post subject: |
That's the point, i got 2 thick, and 2 thin, but don't know which go on intake and which on exhaust..... |
 Posted: 21:20 - 08 Mar 2010 Post subject: |
Well then you fit all four shims and measure your clearances. If you get any with no clearance at all you have put in a thick shim where a thin one should be.
Don't get this wrong it will burn out the valves if you have too little clearance. ____________________ a.k.a 'Geri'
| jimathy |
 Posted: 18:01 - 09 Mar 2010 Post subject: |
Where the shims reside makes no difference. First measure your shims and make a note of where you put them in the head. Next, assemble the whole camtrain and make sure you line up the marks so the valves open the right time, to stop the valves from hitting the piston at around TDC. Now you must follow the method in my post listed above, for setting valve shims.
If your clearances were within spec before you started you should only have to swap shims around to achieve correct clearances. If not, you're gonna have to buy a shim or three.
I think you should really find some knowledgable help, seems like you're struggling a bit here. ____________________ a.k.a 'Geri'
 Posted: 18:09 - 09 Mar 2010 Post subject: |
Presume you mean they go under a bucket, with the cam operating the bucket. They take up the excess clearance so the clearance between the bucket and the cam is correct (ie, they just lift the bucket up a bit).
They are made very precisely and there will be numerous different sizes available. A small amount of wear in the valve seats or small differences in manufacturing tolerances (ie, tiny difference in valve length, cam size, etc). Hence you need to measure the clearances and choose and appropriate size shim to get the clearance within specs.
| jimathy |
 Posted: 19:56 - 09 Mar 2010 Post subject: |
Many bike manufacturers use similar diameter shims, such as 9.5mm, you need to measure yours and buy the correct diameter ones.
I have a bike shop locally that has boxes of them and does them on exchange for £2 each. Places like wemoto sell them new. ____________________ a.k.a 'Geri'
| jimathy |
The last post was made 16 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
